Gallery, Projects and General > How do I??
How do i go about choosing the correct chuck
mechman48:
Hi Kev
It looks to me that your machine is that which Machine Mart sell as the Clarke CL500M combi? in which case they sell a 4 jaw chuck to suit as an optional extra, I know as I had the same machine prior to my changing. A good solid machine for beginners (usual disclaimer), if you have the funds buy the chuck from them so no need to faff on with back plate machining & drilling.
George
John Rudd:
Kevin,
It may well be that if the register diameter is a standard/preferred size then Machinemart may not be the only option......if you remove your existing chuck and measure the recess diameter it may be the same size as a standard "recessed " chuck....For instance a typical 125mm chuck may grace an internal reg diameter of 95mm
piper1:
--- Quote from: John Rudd on January 26, 2014, 04:13:02 PM ---Kevin,
--- End quote ---
Thanks John I was thinking about taking my chuck to Machine mart and trying it out for size, but I do know that their 4 jaw chuck is a bit expensive.
Thanks
Kev
Jonny:
£180 Machine Mart but you know you will have no messing about and a direct fit.
Remove 3 jaw and measure the register.
Measure best you can the pcd for the four fixing bolts.
If 95 pcd think I have found a good buy from Rotagrip far better quality http://www.ebay.co.uk/itm/Vertex-160mm-4-Jaw-Independent-Lathe-Chuck-/360828915829?pt=UK_Home_Garden_PowerTools_SM&hash=item5403145075
Need a direct fit on to the register since you wont be able to machine to fit the chuck unlike L00, L0 and D series fittings where better to machine the back plate to fit the chuck.
piper1:
--- Quote from: Jonny on January 27, 2014, 01:11:57 PM ---£180 Machine Mart but you know you will have no messing about and a direct fit.
--- End quote ---
Thanks for the great info Jonny.
£180 does sound a lot of money but I just might get lucky one day searching around on ebay.
Navigation
[0] Message Index
[*] Previous page
Go to full version
