Gallery, Projects and General > How to's
Best way to clamp and cut this?
philf:
Darren,
Bob's suggestion is good but as he says you need to machine the ends very parallel and you need a very good vice where the moving jaw doesn't lift when tightened.
If you can angle the vertical head or your vice you could try either of the following:
DarrenUK:
--- Quote from: philf on November 14, 2013, 03:57:24 PM ---Darren,
--- End quote ---
Thanks Phil, that looks the way to go for me. I think I will give that a try.
DarrenUK:
Thanks all for the suggestions.
Mike K:
If it's only 70mm long, can't it be clamped in the vise with the ends against the jaws? Seems like that would be a better grip.
tekfab:
Why don't you just clamp it on the table using the t slot to locate it and either add a clamp at a machined place then remove the clamp at the area still to be machined that way it shouldn't move/rotate while you continue your machining operation.
Mike.
Navigation
[0] Message Index
[*] Previous page
Go to full version
