The Shop => Tools => Topic started by: vtsteam on June 09, 2015, 02:17:16 PM
This is one of my favorite tools ever -- a drawknife manufactured by Winsted Edge Tools. I've had it 40 years. I'm putting photos up here because Simon mentioned possibly making a drawknife from an old file in his banjo thread, and the proportions of this one are so much better to work with than more modern versions I've tried.
This one is about 20" overall across the top, 21-1/4" overall at the ends of the handles, and has a 14" cutting blade. The blade is 1-1/2" wide and about 1/4" thick.
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/drawknife1.jpg)
The blade is slightly curved in plan -- about 1/8" at center, and this is a really critical quality for using it. The curve is concave above the bevel side of the drawknife. If you hold it level, bevel side up it would appear as a sag in the middle.
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/bladecurve.jpg)
The blade is relieved in a bevel along the top edge, and 7/8" of the lower portion of the blade is relieved to 1/8"
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/bevels.jpg)
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/relief.jpg)
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/upperbevel.jpg)
The tangs extend through the handles and are riveted over a steel cap:
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/handle.jpg)
The relief and relatively narrow blade keeps the tool light and maneuverable. The curve concentrates the cut on a flat surface, which is essential to working freely. The effective curve and tool width can be reduced by angling it, and very fine shavings can be removed -- or huge amounts of wood depending on the pitch held. This is different from a spokeshave, which can only cut at one angle and one set depth. You vary a drawknife's angles continuously as you work. By feel as much as anything else. It's particularly effective to work with knots and difficult grain. You can flip it upside down, and reverse direction, while controlling depth, angles, stroke and strength. You can cut inside curves, unlike planes (other than a compass plane) and much easier than a spokeshave. A drawknife is a virtuoso instrument for working wood compared to fixed shoe tools. Kinda like the difference between a xylophone and a violin.
That's interesting, thanks for posting it. I was just looking at some more videos on rasps, spokeshaves, and draw knives and had a horrific realisation that i'm turning into a hand-tool guy. Soon i'm gonna have a wall lined with all kinds of specialist planes that I never use.
If you're making a 30' mast, you could either use a drawknife or a 30' bed lathe with a traveling steady. The drawknife would win hands-down in speed, and likely finish., and is quite a bit cheaper.
Draw knife is a tool that has eluded me. I wish I could find a good one and someone would teach to use it. I have used vaguely close relative to peel the bark of green wood and even those can be temperamental.
Thanks for showing.
Is that a single cut draw knife Steve :)
One really really big cut, Rob! :lol:
I think tomorrow I might try to make a video of using it.
