The Shop => Tools => Topic started by: sparky961 on July 14, 2015, 10:30:35 PM
Title: Angle Plates - How are they made?
Post by: sparky961 on July 14, 2015, 10:30:35 PM
When performing the final grinding operation on an angle plate, how does one ensure squareness to a crazy degree of accuracy? What about without another angle plate to use as a fixture?
Title: Re: Angle Plates - How are they made?
Post by: Lew_Merrick_PE on July 15, 2015, 11:39:33 AM
Sparky -- I am assuming that this question involves a surface grinder.  Am I correct in this?
If so, there are a lot of variables surrounding the clamping of the angle that are dependent on other things, but the basis would be to use something like unto jack screws to support the to-be-ground surface and making adjustments until your "base" is true to the table using a knife-edge or die-maker's square before (& after) clamping.
Such angle plates are usually made in pairs such that you can blue-check the fit between them and scrape in the final form.
Post by: vtsteam on July 15, 2015, 12:19:33 PM
I'm wondering if the fixturing method used for non-crazy accuracy with two raw angle plate castings, using a lathe, might just work for crazy, as well?
Here's how:
On the lathe for non-crazy, you take one as-cast raw angle plate, flatten (not square) the faces with a file enough to mount it so it won't rock on the faceplate. It doesn't have to be square yet, just flat.
Then bolt it on to the faceplate with a shim under it until the extending face IS square to the faceplate, checking with a true square.
Then you take your second raw angle iron casting, flatten the faces as before, and mount it to the first angle iron leg, which you made square to the faceplate. It now has a raw face that is somewhat parallel with the faceplate, and you proceed to turn that off flat, which makes it truly parallel to the faceplate and square to the other leg of its angle plate.
Then you take apart the rig, and mount the newly squared angle plate to the faceplate, and mount the second (still untrued) faceplate to it, and face it's extended leg true. Now both angle plates are square (non-crazy).
A similar process may be possible fo you using a flat but not absolutely true angle plate (or even angle iron) with shim -- checked with your true square, to yield a vertical surface to your surface plate for mounting your second and important piece to be squared.
Post by: chipenter on July 15, 2015, 01:47:29 PM
Harold Hall used cylindrical squares http://www.homews.co.uk/page309a.html in his artical on angle plate from castings .
Post by: sparky961 on July 15, 2015, 04:50:17 PM
Thanks for the tips.  I was, indeed, asking about doing this on a surface grinder.  I believe that's the only way you could get close to the finish you see on commercial examples, not to mention the only practical way if the plate is hardened.
It seems the general consensus is that you need something square to begin with.  Be it a machine, a square setup by shims or other adjustment, or a proven master.  I thought there might be some "magic" method that zeros out any errors that may creep in.  I was trying to think of a way to use two of them in a way that would do this with theoretical perfection; kind of like when you lap 3 plates together in turn and end up with a dead-flat surface.  Unfortunately everything I could come up with so far just kept the two equal, rather than exactly 90 degrees.
I like the idea of using cylindrical squares for the reference.  I'll have to also look into how to accurately make one (or two) or those now.  I'm thinking if you didn't do it quite right you'd be relying on the perpendicularity of the lathe.  Taper is easy enough to eliminate but how to ensure the end face isn't concave/convex?  I suppose if you hollow out the bottom a bit it would only be sitting on a small circular ring of contact area.  Whether or not that face was dead flat would matter little at that point.
So, I'm left believing for now that you can only make an angle plate as perpendicular as you can make (and more importantly "measure") your setup.
Post by: nrml on July 15, 2015, 05:02:53 PM
I remember reading somewhere of lorry gudgeon pins being used as cylindrical squares. It makes perfect sense as they are hardened and ground to close tolerances. They will probably be more accurate than the average shop made square.
Post by: vtsteam on July 15, 2015, 10:04:40 PM
Sparky, yes, concave or flat face turning will make a true cylinder square which can become your reference square. A convex face is pretty obvious because it wobbles on a flat surface. You can blue and rub on a surface plate to check the other two. You can use a toolpost grinder instead of a lathe tool if you want.
Once you've got your reference cylinder sqaure you can use it to check your setup for the grinder to do the angle plate.
The method I gave above can be used on a grinder, and the first angle plate can be any kind of angle -- even angle iron. You just shim it unti its vertical leg is square to the table (checking with your cylinder squre) and then bolt it down. Then bolt your angle plate to be machined to that, and start grinding.
Or you can do the whole thing in the lathe as I mentioned earlier. If you want to check your lathe for how well it faces, it's easy enough to do with a straightedge and some marking blue. I skim my cast aluminum faceplate to check it. Scrape your carriage if need be to correct. (well you can set the topslide over and use that temporarily if it has enough travel -- but you'll probably want the cross slide true anyway).
All this is done without any true measuring tools, and I think it's analagous to the 3 plate method for  getting a true flat.
Post by: SwarfnStuff on July 16, 2015, 04:35:32 AM
Yep Nrml, I paid a visit to a truck / lorry repair place recently and got a few gudgeon pins that unfortunately were too big for my X2 mill. Not to worry, they will make great rollers for a bending roll eventually. There was one in the grab lot I got from a small Japanese Diesel that was perfect size but alas, I only grabbed one. Bummer have to wait till next visit and hope they have worked on a similar small truck.
Post by: krv3000 on July 17, 2015, 08:03:49 PM
hi just my bit as I do a lot of grinding at work all ways start with a flat face that means a lot of filing or grinding to get one face 90% flat then the next face is made level with that and so on
