Gallery, Projects and General => Project Logs => Topic started by: Divided he ad on March 08, 2009, 12:36:38 PM
Title: Tubing bender
Post by: Divided he ad on March 08, 2009, 12:36:38 PM
Well it's about time I got off my ass and made something I suppose!!??
This is a side project that has been threatening for a while, it's all in order of completing my Aeolipile!! (yep I know.... About time!)
So here are a few photo's... I know, from the dates you can see I've been holding out on you.... I've been a little preocupied   :hammer:
I'm using a plan.... When I say using I'm basically using the bits I like.... I'm re-modeling the rest as I go  :)
Well, here they are..... Not my finest work.... But it's meant to be and will be functional  ::)
Start with some scrap...
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC02970.jpg)
faced off top using the saw cut as a datum ..... This was a seriously rough piece of scrap! I also made a little facing down the sides to allow parallel mounting for the wider faces, (the bottom one was done after this photo... it was remounted and the side cut first so the bed hadn't been moved) once the part was set up on these smaller cuts and the rough side faced it could be turned over and faced down far enough to remove them.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC02972.jpg)
The block was mounted in the 4 jaw and a bit of reducing performed.... Free hand.... Not going to effect anything important. (edit... The numbers in circles are my machining order... 1 shape the part as seen, 2 drill and tep, 3 pivot hole and slots and finaly 4 the big slot... planning you see  :thumbup:)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC02975.jpg)
The pivot hole was drilled and two holes for the end of the slots,(no DRO's at the mo.... Cold weather kills them!!) then the slot cut in the top only as far as required to pass into the path of the larger slot which is yet to be cut. The part was then turned over and the bottom slot was cut.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC02980.jpg)
The larger slot is then cut, this shows the areas of the smaller slots and the pivot holes being exposed as material is removed. (1" end mill)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC02983.jpg)
And here is the part completed.....
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC02986.jpg)
Now there was a lot of thought put into the machining process here... I held the solid block in the lathe first so that it was easy to machine.
The smaller slot and pivot holes were drilled and milled into the solid block to keep them in line. (if done after the larger slot when two bits of thinner metal they could flex under pressure at the ends.)
Then when the larger slot is machined it all comes into order, and now that the parts structure is weakened it's ok... You've already done all the little fiddly bits!
I''ve already made the base and clamp..... I'll be posting that later.... Else this would be a ginormous post!!
There are some small errors, but nothing that will prevent the tool from doing what it is designed for.... I'm ok with that, it's a tool.... not a display piece!
Hey it's not a total science.... Most of this home shop hobby is fun..... Well it is for me anyway  :thumbup:
Feel free as always to comment..... You'll comment more once you see the base!!  :doh:
Ralph.
Title: Re: Tubing bender
Post by: bogstandard on March 08, 2009, 01:56:15 PM
Ralph,
You are not alone, but it is such an easy design it can just be modded on another part so it doesn't matter. Mine works a treat.
Post by: Twinsquirrel on March 08, 2009, 02:36:35 PM
Looks good so far Ralph, what plans are you using?
David
Post by: Bernd on March 08, 2009, 03:34:29 PM
HeHe, I see what you were doing that day.  :headbang:
I take it this going to be a "small" tubing bender. Probably call it more of a pipe bender.
Those side projects to get the main project moving can be time consuming. I'm working on a side project so I can finish up on that clamp plate for my indexhead.
Nice job by the way. I think I'm going to need one of those benders sometime down the road.
Post by: Brass_Machine on March 08, 2009, 03:59:17 PM
Nice start Ralph. Which design are you doing again?
Post by: sbwhart on March 08, 2009, 05:16:46 PM
Good one Ralph its nice to see you giving Aeolipile a mention I was going to give you a  :poke: but no need now.
Look forward to next installment.
Post by: Divided he ad on March 08, 2009, 07:38:33 PM
John, I have learnt that when you haven't got a 5mm end mill, use the 6mm you do and make the other bit fit it  :thumbup: Seems to have worked so far  :)
I've also used a detail of three from the one you showed me... I'm always absorbing something when I come to visit  :med: You'll see it soon enough  :thumbup:
David and I have had a chat about the plans.... I'm not thinking they can be posted?
