The Shop > Tools
Vertex mini vice?
ketanswali:
Both
Manxmodder:
Just to add to this which vice thread,I purchased a 70mm type 2 toolmakers vice from arc a couple of days back and I have to say the quality and precision of this vice is superb. http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
.....OZ.
Phody:
Hello, I purchased a pair from ACR EURO and for the money they have been good value. I wanted them as a matched pair so I could have two clamped to the milling machine at the same time. When I clamped them to a precision parallel 25mm by 30mm cross section I noticed one was low by .03mm. So took them to the club and skimmed the bases to the same size on the surface grinder. They are now spot on. No complaint with Arc Euro. I have seen the same quality at double or triple the price. Mine are the ones with just hole and no side clamping grooves. Made two alloy buttons so I could clamp via the centre hole/slot and not mark the ground slides. I bit of time on the milling machine and two clamps were made that hold down on the vice bed sides.
Good luck Phody
PS get the ones with the spring fitted to the jaw clamping bolt, if they suit your purpose.
PPS A 'T' handled 'hex' wrench makes tightening a pleasant operation.
Manxmodder:
Phody,the type I have is the spring loaded model,and I'm already there with the T handle hex key :thumbup:
To date I have been more than happy with the quality of all my tool purchases from arc.....OZ.
Arbalist:
I'm a great fan of the T handle hex wrench and find the extra long ones very useful, also the ball type when access is difficult.
My favourite brand is Bondhus.
Let's see you clamping buttons when you get a minute Phody.
Navigation
[0] Message Index
[*] Previous page
Go to full version
