The Shop => Metal Stuff => Topic started by: doubleboost on August 12, 2012, 03:51:15 PM
Lads
I made use of the sand cores i made last week and cast my cylinder
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4071.jpg)
This picture shows the sand core in the mould
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4076.jpg)
The small round bit is where the metal is poured in (sprue) the rectangulsr bit is the riser
This feeds the casting as it cools
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4077.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4080.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4082.jpg)
This shows where the riser has been cut off (nice clean solid metal)
This is always a welcome sight
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4085.jpg)
Very happy with it
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4061.jpg)
I cast this yesterday with poor results
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4062.jpg)
Nasty void in the riser (scrap casting)
At least you can always cut it up and re melt it
I could not resist machining at least one face
Good clean metal
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4088.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4091.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4092.jpg)
Cylinder casting looks spot on John :thumbup: :clap: :clap: :clap:
Thanks to You Mate :thumbup: :thumbup:
I think i have found the shiney button on my new camera :ddb: :ddb: :ddb:
Nice work :thumbup: :thumbup:
I bet you have nicked Rob's camera :) :) :)
Really nice job on the casting :thumbup: :clap: :bow:
Nice work, what was the metal? Brass or Bronze?
well dun john it looks brill
nice finish john.just watch for JS and his ju ju dolls,as your good mates with "the twat in the yellow mac"
Looking good John :thumbup: :thumbup: :clap: , the inside looks very shiney too :)
Cheers Mick
Thanks Mick
I have a new camera :drool: :drool:
Lads
Got a bit more machining done on the cylinder
Next job is to mount it on the lathe saddle & poke a hole through it
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4104.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4110.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4114.jpg)
Wow, looking fantastic.. :bugeye: :bugeye:
Looking very good John :thumbup:
Nice pics as well:- happy new camera :headbang:
well thats it you will just have to mace me a set of castings well dun john
I think it might be the light in the North east or the fumes from the Newcastle brown plant smoke. but the finish is fantastic something for me to stride for.(both of you) what camera is it by the way and do you use flash or other lighting
Peter
don't think they mack newcastle brown all at newcastle any more
Peter
Peter
The camera is a Cannon 300 D
It is fairly old
SLR Type
I just use it on automatic if it needs a flash it just fires it off
Looks great John and is in perfect proportions! Brilliant project!
Nick
Hi Peter
Panasonic Lumix DMC-FZ38 , only use two settings IA (smarter than I) and Flower :palm: , no flash just point and shoot . I must learn to take popper photos ,instead of the usual rushed last minute shots .
Lookin good John :thumbup:
Does look good John :thumbup: :clap:
Peter
Peter
It is fairly old
SLR Type
Thank you for that
Peter
Lads
Started boring the cylinder
Mounted on the lathe saddle
Body filler is used to plug the end and the centre marked
It is mounted on the face that it will sit on
This should keep the bore paralell with the base :D:D
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4122.jpg)
The bottom of the cylinder is held against the face plate this should keep the bore and the botton face in line (note use of tab papers) as a "slip guage)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4149.jpg)
After a few cuts it was obvious that something was wrong
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4154.jpg)
Sand inclusion in the casting (core sand)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4164.jpg)
I may as well keep going
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4174.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4175.jpg)
Cleaned up at just under 2 1/4 inch
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4173.jpg)
Should be ok with one more fine cut when it cools off
I was aming for a bore of 1 7/8 the same as my marine engine
2 1/4 will give it a bit more power
Looking good John :clap:, a bit more power never hurt anyone :thumbup:
Mick.
