Gallery, Projects and General > Gallery
A tap follower
PekkaNF:
Thank you. I got it.
I made one bit like that in stone age. But much more crude and ad-hoc. I just drilled and reamed hole at the nose of MT3 blanco and plonkked a spring and a centre made out of silver steel. It is rather long to reduce tendency of the centre to fall off. Hmmm.. thinkking of it maybe I should make another centre with a dimple.
awemawson:
Mine was even cruder - just a pointed rod in the Bridgeport chuck kept in place by downwards pressure on the quill feed arm, but now I tend to loosely grip in a chuck and start the tap by hand turning. (or power tap if the tap is stout enough)
Andrew
Meldonmech:
I have a set of tap wrenches made by Eclipse, they grip the tap in a chuck, and have a center hole in the other to locate with a center.
Arbalist:
These are mine. I made the top two, one male one female as some small Taps have a point on the end. I bought the one at the bottom but had to remake the internals as it was such a poor fit! I think I made it reversible, one end male, one female.
ksor:
Oh, really nice Work you have done ! :bow: :bow: :bow: :bow:
Navigation
[0] Message Index
[*] Previous page
Go to full version