You say pipe I say tube.... You've no doubt heard another version of that phrasing?  :)
It'll probably do a 10mm annealed tube though   :thumbup:
Erm... Eric, you'll see soon.... I'm not too sure about publishing the pic's?
Stew, I knew you'd be getting itchy about the Aeolipile.... It's been niggling me too!!
Soon, it'll all start to work, I hope  ::)
Thanks to all for the positive posts  :clap:
Ralph.
Post by: Bernd on March 08, 2009, 09:22:24 PM
Ralph I remember once reading a disscusion on a forum about "pipe" and "tube".
Tube usally meant a thin wall, were as pipe was something heavier. For example a water pipe. Much thicker than EMT (electrical conduit over here). But then I ask why do they call it an exhust pipe why not an exhust tube since the exhust uses a much thinner wall. :scratch: Rather confusing, and I'm getting  :offtopic: here.
Now I remember what the disscusion was a "tube bender" versus a "pipe bender". Ok that's enough disscusion, on with your subject.
Post by: bogstandard on March 09, 2009, 11:27:13 AM
Twinsquirrel David,
If you send me an email, you will get plans by return.
Post by: Twinsquirrel on March 09, 2009, 02:37:28 PM
Thanks John, PM sent :D :D
Post by: Divided he ad on March 10, 2009, 09:35:43 PM
Ok.... A quick one before I get the sleep I should be having!
Not much explanation more pic's .... I know,   :worthless:     :)
The base blank.... A piece of garage door arm  :thumbup:
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03006.jpg)
Drilled and recessed for the screw and pivot. Then the holes were drilled and tapped for the clamp.
(mistake of the day.... I snapped a centre drill in the last hole I was drilling :doh:  So 2 new holes just to the left of the now useless ones, and the clamp base will be made to fit.... Bespoke?? :scratch: )
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03010.jpg)
The clamp base.... Scrap bit of ali from an old metal carport  :borg:   cut to height with the slitting saw... Worked a treat (plenty of "bog water" on the blade eh Stew?.... Lubricating spray to the rest of you :))
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03011.jpg)
two slots in the correct place for the adjusted holes :thumbup:  Clamp base finished!
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03012.jpg)
The clamp upper chucked up ready for a but of shaping, drilling and tapping.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03013.jpg)
shaping,drilling and tapping completed.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03014.jpg)
Cut the recess into the clamp upper.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03016.jpg)
The clamp parts so far.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03017.jpg)
mock up of the clamp parts... The bolt is to be changed.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03019.jpg)
A little shaping.... Got the tools might as well!!
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03020.jpg)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03021.jpg)
Well, that's it for now.... These were all made last week.... I'll try and get some more done this week, we will see!
Ralph.
Post by: bogstandard on March 11, 2009, 01:51:38 AM
Lookin' good Ralph.
You'll be going round the bend in no time, if you haven't already  :lol:
Post by: Divided he ad on March 11, 2009, 03:52:27 AM
I think I'm firmly on the way John.....?  :ddb:
 :lol:
Ralph.
Post by: sbwhart on March 11, 2009, 04:04:22 AM
Nice neat job Ralph, looking good.  :thumbup:
Broken centre drill  :wack: turning the plate over and drilling from the other side would have sorted the broken bit out  :ddb:
Have fun
Post by: Divided he ad on March 11, 2009, 07:22:08 PM
Well you see Stew.... I wasn't willing to spend the time flipping and re-positioning for the sake of a clamping screw hole.....(it's only a tool, and that bit will not interfere with it's working)  I killed a drill bit the last time I tried that too!
I'd have sooner made the base again if it were that much of an issue... Got loads of old garage door arms around here  :thumbup:
Still haven't made any further progress.... Friday will be the earliest now..... Snooker tomorrow  :)
Ralph.
