Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
Gallery, Projects and General
Project Logs
ball turner for a compact 8
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ball turner for a compact 8 (Read 18866 times)
krv3000
Hero Member
on:
October 14, 2013, 06:30:54 PM »
hi all well i have seen Meany different types of ball turner so i decided to mack one for me lathe the base plat is 12mm by 80 by 250 i marked off the center and drilled 10.1mm then countersunk to tack a m10 countersunk bolt i then had a rut for a Bering i will post the No of it its a double shielded Bering most of the ones that i have looked at just pivot on a center pin or on the base itself did not like that so mine is getting mounted on a Bering i made a retainer to hold the Bering to the plat then started work on the tool holder bit got a lump of rusty bar by it time i had cleaned it up it ended up being 48mm OD i drilled out the bottom 17mm deep then started to bore the base out it will have to be steeped 12mm deep for the Bering and 4.5 mm for the Bering retainer once this was dun i did sum simple dividing marked the out side with felt Pen went in 6mm from the bottom edge and put a line all the way round then with a Peace of plastic under one of the jaws of the chuck scribed a line a cores the center line then moved the plastic and turned the chuck to the next jaw and put the plastic back under and scribed a Cross the center linen so i ended up with 4 divisions equal spaced then thees where drilled and tap for m3 grub screws then sawed the top off right pics
Logged
micktoon
Hero Member
Re: ball turner for a compact 8
Reply #1 on:
October 14, 2013, 07:06:56 PM »
Looking good Bob, you have been a busy lad
I look forward to seeing the project progress and the first ball come off the production line
Cheers Mick.
Logged
vtsteam
Global Moderator
Hero Member
Republic of Vermont
Reply #2 on:
October 14, 2013, 08:24:50 PM »
This is cool!
Logged
mattinker
Hero Member
Reply #3 on:
October 15, 2013, 12:51:07 AM »
Hey, good stuff, as a fellow compact 8 owner I'll be following this closely!
Logged
krv3000
Hero Member
Reply #4 on:
October 17, 2013, 04:32:30 PM »
hi well i did a bit more i finisht of the top then i cheated i gave the part to the other grand dad as he has a mill to mill the slot for me and drill the holes for the grub screws which i taped out to m5 then i cut the bottom plate dawn to 100mm which is the same with as the Cross slide then went over the top of the plate with me belt sander then i marked off the plate for the fixing bolts drilled them out to 6.2mm then i made up 4 t nuts i have sum m6 sqer nuts that fit in the t slots i silver soldered them to lengths of m6 stainless steel studding that i had kept of cutting m6 bolts dawn i put the holder back on to the plat and checked all was OK then i removed me chuck and fitted a mt sleeve 3 to a 2 to fit me 2 mt center which is tipped i have a 3 mt center but this wood not reach the tool holder i marked up the tool holder and fitted it in to its holder then with the tip of the center i marked the height of the tool holder then before cutting the extra length off i marked the top up for m2 cap heads and drilled 1.6mm then i cut that bit off then i cut just above the mack on the tool post then mounted back up in the 4 jaw chuck and machined the top dawn to the mack then glued the top on to a Peace of scrap then machined it dawn to 3mm thick right pics
Logged
micktoon
Hero Member
Reply #5 on:
October 17, 2013, 05:05:14 PM »
Quality work as usual Bob, its looking very nice
, I like the domed nuts too
, looking forward to seeing it make its first ball .
Cheers Mick
Logged
doubleboost
Madmodder Committee
Hero Member
Newcastle Upon Tyne
Reply #6 on:
October 17, 2013, 05:27:51 PM »
Looking nice Bob
It is nice to use a tool you have made
Logged
http://www.youtube.com/user/doubleboost
krv3000
Hero Member
Reply #7 on:
October 19, 2013, 05:22:19 PM »
hi all last bit i stuck on the top to the tool holder and spotted the holes for the m2 cap heads then tapped them once this was dun i mawnted me angel bracket to me Cross slide then clamp me tool holder to it for milling out of the 3mm slot by 2.5 mm deep for the cutting tool SOS no pics of that bit i then put the top back on and put a angel on the tool holder i then cut a length of the 3mm tool steel for the cutting tool and put a cutting face on it then i made the handle me handle goes on to the tool holder and not the rotating body as i cud see their may be a safety issue this handle ma be permanent or thrown in the bin a length of m6 threaded rod a dried up felt tip pen and a ball the inner diameter of the pen was bigger than 6mm and the ball had a m8 thread in so i mixed up sum epoxy glued the 6mm rod in to the ball and then put the remainder of the epoxy in to the pen which i left standing strata up once the epoxy had gone hard i drilled it out 6.1 then put it on to the rod then cut the threaded rod to length then fitted it and wile me first ball is not spot on i think its OK right pics
Logged
vtsteam
Global Moderator
Hero Member
Republic of Vermont
Reply #8 on:
October 19, 2013, 08:57:11 PM »
Logged
mattinker
Hero Member
Reply #9 on:
October 20, 2013, 05:50:11 AM »
Great stuff, it'll be on my list of things to do. Now you'll have to make a ball instead of the orange one!
Logged
tom osselton
Hero Member
Reply #10 on:
October 20, 2013, 03:35:55 PM »
Very nice ball turner I like how you hold the tooling I've been thinking how to put a square hole for a index marker I built.
Logged
Stilldrillin
Global Moderator
Hero Member
Reply #11 on:
October 20, 2013, 03:46:09 PM »
Very nicely done, and explained Bob!
Logged
micktoon
Hero Member
Reply #12 on:
October 20, 2013, 07:03:33 PM »
Turned out lovely Bob, looks like a classy bit of tooling and will do a good job too
, you should have a ball handle on everything in sight by the next time I visit
Cheers Mick.
Logged
Meldonmech
Hero Member
Reply #13 on:
October 26, 2013, 08:57:28 AM »
Hi Bob
Nice job, well made.
Logged
Arbalist
Hero Member
Reply #14 on:
October 27, 2013, 05:34:19 AM »
Nice one Bob.
This is my one, it also has a nice big bearing in the base. Sadly I don't have tee slots on my BV20 so I had to install four tapped holes to mount it. The first thing I did on it was to make it's own ball for the handle!
Logged
krv3000
Hero Member
Reply #15 on:
October 27, 2013, 08:28:39 PM »
thancs for the coments and a nice one to arbalist as predikted i will have to modyfy the handel on mine will do a post soon
Logged
Brass_Machine
Administrator
Hero Member
Reply #16 on:
October 27, 2013, 09:31:11 PM »
Gosh Bob... You make this look easy. I need to finish my ball turner...
Logged
Print
Pages: [
1
Go Up
« previous
next »
Project Logs
