Gallery, Projects and General => Project Logs => Topic started by: bry1975 on June 08, 2011, 10:40:49 PM
And of you LOVELY chaps fancy building a tool so I can remove BRITTLE Ceramic bezel inserts?
The insert is supposedly a very tight friction fit hence will need a good tool that can apply even pressure, probably need a tool that will be like a modified crystal die.
TIA Bry
(http://www.minus4plus6.com/images/GMTCBezel/tn_watchhead.jpg)
(http://www.minus4plus6.com/images/GMTCBezel/tn_bezelinsert.jpg)