Post by: sbwhart on March 12, 2009, 02:49:42 AM
They look a useful size:-  hint, hint, nudge, nudge.
 :ddb:  :ddb:
Post by: Divided he ad on March 12, 2009, 08:25:14 PM
I'll transport some your way next time I'm over there Stew.... I'll take a look through my stock and get you some varied sizes :thumbup:
Ralph.
Post by: sbwhart on March 13, 2009, 12:02:20 AM
Thanks Ralph  :thumbup:
I'll get you a little goody bag together.  :ddb:  :ddb:  :ddb:
Post by: bogstandard on March 13, 2009, 12:48:37 AM
You really do leave yourself wide open Ralph.
You are forcing me to ask for some now :poke:, and you know I don't like begging. :lol:
Post by: Divided he ad on March 14, 2009, 02:56:49 AM
John.... You are correct you shouldn't have to ask.... But where would it end?  I could fill your metals bin with many differing unknown grades of mild steel of all sorts of shapes..... But you'd never find anything else!
Well with business being a little slow it'd take a short while..... But I'd get it full   :)
I'll see you both right, don't worry about that  :thumbup:
Sadly I've got to work today :(  But I'm at the office/yard.....  :coffee:   I'll hunt some bits out of the scrap skip and put them on one side  :thumbup:
Back onto topic!!  I'll be aiming to get a bit more done tonight, was aiming for last night..... But fell asleep at 18:00 and woke up bout an hour ago!!!  :scratch:
Anyway, I'll see where I get to later?
Ralph.
Post by: Divided he ad on March 22, 2009, 09:24:10 AM
Well.... So much for that!!!!  :doh:
Well last night got a little workshop time in and made a few more bits....
My new phone doesn't seem to like to store all the photo's you take!!! So very few good ones saved as a result.... So here are a few exploded shots as to where I left the job last night.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03082.jpg)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03083.jpg)
I had to give it a little sprucing up.... It's just felt like it needed it  :)
Hopefully the block on the bottom for holding in the vice and the rolls will not take me too long?  Then it'll be back to the Aeolipile (is that the correct spelling.... Still haven't got that down properly in my head!!)
Time to re-mount the RT to my mill!
Hopefully I'll be a little quicker with the results than last time!?
Ralph.
Post by: Bernd on March 22, 2009, 09:57:18 AM
Glad to see a little more work done on the bender. I'm going to be building one in the not to distant future, so make sure you are doing it right. I'm going to fullow your build.  :thumbup:
Post by: Brass_Machine on March 22, 2009, 11:46:35 AM
Very good Ralph!  :headbang:
You are coming along quite nicely.
Post by: Divided he ad on March 22, 2009, 12:52:53 PM
I wouldn't follow my build Bernd.... It'll take you ages!!!  :lol:
Thanks Eric, slowly but surely  :)
Maybe more this evening?
Ralph.
Post by: Darren on March 22, 2009, 02:16:13 PM
That's looking very shiny Ralph..... :thumbup:
Post by: sbwhart on March 22, 2009, 03:36:20 PM
Nice one Ralph  :thumbup:
Ther's a few bits on their I havn't seen before or was I asleep some time:-  can you sleep surf the net  :scratch:
Any way keep up the good work looking forward to seeing those spinning balls.
Post by: Divided he ad on March 22, 2009, 08:00:16 PM
  Yep! It is a little.... But I haven't polished any of it yet..... just a bit of emery  :)
Seen before at all.... Probably because I made a few bits to my own design/tastes! ..... But that's what your meant to do with plans right? Change tham to suit you!  :dremel:
Sleep surfing.... Well I usually fall asleep while surfing! I'm obviously working too hard.... Or staying up too late.... Or getting old!!!  Maybe a little of all three!?
  What! I haven't got a party trick!  :scratch:          :lol:
All good things Stew, all good things  :)
Ralph.
Post by: ozzie46 on March 22, 2009, 10:24:42 PM
   Nice work Ralph or should I say good play time instead of "work" :thumbup:
  Ron
Post by: Divided he ad on March 23, 2009, 08:43:22 PM
Thank you Ron. "Play time" ....Stress relief in my book!  Good tunes and machinery.... Takes away all those niggling thoughts about everyday life  :med:
Speaking of which.....
