Author Topic: This is one way of pattern making i havent seen before.  (Read 11580 times)
Offline NeoTech
    • Roughedge Hobbyworks
« on: July 19, 2013, 05:40:34 AM »
Well he does a two part pattern the usual way.. The core box is quite ingenious as well instead of using plastic tubes and what nots.
The thing that differs is the use of a "match plate".. this i hadnt seen before. =)
[youtube]MeYNLUNk0E4[/youtube]
MetalCaster
Re: This is one way of pattern making i havent seen before.
« Reply #1 on: July 19, 2013, 11:48:26 AM »
That's a good tutorial on match plates.
Very handy if you want to make multiple copies of the same piece, but rather overkill for a one-off piece, where a loose pattern would work just as well.
Good to know how it is done.
I wondered about alignment on either side of the board.
« Reply #2 on: July 19, 2013, 02:34:37 PM »
One of mine.
Makes two per flask.  Definitely overkill for a one-off.
MetalCaster
« Reply #3 on: July 19, 2013, 02:42:50 PM »
I have seen some put the gates, runners, sprues, risers, etc. on the match plate.
« Reply #4 on: July 19, 2013, 02:59:39 PM »
Yep, But rather overkill in this case.
A lot harder to carve and finish gate patterns, to fit them to the crankcase patterns, to ram all the new nooks and crannies of the joints evenly against a hard backing, and then unmold without breaks... than the ten seconds it takes to cut a couple of gates in sand.
« Reply #5 on: July 19, 2013, 03:15:01 PM »
Apologies for tone.
« Reply #6 on: July 19, 2013, 03:56:37 PM »
Just an additional point of information -- sprues and risers would have to be pinned loose pieces in the above plate I show because they would probably only be useful in the cope. The plate is rammed up in both cope and drag. You could do the gates to one side only, but they will then appear in the cope on one casting and in the drag for the other, thought that isn't necessarily a problem. Or it could be a split pattern like the main pattern -- you'd have to make two matching pieces for each, and they would go to each side.
« Reply #7 on: July 19, 2013, 04:42:21 PM »
Here is a plate pattern I made VERY many years ago. Initially casting aluminium, but I have successfully cast brass and iron from the same pattern. Designed for a custom made wooden  flask, and done in CO2 / sodium silicate sand. I made up several at a time, sandwiched them between plywood boards, and clamped them up with studding. Obviously cast in a vertical orientation. It makes a copy of a Victorian 'Khasi Bracket' of the sort used to support high level toilet cisterns, but now used for shelves and all sorts. I've still got one supporting a large brass bell at my front door.
« Reply #8 on: July 19, 2013, 05:24:34 PM »
Beauiful, Andrew!
