Author Topic: Pressure inside a small LPG gas cannister?  (Read 10875 times)
Offline mhh
  • Country: dk
« on: January 14, 2014, 11:34:13 AM »
Hi!
I'm sitting here with a small 0.5kg gas cannister and wondering about how much pressure there is in at 21°?
Is there anyone in here that knows anything about this?
Another question is... How much pressure is it save to put in it?
Any help is welcome!
Re: Pressure inside a small LPG gas cannister?
« Reply #1 on: January 14, 2014, 11:43:04 AM »
Couple of bits of info missing here....
What gas is it?
Propane gas a different vapour pressure to butane...
What is the canister made from.....?
The canister has a vour space in it too, so you cannot completely fill it....
Offline bcassel
« Reply #2 on: January 14, 2014, 11:43:42 AM »
Well, propane converts from liquid state to gaseous at 8.17 bar, or 118 psi.  So, if there is any liquid in the tank, it must be at 118 psi in the tank to keep it in a liquid state.
Offline mhh
  • Country: dk
« Reply #3 on: January 14, 2014, 11:49:09 AM »
What gas is it?
It is butane/propane mix
I think the canister is made of thin steel..... How does this affect the pressure?
Offline mhh
  • Country: dk
« Reply #4 on: January 14, 2014, 11:52:24 AM »
Oh! Well that makes sense! I think that is all the answer I need!
Thank you!
« Reply #5 on: January 14, 2014, 12:59:48 PM »
Presumably temperature affects the pressure at which the liquid / gaseous states co-exist? Is that at a nominal 20 deg C or what ?
Andrew
Offline bcassel
« Reply #6 on: January 15, 2014, 12:27:50 AM »
Vapor pressure (at 21 °C or 70 °F) : 8.587 bar
Offline Arbalist
« Reply #7 on: January 15, 2014, 06:00:29 AM »
Good man!  :thumbup:
Offline 75Plus
« Reply #8 on: January 15, 2014, 10:55:16 AM »
