Author Topic: colbolt drill stand  (Read 13910 times)
colbolt drill stand
« on: July 30, 2013, 08:00:19 PM »
hi all well i have a set of cobalt drills that go up in .5mm steps to 11.5 so rather than them laying in a tub i made this up today i have gone all the way up to 13mm don.t no where i got the aluminum angel from i cut 3 lengths of it 200mm long i then made two side panels divided the lengths up for the center of etch drill stuck it all together then started to No the drills IE 1 then 1.5 and so on but i run out of No 5s so i just cared on will go to wh smiths in the morning to get sum more right pics
Offline Chuck in E. TN
  • USAF Retired
Re: colbolt drill stand
« Reply #1 on: July 30, 2013, 08:03:33 PM »
Nice work!
Chuck
Chuck in E. TN
« Reply #2 on: July 30, 2013, 09:25:57 PM »
Great job! And easy to read and see where everything goes -- which is getting more important these days! Nice clean layout.
Another small job that makes a big impact. Keep em' coming!  :bow: :bow: :bow: :clap:
« Reply #3 on: July 30, 2013, 09:55:52 PM »
Bob
As always you do a fine job at making things to organize your tools. Thanks for sharing it with us.  :D :D
« Reply #4 on: July 30, 2013, 11:56:59 PM »
Nice!!
« Reply #5 on: July 31, 2013, 03:36:15 AM »
Spot on that!
« Reply #6 on: July 31, 2013, 06:20:20 AM »
Hi Bob,
                   That is a smart looking stand. Like the construction method using the angle, very clever.
« Reply #7 on: July 31, 2013, 04:00:19 PM »
  Hi Bob , nice job  :drool: :drool:, much better than having them in a pot and hunting through every time you need one  ( like me  :palm: ) , better markings than most proper stands too , you normally cannot see the sizes they are that small.
 Cheers Mick
« Reply #8 on: July 31, 2013, 04:06:52 PM »
Nice one Bob
I have been looking for a empty drill box for mine
« Reply #9 on: August 01, 2013, 07:41:45 PM »
Bob, how did you put the numbers on the ally?
Nice job anyways... :thumbup:
Offline mechman48
« Reply #10 on: August 02, 2013, 03:35:52 AM »
Nice job, looks good   :thumbup: I guess your numbers are self adhesive backed  from Smiths or Hobby craft sheets (no connection)?
George.
George.
« Reply #11 on: August 02, 2013, 12:48:51 PM »
hi all thancs for the coments the letering is from smiths as mechman48 sed ther dry transfer type you just rub them on but to mack them permanent you need to varnish over the top of them the key in useing them is prep i whent over the face with a cloth with thiners on to remove any oil and muck
