Author Topic: Thoughts about making ladles  (Read 37144 times)
« on: June 06, 2013, 08:35:16 PM »
Cupolas normally use ladles instead of crucibles.  The ladle is often a metal pot with a ladle wash of refractory to protect it. I thought I'd open this thread to get feedback and ideas on making them.
I'll probably just put down some random thoughts here. Feel free to join in on the topic.
I've found that when I made a crucible out of 4" diameter  iron pipe for melting aluminum that it wasn't easy to pour with compared to some other shaped crucibles I have.
A straight narrow cylinder seems to pour all at once rather than gradually like a "bilge" shape in a conventional crucible.
I think the same thing would happen with a ladle made from 4" pipe. Or maybe worse. Because you have to line it, which effectively makes it even narrower and proportionately taller for its volume.
Another problem with a pipe crucible is that to fully empty it you have to tilt it at a greater angle. At least it seemed that way to me. The greater the angle, the further away from the sprue hole it needs to be held.
Since the flow varies as you pour you have to move it horizontally to adjust for the change. All in all it tends to make for more misses and miss-pours than a bilge or tapered cone shape.
Re: Thoughts about making ladles
« Reply #1 on: June 06, 2013, 08:43:44 PM »
It seems to me that crucible proportions have been worked out over time to ease pouring and accuracy.
So I think a ladle shaped with a bilge, along crucible proportions might be something to try to make.
Well one way to make that would be to pour it. But since I can't do that yet, I was thinking about maybe trying to weld one up.
Would it be possible to make one with dart shapes welded together?
I have some 11 ga. (approx 1/8") sheet that I could jigsaw into the dart shapes -- maybe joined at the widest part, and then maybe weld those together to get a good approximation.
« Reply #2 on: June 06, 2013, 08:47:23 PM »
Another thought is the teapot type of ladle.
These look like a watering can with the spout tight to the main body. Their advantage is that they are self skimming. So they would make pouring easier for a one man operation.
The problem with them as I see it is, how do you line it?
Particularly the part where the spout joins the main part. I'm guessing that the lining should be about 1/2" thick.
« Reply #3 on: June 06, 2013, 08:50:05 PM »
In my case a teapot would be rather small, which might make lining even harder or even impossible.
Here's a big one!
« Reply #4 on: June 06, 2013, 09:16:57 PM »
Right now I'm thinking about ladles to hold about 10 pounds of iron.
Probably good to figure out how much volume that actually is.
491 lbs/cuft
so
10/491 = .02 cuft or 34.5 cu in. (or 566 cc)
Let's see how tall a 4" dia pipe that would require:
4 * PI * h = 34.5
h = 34.5/ (4* PI) = 2-3/4"
Wow! That's not much -- is that right?
So a 4 inch deep piece of 4" diameter pipe would easily hold 10 lbs?
« Reply #5 on: June 06, 2013, 09:22:17 PM »
Okay, suppose I did use a piece of pipe, I would have to subtract the thickness of the lining to get the true capacity.
So assuming the lining is 1/2 " thick, then the diameter is really 3" so we get:
34.5/ (2.25 * Pi) = 4.88",  say 5"
So you'd want a 6" piece at least.
« Reply #6 on: June 06, 2013, 09:37:02 PM »
I have a couple of A6 crucibles -- not strictly speaking "bilge" type, but shaped better than a straight pipe.
Dimensions are:
6 1/8" tall x 4 5/8" top diameter x 3 3/8" bottom diameter.
This is supposed to handle about 13.2 pounds of brass. Not sure how much iron. Well, I could figure that out. Let's see...
535 lbs/cuft brass, 442 lbs/cuft for grey iron (hey, that's different than what I found online earlier 491 lbs cuft....? Oh well..)
442/535 * 13.2 = 10.9 lbs, okay say 11 lbs, so A6 is about right for my furnace assuming a 10 lb charge.
Okay.
So say an A6 crucible is about 1/2" thick -- that's about what a steel ladle imitation of that shape should be with an allowance for the lining thickness.
So I could use the A6 crucible as a model for making a steel ladle.
« Reply #7 on: June 06, 2013, 09:51:19 PM »
I was trying to find proportions for B4 crucibles -- these are about the same capacity as the a6, but with a true bilge. Unfortunately I can only find the bilge dimensions for larger sizes. The bilge dimension is the widest part.
Well I guess I could interpolate that from the larger sizes. Just get a typical proportion of the top diameter for the bilge.
Okay, a B10 crucible has a top diameter of 6/14"  and it has a bilge diameter of 6-5/8".
So the proportion is 1.06.  The bilge is 106% of the top diameter.
Okay going back to my A6 dimensions, the top was 4-5/8". That means if I want a "classical" bilge, it should be about:
4.625" * 106% = 4.9",  or about 4-7/8"
« Reply #8 on: June 06, 2013, 09:56:13 PM »
Okay, so I've got 4 dimensions for my bilge shaped ladle to handle 10 lbs or so of iron:
Height = 6-1/8"
Top diameter = 4-5/8"
Bilge diameter = 4-7/8"
Bottom diameter = 3-3/8"
Is that right?
