The Shop => Tools => Topic started by: Starhead on May 25, 2019, 03:15:05 PM
Hi folks,
I've got this lovely little lathe gearbox, I imagine a jeweler's lathe - (see pics)
Does anyone recognize how it connects to the chuck? Any ideas how I can adapt it to receive a standard chuck or a faceplate? The shaft is 1/2" diameter and has a drift pin , a groove presumably for a rubber ring washer, and a threaded hole in the end.
Thanks
Hi,
It doesn't look like part of a lathe to me.
The output shaft is really too small for even a watchmaking lathe.
The gear ratio from the pulley to the output shaft looks to be about 16:1. That combined with the large pulley would mean that the torque could be very high but the rotational speed very low.
A lathe spindle needs bearings to take thrust as well as radial loads. Does it have that feature?
Cheers.
More like a hand grinder.
Philf there are plenty of mini lathes with a 1/2" shaft, yes it will be low speed, and high torque which is what is needed for turning.
Seadog it's not a hand grinder, if you were to turn it by hand the output speed would be about 2rpm.
Maybe if I ask the question differently.... I've got this metal thing with a shaft sticking out, how can I attach another metal thing to the shaft?
"yes it will be low speed, and high torque which is what is needed for turning"
Only if you're turning something of large diameter. For small parts surely you need a high speed spindle to achieve a decent surface finish?
The shaft... how do I connect something to the shaft?
1 Polish the shaft,
2 Obtain or make a piece of thick wall tube that is a shake-free fit on the shaft
3 Mill, or drill & file a slot in the rear end to fit the drive pin
4 Drill & tap a hole to meet the groove & fit a grubscrew
5 Weld, or shrink on a suitable flange to fit a chuck of your choice
6 Mount chuck & place assembly on shelf while you look for a small lathe, 'cos I doubt this will serve as one :D
Thanks pycoed, I think that's probably the answer I'm looking for. Ive been searching everywhere for a 1/2" flanged coupler but I can't find anything suitable, everything in the UK seems to be metric now and I don't think I can ream out a 12mm one accurately enough without erm.. a lathe.
I'm pretty sure this will be capable of turning wax which is my intention, for lost wax casting of aluminium.
You don't actually need a chuck. I use a faceplate with a piece of waste wood attached for most of my wood turning. I think this would work even better for wax. One nice thing about using a faceplate and waste wood is you don't have to be particularly accurate with the faceplate mount. Once it's attached to the spindle, you true up the waste wood. Whereas a chuck should have an accurate mount.
