Author Topic: Plasma Cutter  (Read 31708 times)
Plasma Cutter
« on: December 01, 2013, 05:33:14 PM »
Lads
Got a new toy to play with
Re: Plasma Cutter
« Reply #1 on: December 02, 2013, 07:53:23 AM »
I can't watch the video right now as I'm on a client site - but they are rather brilliant things, aren't they?
I bought an old transformer based Cebora (partly because I don't trust this newfangled Chinese inverter stuff, and partly just because I like the heavy duty), it's brilliant. Cuts 10mm steel like it wasn't there. Cuts aluminium too. Shame it deosn't cut wood, really, it'd be perfect if it did...
Offline trevoratxtal
Re: Plasma Cutter
« Reply #2 on: December 03, 2013, 03:11:46 AM »
Hello Doubleboost
They are great machines,BUT if not fitted with low air pressure cut out can cost a fortune.
If it has not got one fit one,
Same goes for an air dryer fitted on the air input. (From the clip would suggest is to small fit another in line.)
Only set the cutting current to just do the job, over current uses the electrodes quicker!
To cut non metals lay a sheet of metal on top up the current and try it.
To cut rod or tube make up a hand rotating chuck and keep the torch still, cuts much neater and to the centre.
Have fun
Trev
Re: Plasma Cutter
« Reply #3 on: December 03, 2013, 03:40:48 PM »
Mine has the low-air cutout, it has a regulator fitted to the back to keep the input pressure at the right place. No dryer though....
I only have two power settings: HIGH and HIGHER  :lol: I like the idea of the chuck...
Re: Plasma Cutter
« Reply #4 on: December 09, 2013, 02:43:33 PM »
well dun as per john :thumbup: :thumbup:
Re: Plasma Cutter
« Reply #5 on: December 13, 2013, 12:59:10 PM »
[ Invalid YouTube link ]
Re: Plasma Cutter
« Reply #6 on: December 13, 2013, 01:34:00 PM »
Another great video - hey I like that shade 5 face shield, who stock those then?
Andrew
Offline kayz1
Re: Plasma Cutter
« Reply #8 on: December 13, 2013, 04:18:31 PM »
Another great video John, thanks...you have just cut up what would be my whole months supply of metals :dremel: :clap:
  Lyn.
PS: John.. is the spindle assembly on the 626 easy to pull apart and refit?
Ta. Lyn.
Re: Plasma Cutter
« Reply #9 on: December 13, 2013, 04:30:03 PM »
Lyn
R-Tech supplied the metal that I cut up
The spindle is a straight forward job (I think I have some pictures )
The bearings in mine were very good but the grease was shite
Re: Plasma Cutter
« Reply #10 on: December 13, 2013, 05:20:11 PM »
Thanks for the link John, I've ordered the mask.
Andrew
Re: Plasma Cutter
« Reply #11 on: December 13, 2013, 07:17:49 PM »
John, don't go paying for that cutter . You've earned it ;)
(Honestly, i had more expensive freebies after reviewing them :D)
Another great video, i was particularly taken by your neighbour's long johns - must get me self a pair8-)
  • Country: za
Re: Plasma Cutter
« Reply #12 on: December 13, 2013, 08:04:20 PM »
Andrew
Andrew,
You have ordered a mask from a company that states "doesn't post to South Africa" -seems a bit discriminant to me.  (Shame on you)
 :lol: :lol: :lol:
Offline S. Heslop
Re: Plasma Cutter
« Reply #13 on: December 13, 2013, 08:08:12 PM »
That thing does look handy. Especially with the circle cutter.
How would it fare cutting things with a non flat surface? Like castings or extrusions.
Oh by the way the video didn't turn up in my youtube feed. Maybe it's something wigging out on my end but you might've forgot to send it to subscribers.
