Author Topic: How do i achieve this?  (Read 34841 times)
Offline piper1
« on: November 14, 2013, 03:07:54 PM »
Hi hope some can help me out please.
Over the past few weeks i have been making some drip tips, but because of the limited amount of knowledge i have on a metal lathe they all appear to be similar in shape .
I was wanting to know how is it possible to achieve tapered and bevelled shapes by using a lathe.
The first picture show's a couple of drip tip that I have made.
second picture show's some of the shapes I would like to achieve.
Offline S. Heslop
Re: How do i achieve this?
« Reply #1 on: November 14, 2013, 03:16:27 PM »
There's several ways I know of. But the easiest would probably be to just file them on the lathe.
Make sure you read up on it so you do it safely though. Using a file without a handle or getting a sleeve snagged on the chuck could do a real number on you.
http://www.youtube.com/watch?v=ZqFFRjzeNuo
« Reply #2 on: November 14, 2013, 03:19:19 PM »
You either need to grind a form tool or have a cnc lathe
Andrew
ps you could just buy them here:
http://www.cloud9vaping.co.uk/epages/yxve46fvrnud.sf/en_GB/?ObjectPath=/Shops/yxve46fvrnud/Categories/DripTips/CherryVape
Offline piper1
« Reply #3 on: November 14, 2013, 04:19:20 PM »
Thank you for the safety tip.
Offline piper1
« Reply #4 on: November 14, 2013, 04:20:39 PM »
Andrew
lol I know but I do enjoy making them.
« Reply #5 on: November 14, 2013, 04:45:18 PM »
Hi there,
Please do tell - what's a 'drip tip'?
« Reply #6 on: November 14, 2013, 04:57:01 PM »
Hi there,
Your not alone, I'm curious as well.  :scratch:
« Reply #7 on: November 14, 2013, 05:04:50 PM »
I >>>think<<<< it's something to do with those 'electronic' cigarette nicotine inhalers from a bit of googling.
Andrew
« Reply #8 on: November 14, 2013, 05:23:06 PM »
Andrew
Andrew
You mean they tried to kill me with real cigarettes and after 50 years that hasn't worked (yet) now they want to try and use electronic cigarettes to finish the job. Those dam cigarette companies just never quit trying to get our money and kill us off.
Offline S. Heslop
« Reply #9 on: November 14, 2013, 05:55:57 PM »
Never mind. I just asked the guy becuase I wasn't so sure and I think I was mistaking it for something else.
« Reply #10 on: November 14, 2013, 08:16:47 PM »
Yup. They are used for E-cigs. Not the kind you buy all pre-made... more for the advanced e-cig user. It allows you to "drip" you nicotine liquid into your e-cig without having to basically take it apart.
I made a bunch for my nephew when he tried to break out into to vaping (smoking e-cigs) business.
Just make sure you are using stainless steel.
As far as shapes? Try using a ball turning attachment on the lathe...
« Reply #11 on: November 15, 2013, 04:47:06 AM »
Yup. They are used for E-cigs.   SNIP
Oh, and there I was thinking they were something to do with the bagpipes!   :Doh:   :Doh:   :Doh:
Offline piper1
« Reply #12 on: November 15, 2013, 12:24:22 PM »
I wish I could make a decent set of pipe.
Yes the drip tips are for electronic cigarette but not just the normal ones.
« Reply #13 on: November 15, 2013, 12:42:47 PM »
You could file up a form tool from sheet metal and make a basic follower mechanism for the cross-slide. Use the compound slide to advance the tool.
Offline piper1
« Reply #14 on: November 15, 2013, 01:57:04 PM »
Thank you for the reply Pete, I've just tried to goggle a  "follower mechanism" but I could find anything, would you be able to point me in the right direction please.
« Reply #15 on: November 15, 2013, 03:08:35 PM »
Use the term 'tracer attachment', you'll find what you want.
Offline piper1
« Reply #16 on: November 15, 2013, 04:07:28 PM »
Thank you.
Offline unc1esteve
« Reply #17 on: November 15, 2013, 07:51:42 PM »
You could set up to do it free hand like a wood lathe.
I think tubal cain has a video of that.
Offline S. Heslop
« Reply #18 on: November 15, 2013, 08:38:03 PM »
Do you intend to produce many of these to close tolerances? Since they're mostly decorative you could just rough out the majority of the material with plunge cuts and a parting tool, then smooth the steps with a file and emery tape. If you need to keep close enough to a plan for some reason you could figure out how far to plunge each step.
Here's a shoddy representation.
Although the way i'd do them would just be to cut the bulk material free hand with the carriage and crosslide handwheel and file it smooth.
I know there's a great temptation to try do everything in clever and overly technical ways, but it's just not worth it for these one-off jobs. Keep it simple.
Offline piper1
« Reply #19 on: November 16, 2013, 11:38:24 AM »
Thank you for the reply.
I only intend to make them as one offs.
The diagram and instructions look pretty easy for me to understand and follow so I'm going to have a bash in the morning.
Offline piper1
« Reply #20 on: November 16, 2013, 11:40:27 AM »
Thank you.
I couldn't find any video on tubal cain.
Offline S. Heslop
« Reply #21 on: November 16, 2013, 12:30:44 PM »
Thank you.
http://www.youtube.com/user/mrpete222/videos
Here's his video chanel. Well worth checking out.
Offline DaveH
  • Kempton Park, South Africa
« Reply #22 on: November 16, 2013, 12:34:23 PM »
Piper,
Those forms can be quite easily achieved on a lathe, you will however need a 'radius turner' to make things easy.
Have a look at 'Divided he ads' (Ralph) posts.
Here's one to start
http://madmodder.net/index.php/topic,8423.msg90636.html#msg90636
Offline piper1
« Reply #23 on: November 16, 2013, 04:55:02 PM »
Thank you.
Amazing thank you
Offline piper1
« Reply #24 on: November 16, 2013, 04:58:06 PM »
Piper,
Here's one to start
is this a devise that can be purchased or do you have to build one to fit your own lathe? sorry for the dumb questions.
Kev