« Reply #9 on: June 07, 2013, 01:09:57 PM »
Since it's raining. I'm just playing around with an older free version of Google SketchUp making crucible patterns. Here's a real simple one -- just two rings, but it does give the bilge shape and has a pouring spout. If you made this, it would actually turn out round rather than faceted into an octagon, though you would see the join line as a hard edge between the two rings.
However internally, it would be smooth since you would line it with 1/2" of clay refractory, and could round the corner out.
This is the same size as the A6 (with bilge added) from the dimensions in  the last post.
I might actually try making this.
ps. I'm not a SketchUp expert -- this is as much a learning exercise as anything else.
« Last Edit: January 12, 2018, 09:50:00 PM by vtsteam »
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #10 on: June 07, 2013, 03:44:37 PM »
why not make a rudimentary "one shot" crucible out of clay and the first thing you cast is a laddle?? =)
« Reply #11 on: June 07, 2013, 04:55:34 PM »
A "bilged" ladle is not the easiest thing to cast actually, thin wall, needs a core, and is compound curved. Not the best first iron casting project. And I wouldn't trust a pure clay ladle I made, though I could easily use a metal pot or pail or steel pipe ladle, lined with clay refractory mix in its place.
But more importantly, like the question, "Why would you build a lathe when you can buy one," I might think about trying to make a shaped ladle this way because I'm simply curious and interested in it, enjoy practicing with SketchUp, and because it is going to be raining continuously for 2 days.
 :D
« Reply #12 on: June 07, 2013, 07:50:07 PM »
Offline NeoTech
« Reply #13 on: June 08, 2013, 06:00:01 AM »
Well u build a lathe coz its fun making tools and machinery. And buying them is either expensive or chinese rebranded crap. :)
« Reply #14 on: June 08, 2013, 10:04:17 AM »
Here's a pattern for making the ladle -- I've made it so it will print out on A4 paper for others here. I'm labeling it a B4 because it is similar to the size of  B4 crucible (or A6 with a bilge added).
« Reply #15 on: June 08, 2013, 05:34:30 PM »
Print out and, tape sheets together, and cut them out with scissors:
« Last Edit: January 12, 2018, 09:51:41 PM by vtsteam »
« Reply #16 on: June 08, 2013, 05:36:08 PM »
I glued them to some aluminum sheet and cut them out with tin snips to make patterns. I'm sure i'll make more than one, so patterns are handy to have:
« Last Edit: January 12, 2018, 09:52:16 PM by vtsteam »
« Reply #17 on: June 08, 2013, 05:39:09 PM »
Then I used the patterns to mark out some 1/8" plate I had. The plate was cut out with a portable reciprocating Bosch jigsaw, which, with a bimetal blade makes short work of this stuff. Frankly,  faster than a bandsaw, and a lot easier to maneuver on a big sheet of material.
« Last Edit: January 12, 2018, 09:52:51 PM by vtsteam »
« Reply #18 on: June 08, 2013, 05:41:01 PM »
A little bending, a little cussing, a littl hammering, a little welding, not to mention some grinding and....
« Last Edit: January 12, 2018, 09:53:28 PM by vtsteam »
« Reply #19 on: June 08, 2013, 05:44:37 PM »
An enjoyable little job by the time it was done. I'm impressed with the unfold tool add-on to SketchUp. The pieces fit together perfectly:
« Last Edit: January 12, 2018, 09:54:12 PM by vtsteam »
« Reply #20 on: June 09, 2013, 03:20:09 AM »
 :clap: :clap: :clap: :clap:  Very nice Steve  :thumbup:
Offline NeoTech
« Reply #21 on: June 09, 2013, 03:22:29 AM »
That looks brilliant. :)
« Reply #22 on: June 09, 2013, 05:12:16 AM »
Very clever
 :thumbup: :thumbup: :thumbup: :thumbup:
« Reply #23 on: June 09, 2013, 05:30:34 PM »
Well done , the unfold tool looks like it would be handy to have , thanks for posting  :thumbup:
Cheers Mick.
« Reply #24 on: June 09, 2013, 06:40:21 PM »
Rob, Neo, Double, Mick thanks!
The unfold tool is by Jim Folz and is available here:
http://sketchuptips.blogspot.com/2007/08/plugin-unfoldrb.html
I use it with an older version of the free version of SketchUp (version 7.1). Along with tools for exporting DXF files and the PhlatBoyz CAM CNC Router output plugin, it makes free Sketcup a much more powerful tool.
For those who want to do similar things to the crucible design without using a CAD program, there is an online  program to generate the projected shape for cutting out cone sections from sheet metal here:
http://www.i-logic.com/conecalc.htm.