Got a little done tonight... Still got the base and a few bits to experiment with but....
The first, larger roll.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03085.jpg)
The two rolls for todays test.... Didn't even measure the dia! Just wanted one larger than the other  :)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03087.jpg)
Right. The set up for cutting the relief for the tube.  I couldn't quite remember what John said about the height of the cutter so, I put my cell to work and figured that if it was just slightly above centre then it would cut with the face of the end mill and then when the RT was turned the other way it would take off any slight ridges and leave a nice finish.... I used my mill stop to make sure that the two cuts lined up once mounted in the main tool.  Seemed to work to plan anyhow!  :thumbup:
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03090.jpg)
Direction of rotation of the part was clockwise as you face the chuck (part moving upwards as turned) This shows the first 0.25mm cut coming round.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03091.jpg)
Then a shot of the large roll just about there. The last clockwise cut was followed by a rotation anti-clockwise to clean off any small grooves left by my turning of the RT handle.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03094.jpg)
The view from the side. See how the mill stop lighty touches the face.... I know it's in the right place :)  (sounds obvious but... To get the big roll in and up to the stop which can't be moved ....Cause it's a stop! I just opened the chuck jaws much wider than the roll size and slid it in between the sides of the jaws then held it steady while I closed the jaws and held it lightly to the stop.)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03095.jpg)
The rolls ready for use. If your wondering why the masive height of the rolls.... They will have another relief cut into the top half too.... Multi use (Idea a la Boggie!) I recon I could do upto 10mm anealed copper tubing in this..... Might try it one day?
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03097.jpg)
And to prove it works.... Even if I haven't made the base bit or the end of the handle....
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/th_MOV03098.jpg) (http://s289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/?action=view&current=MOV03098.flv)
And the reason for the various roll sizes..
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03099.jpg)
Well that's it till at least Thursday evening.... But I'm happy  :D
Ralph.
Post by: bogstandard on March 23, 2009, 09:20:11 PM
Nice one Ralph :clap: :clap:
It looks like it works really well.
I have the cutter slightly lower than centre (only say 1/2mm), otherwise you won't get the true depth of groove from touching on. I have the roller turning so that the roller is being fed from the cutter bottom towards the top.
I also made a mandrel to put the rollers on in the RT. So you just cut one groove, flip it over end to end, change cutter size and cut the next groove. That way they will all be perfectly in line with each other.
Also, if you are only ever bending soft copper and brass, the rollers could be made from something as soft as ali. I used brass for mine, and show no signs of damage or wear.
Now wasn't that an easy tool to make?
I think this design must be the easiest one to make, but is actually a lot more versatile than some of the more complicated ones.
Again, nice job
Post by: Bernd on March 23, 2009, 10:41:57 PM
Nice one Ralph. :thumbup:
Looks like that's the next project for me after i get my indexhead done.
BTW, like the tunes in the background. :headbang:
Post by: SPiN Racing on March 23, 2009, 11:54:20 PM
Very Cool tool!!
I dont need to bend small tubing much YET... but I am seriously keeping that in mind.
When I was doing the R/C thing in high school and early college I usually bent copper tubing for fuel systems with a spring around it. Or braided steel line inside to prevent a crush, or by hand. But it worked well for the application inside a fuel tank.
For the race cars I have a really shoddy plastic screw together tubing bender to bend brake lines, and or up to 1/2" fuel system lines.
And I DO need to make some bends in the new fuel system lines..... I might need to look into making a bender sooner rather than later.
grr  :proj:  LOL
VERY NICE TOOL  :thumbup:
Post by: sbwhart on March 24, 2009, 02:06:34 AM
Well done that man  :ddb: :ddb: :ddb: :ddb: :ddb: :ddb:
Post by: Twinsquirrel on March 24, 2009, 04:18:12 AM
Brilliant! nice job Ralph.
