Extending the cross slide travel on a 7 x 12 mini lathe
<< < (3/3)
cedge:
David
Seems like a lot of work to reach around one's thumb to touch one's elbow...(grin). The mod has been successful untold numbers of times. Reinventing the wheel seems a little like a lot of work only to get unproven results.
Twinsquirrel:
Noted Steve, I have ordered a new screw but in the meantime I may have a go with my original idea as I can easily change tack if it all goes south.
I guess Im just a rebel without a clue  :hammer:
David
winklmj:
So how'd it go with this mod. I've started a similar mod this weekend. I'll be adding a ball-bearing as well similar to the mod on GadgetBuilder's site.
Sorekiwi:
Its been 4 or 5 years since I did this same mod on mine, so the details are a little "fuzzy".  But I think I left the leadscrew in its origional location, and turned up an extension for the unthreaded end of the screw.  I also added a ball bearing in the extension spacer.
I could go out to the shed and look at the lathe, but its cold and raining tonight, and I think there are monsters out there...
andyf:
There's another, very similar, recipe for extending the cross-slide travel on here:
http://mikesworkshop.weebly.com/cross-slide-extended-travel.html
by Mike Cox, who had the idea for the swing-up toolholder for threading. At the end, he reckons it could have been done without milling out the slide. There's a mod for extending the top-slide travel on there, too.
Mike has only just started his site, but it will be worth keeping an eye on it if you are into improving your mini-lathe; I know there are things like a T-slotted cross-slide to come.
Navigation
[0] Message Index
[*] Previous page
Go to full version
