Gallery, Projects and General => The Design Shop => Topic started by: Chuck in E. TN on July 05, 2011, 01:42:49 PM
I would like to make a couple of clamp on table stops for the X axis of my X2 mill. Anyone made these and have a drawing or pic to share?
Chuck in E. TN
here's some I made for my mill (a Chester Conquest ).
they might give you some ideas.
(http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/tablestop3.jpg)
(http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/tablestop.jpg)
Roy
There are some permanent (as opposed to temporary clamp-on) X and Y stops shown here, Chuck:
http://mikesworkshop.weebly.com/mill-table-stops-and-locks.html .
They are on an X1, but the general design would probably work just as well on an X2.
Thanks, Roy, and Andy for your replies. I like the simplicity of Roy's design. I will study both.
Roy, did you add a brass point to the locking bolt, or just a push piece?
Chuck in E. TN
the brass point is inserted into the end of the bolt.
these stops were a quick and dirty fix for a particular purpose but they have got certain limitations.
Roy
Roy,
What are the limitations you've found?
Chuck in E. TN
Thanks guys, just what I've been looking for. Such a setup on my X2 (Conquest) mill will reduce my reliance on my cheap DRO system. As I see it I will be able to do the initial setup using my DRO system and once the stops are positioned I shan't need to rely on my temperamental DROs for repeat travel. It's usually on the back and forth travelling that my DROs decide to throw a wobbly.
I shall be trying to adopt the ideas on Mikes Workshop but the fixtures will have to be adjusted to accommodate my DRO installation.
http://mikesworkshop.weebly.com/mill-table-stops-and-locks.html (http://mikesworkshop.weebly.com/mill-table-stops-and-locks.html)
John-Som
