The Breakroom > The Water Cooler
Compressed air motor to brushless generator ?
AdeV:
I'm curious to know why you'd want to do this?
Compressed air is "expensive" - you need a motor of some description to create it, then you need a strong tank to store it, and you're going to hook up a low efficiency air motor (which are a bit like Harleys - great at turning input energy into noise & not a lot else...)? Why have the compressed air in the middle, surely it'd be easier to simply take the motor off the compressor & use that to run the generator direct?
On the other hand, if this is some mad project, then.... :worthless: :nrocks:
kwackers:
Aren't alternators always brushless? (Coils on the casing)
picclock:
Hi Adev
Mad :loco: project fits the bill - but interesting if it works. If it does I'll post details, that way I won't have to hang my head in shame if it fails :med:.
Had another idea :smart: - must be the weather - If I squirt compressed air into my cheapo generator 4 stroke it will only power every other stroke, but if I change the cam reduction gear to make it 1:1 then it should have power every stroke - and it may be OK with the shorter valve opening times as the gas volumes will be lower but twice as often.
I'll have to think on it some more but it sounds like a sort of plan .. .
Other thing is, if it is going to cost me £200 for a delivered Clarke alternator and this petrol generator is £175 including IC engine then it seems like a no brainer, even if I can't get it to work with 4 stroke engine I am no worse off - just some time spent - which the government hasn't seen fit to tax yet !
Have some other inquiries out for air motors so I'll finally decide when I know the costs involved.
Best Regards
picclock
Hi kwackers - alternators normally have brushes to excite the rotating coil. Often mounted on the end of the alternator. They only carry low current, and by varying the current you can control the alternator output. Brushless ones are sneaky, they control the current in the centre winding by inducing it from another coil on the shaft.
John Rudd:
--- Quote from: kwackers on July 01, 2013, 10:14:58 AM ---Aren't alternators always brushless? (Coils on the casing)
--- End quote ---
Ermm no....The output usually comes for the stator, the static part, and the rotor is the excited magnetic field...The excitation voltage from the AVR is applied by brushes to the slip rings...
mattinker:
Picclock,
I'm curious as to why you want to drive an alternator with compressed air, it's going to take an awful lot of air! Do you have a big engine driven compressor? If so it would be far more efficient to run the generator from the compressor engine!
Navigation
[0] Message Index
[*] Previous page
Go to full version