Good to see your workshop is almost as messy as mine :headbang:
David
Post by: Stilldrillin on March 24, 2009, 04:38:58 AM
Well done, & well shown Ralph.....    :thumbup: :clap:
Post by: Darren on March 24, 2009, 04:50:46 AM
People keep showing me nice shiny objects to make..... :dremel:
Well done Ralph, that works really nicely, simply and results in a tidy job....
I wonder if it can be scaled up to solids..... :scratch:
Post by: bogstandard on March 24, 2009, 05:01:54 AM
Darren,
I think I have plans for a vice held solid bender somewhere, let me have a root in my 'bunker' magazine collection, and I will get back to you. I think it uses the same easy sort of build and principle.
Post by: Brass_Machine on March 24, 2009, 11:16:27 AM
Nice job!   :bow:
I gotta get into the shop.
Post by: Divided he ad on March 25, 2009, 03:58:45 AM
Thank you fellas  :)
I am sure that many different designs will pop up soon.... It's easy as always to change things around the important "core" measurments, you don't have to make it a 10mm thumb screw.(even though that's not on the plans at all!!)  If to have big hands or a crappy grip, make it 25mm!  :thumbup:
John, fun and not too tough to build... I always make stuff look too dificult in my mind.... Then I start to make it and it all turns out ok! (usually!!)
point noted about the tool position, I will adjust accordingly for the next run  :)
Bernd.... Tunes, Got to have some good tunes playing  :headbang:
Davd, messy workshop.....?  Don't know what you mean.... :scratch:  That's tidy!  :bugeye:
Darren, solids, you might have to re-design the clamping method for greater force, it can slip backwards if not enough pressure applied!  But that's what a Madmodder should do isn't it??  :borg:
Still got to finish it..... Later in the week  :thumbup:
Ralph.
Post by: Divided he ad on April 15, 2009, 07:41:04 PM
Ok then.... Finally here is the finished article (except for any and all the rollers I might make!)
A bit of aluminium for the vice block, tapped for the pivot pin and the securing screw.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03169.jpg)
A tidy up of the roller frame rear end.
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03173.jpg)
and of course.....
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03172.jpg)
The knob for the handle  :headbang:
So a few shots of the end product and then the next time you should see this is in a vid (if I make one?) or the Aeolipile thread  :thumbup:
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03176.jpg)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03178.jpg)
(http://i289.photobucket.com/albums/ll221/dividedhead/Tubing%20bender/DSC03182.jpg)
Oh, that big chunk of brass.... Soon to be made into a roller for the Aeolipile project  :dremel:
Ralph.
Post by: Brass_Machine on April 15, 2009, 08:11:26 PM
 :clap: :clap: Nice one Ralph!  :clap: :clap:
Post by: Bernd on April 15, 2009, 09:35:07 PM
Very nice Ralph.  :thumbup:
Waiting to see the first bent tubes coming off of it.  :whip:  :headbang:
Post by: sbwhart on April 16, 2009, 01:46:04 AM
Good Job Ralph
 :clap: :clap:
next step  :poke: Aeliopile
Post by: Darren on April 16, 2009, 03:06:38 AM
Nice going Ralph,
Tidy workshop, looks just like mine  :lol:
Post by: Stilldrillin on April 16, 2009, 03:24:59 AM
Blummin well done Ralph.  :clap:
An` I can`t see nowt wrong wi yer workshop.......  :wave:
Post by: Darren on April 16, 2009, 03:28:39 AM
Can't be, he has the same high standards as me  :lol:
Post by: Divided he ad on April 16, 2009, 03:49:53 PM
Thank you guys :thumbup:
I tried really hard but just had to sparkle it a little!!  ::)
Tidy.... That is quite good for the end of a project.... Plus I'd been making some little bits for other people inbetween.... It all makes clutter!
It'll all be tidied off soon.... Got to take the Aeolipile and finger engine trays out and get some more done! plus replace the name on this tray with power feed  :D
Right, now I'm off outside for a bit :thumbup:
Ralph.
