Author Topic: Hard Core Three  (Read 14896 times)
Hard Core Three
« on: May 13, 2013, 06:22:45 PM »
Lads
More video
[youtube]http://www.youtube.com/watch?v=hZeC4W0jfgI&feature=youtu.be
[/youtube]
Re: Hard Core Three
« Reply #1 on: May 13, 2013, 07:32:56 PM »
 :thumbup:   I can empathise with the packing being in the way part way through a job.
« Last Edit: May 14, 2013, 12:15:06 PM by Joules »
Re: Hard Core Three
« Reply #2 on: May 13, 2013, 07:44:08 PM »
Another great watch, John. Only three expletives, which is pretty good considering you wanted a smoke.
How did you adjust the cutter in the boring bar between cuts, so it would gradually increase the hole diameter?
Re: Hard Core Three
« Reply #3 on: May 14, 2013, 06:29:42 AM »
Hi John,
            From time to time we all make little mistakes, but the important thing is how you resolve them, and this is a part of the learning process. In this video this is what you have shown.
        Well Done  Cheers David
Offline tekfab
Re: Hard Core Three
« Reply #4 on: May 14, 2013, 07:47:51 AM »
Another great video John. You show it as it is, warts an all !. If you ever fancy a hand building a Mk2 jet kart gimme a shout i've got some kit to hand.
Mike Young
Re: Hard Core Three
« Reply #5 on: May 14, 2013, 01:42:48 PM »
I should have shown that :Doh: :Doh: :Doh: :Doh:
I use a clock on the cutter and just push the tool  through the required amount
I need to make a proper adjuster
Re: Hard Core Three
« Reply #6 on: May 14, 2013, 03:09:09 PM »
No, John, I should have thought it out for myself :doh:
 I posted at 00.44 this morning; should have restrained myself until after a night's sleep.
Offline paulmo101
Re: Hard Core Three
« Reply #7 on: May 14, 2013, 03:36:47 PM »
Another great video, thanks John.
Did you make the boring bar - if so can you let me have the specs as it looks a good bit of kit?
Paul
Re: Hard Core Three
« Reply #8 on: May 14, 2013, 03:39:15 PM »
Paul
It is shown in the previous video
Re: Hard Core Three
« Reply #9 on: May 14, 2013, 06:21:57 PM »
well dun john all bin well i shud be dowing mine this week end
lordedmond
Re: Hard Core Three
« Reply #10 on: May 15, 2013, 02:53:57 AM »
when you were stuck with the gland face of the cylinder, could you not have pressed a boring head into service, or at last resort do as i have done in the past when faced with the same problem hold a lathe tool in the four jaw offset to the required rad.
after all its bot the whole face that is critical but only the bolting face.
A point for others its as well to mark the gland bolting face with a couple of discrete pop marks , just so do do not forget which it is  :bang:
the drill lip gauge sure brought back memories I was introduced to those when I started work as an elect apprentice in 1962 we used the lime wash to coat the up stand ( the guys that did the setting out on the marking out slab used it to coat the work to show up the scribe marks ect. )
great vid as always John I think I have pieced up a tip with all of your previous ones
Stuart
ps looking forwards to more
Re: Hard Core Three
« Reply #11 on: May 15, 2013, 05:46:43 AM »
Another quality video John  :thumbup: :clap: :clap: , keep them coming , everyone is waiting for the next episode!
Cheers Mick
Offline slowcoach
Re: Hard Core Three
« Reply #12 on: May 15, 2013, 03:59:31 PM »
Offline jim4472
  • Tadley, Hampshire, UK.
Re: Hard Core Three
« Reply #13 on: May 16, 2013, 07:07:56 PM »
Brilliant Videos  John .. keep em coming ..
how about a video on grinding up centre drills etc for boring bars angles etc.
Jim
Skype:- gb7iha
Offline paulmo101
Re: Hard Core Three
« Reply #14 on: May 17, 2013, 11:18:32 AM »
I would like to second Jims request for a video on grinding broken drills etc for the boring bar or fly cutting.
The videos are great john thnks for the time and effort in making them..
Paul
