Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
Gallery, Projects and General
Project Logs
Taper attachment for mini lathe
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Taper attachment for mini lathe (Read 18249 times)
mfletch
Jr. Member
on:
January 14, 2014, 09:06:38 AM »
Made this for the mini lathe
used 3 roller skate bearings
Its a brass guide
The adjustment side Im going to put a scale on later
Adjustable connecting bar to the cross slide
Hope you enjoyed the pics
Logged
Hero Member
Re: Taper attachment for mini lathe
Reply #1 on:
January 14, 2014, 09:46:57 AM »
Hi there, Mfletch,
I like that - very 'andy 'arry!!
Well done.
Logged
awemawson
Global Moderator
Hero Member
East Sussex, UK
Reply #2 on:
January 14, 2014, 09:53:05 AM »
Very cunning
I hope that your kids don't miss the skate board bearings
Andrew
Logged
Fredbare
Full Member
Fakenham, Norfolk
Reply #3 on:
January 14, 2014, 03:33:49 PM »
Great, thanks for sharing.
Logged
Stilldrillin
Global Moderator
Hero Member
Reply #4 on:
January 14, 2014, 05:53:34 PM »
Ooooh. I like
that
Nicely done. And shown......
Logged
mfletch
Jr. Member
Reply #5 on:
January 15, 2014, 02:33:48 AM »
Thanks guys it's made a usefull accessory for the lathe
Logged
mechman48
Sr. Member
Reply #6 on:
January 15, 2014, 07:46:10 AM »
Nice job.. can you enlighten us as to how you allowed the cross slide to move freely, I assume that you disconnected the cross slide from its lead screw to allow free front to back movement (Y axis)..
Regards
George
Logged
George.
mfletch
Jr. Member
Reply #7 on:
January 15, 2014, 09:12:47 AM »
Yes I removed the cross slide nut it's only held on with a allen screw
No need to remove the cross slide just wind it to its limit out of the nut then undo the allen screw
Last Edit: January 15, 2014, 12:14:04 PM by mfletch
Logged
krv3000
Hero Member
Reply #8 on:
January 15, 2014, 03:20:01 PM »
well dun
Logged
dawesy
Sr. Member
Reply #9 on:
January 16, 2014, 04:34:29 AM »
Looks great. Might have to have a go at that myself.
Logged
Lee.
wishing my workshop was larger
Meldonmech
Hero Member
Reply #10 on:
January 19, 2014, 02:29:28 PM »
Hi fletch
Nice to see you contributing to the forum, a neat and simple solution, involving little cost.
Logged
Brass_Machine
Administrator
Hero Member
Reply #11 on:
January 19, 2014, 08:01:36 PM »
Nicely done! I like that.
Logged
Yorkshireman
Jr. Member
Reply #12 on:
January 20, 2014, 04:55:26 AM »
Hallo mfletch
Could you please tell us how you made the triangular holder for the bearings, getting it 'right' without any slack or tightness?
Thanks
Johannes
Logged
mfletch
Jr. Member
Reply #13 on:
January 20, 2014, 06:55:43 AM »
It just happened to be like that don't know what it was off but it's not hard to make one it can be round square any shape just do 2 bearings first then put the bar you want to use up to the 2 bearings slide the third bearing up to the other side of the bar in between the other two bearings and mark the hole make this hole slightly bigger and this gives you the adjustment to take out any slack
Logged
Print
Pages: [
1
Go Up
« previous
next »
Project Logs
