The Shop => Metal Stuff => Topic started by: loply on July 20, 2012, 07:06:13 AM
Hi folks,
Anybody know what the metal used for weight-lifting weights is?
I have easy access to loads of these, most are 5kg or 10kg and thus measure 180mm x 30mm upwards.
I have a few projects in mind to use them for - As the disc on a disc sander, as the basis for a fixed steady on my Viceroy lathe, and potentially a series of them stacked together to make the large-bore pneumatic cylinder for my power drawbar.
I'm hoping they're a form of cast iron and will be turnable on the lathe but I thought I'd check if anybody knows what their properties are for sure.
Cheers,
Rich
The ones I had were made in cast iron, of the lowest quality. Chills, hard spots and holes.
Tried turning one of them: it ate HSS and cheap carbide tools like butter, though I had put it into the stove and let slowly cool a couple of times.
Branded inserts purposely made for C.I. had reason of it, but I was really taxing my 7x10.
A couple of pictures:
(http://i1226.photobucket.com/albums/ee403/mzetati/_steamEngines/WIP01-Bernay/12/19Fw_IMG_0290.jpg)
(http://i1226.photobucket.com/albums/ee403/mzetati/_steamEngines/WIP01-Bernay/12/19Fw_IMG_0317.jpg)
the tools:
(http://i1226.photobucket.com/albums/ee403/mzetati/_steamEngines/WIP01-Bernay/12/19FW_IMG_0293a.jpg)
Marcello
If you do make a pneumatic cylinder - go careful.
For containing pressure you generally want a nice tough material, to avoid any chance of building a shrapnel launcher.
Hi Rich.
The plastic coated ones are made of concrete :(
Cheers Derek
Some of those weights are not too bad but others are not too good! :coffee:
I find my lathe tools have a much easier lifer if I take all the raised lettering off before starting with the lathe, a sharp cold chisel does this in just a few minutes.
...the tools:
Marcello
Just love the looks of those boring bars. I tried carbide tipped and indian/chinese insert ones. They are all pretty bad. Then bought some Maier (German ones) and some americans, they are SOOO much better. I had a chance to buy some Sandwik, but they used tips I don't use regularry and I allready have good collection...
PekkaNF