Re: Plasma Cutter
« Reply #14 on: December 13, 2013, 09:36:21 PM »
I used mine to cut the rusty frozen nuts off a bunch of studs (hmm, now there's a sentence that could be misinterpreted  :bugeye:) that were holding a cast iron exhaust manifold on. Managed to do it with minimal damage to the manifold, although the plasma would cheerfully cut that I'm sure.
Re: Plasma Cutter
« Reply #15 on: December 14, 2013, 04:09:41 AM »
Andrew
Andrew,
 :lol: :lol: :lol:
Well just maybe they have their reasons  :lol:
Andrew
  • Country: za
Re: Plasma Cutter
« Reply #16 on: December 14, 2013, 07:13:18 AM »
Andrew
Andrew,
 :lol: :lol: :lol:
Andrew
Someone here must have upset them - it wasn't me  :lol:
Re: Plasma Cutter
« Reply #17 on: December 15, 2013, 04:06:51 AM »
Hi John
                        Very well presented, that is a very attractive piece of equipment, already beginning to covet it.
Offline Dawai
Re: Plasma Cutter
« Reply #18 on: December 31, 2013, 01:44:13 PM »
Neat. ,much more powerful than my $300 chinese one. CONSUMABLES thou are $40 for 250pc set for mine, was more before I put the CHEAP chinese torch on it. THE miller I had I could not afford them, I'd use a saw.
  TORCHES change out if you get tired of the "best ones" in yours and want to be cheap. it is either a 7 wire, or a 2 control wire torch.
Pattern cutting, 2'x2' barrel sized cutter table is perfect for a small shop, Mine started out as a torch. now a plasma pattern. Now on a roll-about table instead of a barrel to catch the sparks. (sparks and metal dust are on floor now)
I have a $100 cnc attachment for it drew up , will share when it works out into reality.
Adjustable Manual circles with swivel, ball bearing "drawer sliders for saw cuts". I used to clamp a ruler on the pattern arm and trace it.. I normally just drag cut beside a ruler if I am in a hurry..
https://www.youtube.com/watch?v=FsgmJW2uX7s The circle cutter in action with close up of radius adjustor.. a simple cantilever swivel, the most important thing is to have the torch center under the tracer center, have the whole shebang level so it stays the same height over the cutting table. Grate is just flooring from a mezzaline floor. A drop, left over piece.
BY the way, I have no respirator?? my iron content of my blood has been off the chart since I have been cutting with my plasma???? WTF??
Offline JD
  • Gosport Hampshire UK
Re: Plasma Cutter
« Reply #19 on: February 06, 2014, 04:52:06 PM »
I have been watching your videos with interest, this thread has come at the wright time.
I am about to buy a plasma cutter, just one question, have Plasma cutters with built in compressors got an advantage (apart form the obvious as having its own air supply) over the cutters without.
John W
Re: Plasma Cutter
« Reply #20 on: February 06, 2014, 05:45:28 PM »
You have hit the nail on the head
Having its own air supply makes it truly portable
This is the only possible advantage
Offline jb3cx
Re: Plasma Cutter
« Reply #21 on: February 06, 2014, 06:17:54 PM »
I think the other way to look at it is if you have a self contained unit  comp /plasma ,if one goes tits up
And has to be repaired,the whole unit has to go,so no comp /or plasma .
Worth thinking about !
Re: Plasma Cutter
« Reply #22 on: February 07, 2014, 02:13:53 AM »
ref "Plasma cutters with built in compressors"
Self contained compressor makes it portable.
My Son in Law a Lloyds Reg Welder was able to do work quickly and cleanly on large boats while afloat using the ships generators only.
He maintains the built in one are perfect for mobility, but prefers the more standard one for shop use.
Trev
Re: Plasma Cutter
« Reply #23 on: February 07, 2014, 04:47:14 AM »
Hi there, John,
That's a very impressive and useful machine.
Have you tried it on cast iron?
Offline Fredbare
  • Fakenham, Norfolk
Re: Plasma Cutter
« Reply #24 on: February 07, 2014, 04:52:59 PM »
Nice one John, keep em coming.
