Gallery, Projects and General > The Design Shop
Keeping the head from turning on a cheap mill
CrazyModder:
I fixed it, and it was dead simple: I just had to strip off the paint under the bolt head at the base. Obviously, the extremely thick layer of primer+paint would compress and thus loosen up ever so slightly under extreme circumstances. Since sanding the base completely clean there, I have not managed to turn the head during milling.
Arbalist:
Pleased you've got it sorted! :thumbup:
superc:
Hi. I would give some consideration to filling the hollow column with epoxy and sand, then drilling the column for the cross pin.
CrazyModder:
Nah, the column is massive steel, I replaced the stock one before even starting it up once. ;)
velocette:
Lots of ways to fix the problem posted here so I will add one more. Replace the clamp bolt for a one with a finer pitch thread this will give more closing pressure for the same amount of torque.
The roller thrust bearing under the nut is a good addition.
Keep the column clean
Navigation
[0] Message Index
[*] Previous page
Go to full version
