The Breakroom > The Water Cooler |
Oh bum |
<< < (2/2) |
tomrux:
why not a couple of different draw bars. I have M8 M10 M12 3/8 and 1/2 For my sx3 In the home shop I have even found normal threaded rod to suffice. No swinging on spanners, they appear to last quite well and at the price of a metre of rod from the local hardware easily replaced. Tom R |
Arbalist:
--- Quote from: tomrux on June 21, 2014, 06:40:41 PM ---Why not a couple of different draw bars. Tom R --- End quote --- You could indeed but I plan to make a self extracting draw bar so will be sticking with M12 for my VMC as it will be less work! Details of the process at the bottom of this page: http://modeleng.proboards.com/thread/5804/mill |
Bigbadbugga:
--- Quote from: philf on June 21, 2014, 04:35:48 PM --- --- Quote from: chipenter on June 21, 2014, 04:07:04 PM ---10mm X1.5 is very close to 3/8 Whit , tapping drill for 10 mm is .3mm bigger . --- End quote --- That's exactly what I did with my 2MT collet chuck. Run an 8.5mm drill down first (or slightly bigger if the shank is very tough) then an M10 tap. The M10 is approx 16.93 tpi compared with 16 tpi for the 3/8 BSW but, as the M10 is nearly 0.5mm bigger in diameter you get several (and enough) perfect threads before the mismatch starts to show. Phil. --- End quote --- Thanks guys, I'll certainly think about doing this. I was wondering how close the threads would be. |
Bigbadbugga:
--- Quote from: Arbalist on June 21, 2014, 07:07:26 PM --- --- Quote from: tomrux on June 21, 2014, 06:40:41 PM ---Why not a couple of different draw bars. Tom R --- End quote --- You could indeed but I plan to make a self extracting draw bar so will be sticking with M12 for my VMC as it will be less work! Details of the process at the bottom of this page: http://modeleng.proboards.com/thread/5804/mill --- End quote --- My Chester mill has a self extracting drawbar, replacements may be a project for the future but as a complete noob I fear this option may be a little beyond me at the minute. |
Arbalist:
--- Quote from: Bigbadbugga on June 22, 2014, 07:44:32 AM ---My Chester mill has a self extracting drawbar. --- End quote --- Nice, wish the Chinese would fit them on all their mills! |
Navigation |
Message Index |
Previous page |
