Author Topic: Elliptical path on wheel rim?  (Read 11732 times)
  • Country: nz
« on: May 28, 2014, 03:31:54 AM »
How do I machine an elliptical groove in the rim of a wheel?  I dont even know if elliptical is the right word but I want to machine a groove in the rim of a wheel so that I can get movement parallel to the wheel's  axis,  sort of like the action of a swash plate.
Thanks
« Last Edit: May 28, 2014, 04:07:20 AM by John Hill »
Re: Elliptical path on wheel rim?
« Reply #1 on: May 28, 2014, 04:15:31 AM »
What? Barrel Cam ??
Similar to pic ?
Dunno, John. Tried to do it myself a couple of years ago with a uController, 2 steppers , one on a rotary table and t'other on the x-axis but although the principle is, I believe, sound my attempt was not too good.
Did work but the set up needed much more refining and was abandoned.
  • Country: nz
« Reply #2 on: May 28, 2014, 04:28:22 AM »
Yes Bluechip, something like that!
Offline Fergus OMore
« Reply #3 on: May 28, 2014, 04:41:52 AM »
Maybe Ornamental Turning is what you are looking for. Elliptical chucks?
There's a Society in the UK. Maybe- Charles Holzapffel and Ornamental Turning. Tubal Cain did a book on the topic as well.
Regards
Norman
Offline JohnC
« Reply #4 on: May 28, 2014, 04:44:11 AM »
If you put the wheel on a faceplate and packed up one side you could use a parting tool to cut a groove perpendicular to the lathe axis but angled to the wheel axis.  Tried to post a sketch but failed, will try again!
John C
York, UK
Offline JohnC
« Reply #5 on: May 28, 2014, 04:47:43 AM »
[embed=425,349]<iframe width="480" height="360" src="http://s1094.photobucket.com/user/JCphotob/embed/slideshow/"></iframe>/embed]
Sorry, best I can do for now is a link to photobucket!
John C
York, UK
  • Country: nz
« Reply #6 on: May 28, 2014, 04:59:07 AM »
Fergus, ornamental turning is interesting and, I think, uses a sliding spindle so I will have to think about that some more!  We have one of the world's best collections of Holzapffel and other OT lathes in our town and maybe I should pay that museum another visit!
Thanks.
JohnC,  I have tried to avoid anything that tilts the wheel for cutting the groove as that will complicate things when I try to put a follower in the groove later but I might have to resort to that method eventually!
Thanks.
« Reply #7 on: May 28, 2014, 05:06:44 AM »
traditionally techniques such as a dividing head gear coupled with the milling table can produce simple cams and spirals.
To produce your cam , I'd suggest drawing or printing the shape as a graph with displacement against angle . you can then either wrap the print around the part and carefully follow the path, or use the coordinates with a dividing head and dro.
if you want just a simple ellipse,  you could cut a suitable piece of tube at an angle then use the cut face as a guide.
  • Country: nz
« Reply #8 on: May 28, 2014, 05:12:55 AM »
Thanks Bill but how to handle backlash when the table changes direction? :scratch:
I have been wondering if there is any established technique that moves the lathe top slide back and forth (that is with the top slide turned parallel to the spindle)?
« Reply #9 on: May 28, 2014, 05:26:45 AM »
backlash isn't too much of a problem if stepping and plunging on a mill.
you might be able to turn the groove , albeit slowly , if you mounted the cut tube  on an arbour with the work piece and arranged a spring loaded cam follower on the topslide (you would have to remove the leadscrew)
you may find inspiration if you look at spiral oil groove cutting techniques on the web :)
  • Country: nz
« Reply #10 on: May 28, 2014, 06:00:25 AM »
Oil groove!  Good reference Bill as it seems a lot of people have made weird and wonderful methods of cutting the figure eight grooves!
