The Breakroom > The Water Cooler
When is half of 60 not half of 60 ?
<< < (8/8)
DavidA:
Phil,
Just had another look at your sketch.
I'm not so sure that it does clear things up.  Hate to keep on chewing at this old bone;  but here goes.
If you look at the sketch you will notice that the trailing edge of the cutter tip is inside the line of feed of the topslide. From this I would assume that you will still get some cutting action from this 'back edge' even though most of the work will be being done by the tip's leading edge.
Now.  if you were to rotate the topslide anti-clockwise another degree,  bringing the line of approach to 30 degrees (same as the angle of the tip) then the tip will cut only on the leading edge whilst rubbing the trailing edge against the previously cut thread .
If you take the angle around one more degree anti-clockwise,  to 31 degrees,  then only the leading edge will cut. You will have clearance at the  trailing edge;  which is what we want.  (I think).
The final straight in cut will restore the correct form.
What do you think ?
At the moment I am suffering my way through a nasty bout of some flue like symptoms and am barred from human contact. at least that is what my family say.  So I am trawling the web to keep myself occupied.
vtsteam:
It won't "rub" on the trailing edge at 30 degrees. It will clear it. If it didn't clear it, it would be cutting it with a light finishing cut.
Also there is no absolute need to take a final straight in cut at the end when cutting at 30 degrees or less. (for a 60 degree thread).
But if you try to cut at 31 degrees or more you will leave a stair step cut on the trailing edge, and then yes, you would definitely want to remove that with a final straight in cut.
When using angles of less than thirty degrees, the trailing edge gets a nice light finishing cut during each pass, while the leading edge does the bulk removal
DavidA:
VT,
Pretty much as I thought. Maybe the use of 'rub' was not a good choice of words. I should have said parallel with the last cut.
But I think we more or less agree overall.
Now I can discard this bone; and perhaps move on to juicier ones.
philf:
--- Quote from: DavidA on October 03, 2013, 07:11:57 AM ---Phil,
What do you think ?
--- End quote ---
Hi David,
As you say at 30 degrees you are right in that the trailing edge won't remove any material - however a fraction of a degree more than 30 degrees will produce a staircase effect. The protractors on compound slides aren't usually that precise. If you think you've set it at 30 degrees you may well have 30.5 degrees and you'll never get a true 60 degree thread. Setting it at 29 degrees should make sure that you don't have this problem.
I've revamped a previous sketch to show external screwcutting with 29 degree and greater than 30 degree compound slide settings. (The angles are exaggerated to show the effects.)In the case of the 31 degree compound slide setting the green dotted line shows the ideal thread flank.) Making the last cut only with the cross slide would clean up the thread correctly but it would have to be a big cut in this case to remove the staircase effect.
I really hope that this finally makes it clear. (Especially as I don't bother with this method!)
DavidA:
Phil,
All clear now.
I also don't normaly use this method. So the whole exercise was pretty theoretical.  I would probably use it for,say, eight tpi and less.
So,  let's move on.
Those sketches of yours are pretty good.
Navigation
[0] Message Index
[*] Previous page
Go to full version
