Author Topic: Minnie TE Long term project  (Read 160698 times)
Re: Minnie TE Long term project
« Reply #175 on: October 28, 2015, 11:28:02 AM »
 :clap: :clap: :clap: :clap: Good to see you back one with this build Joe .
Cracking job as per  :thumbup:
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, sea cadets ,,,,,,,,,,,,,,,,,,,,,way too much salt water   :loco:
Offline Joe d
« Reply #176 on: October 28, 2015, 12:45:41 PM »
Well, about what I'd expect from a pongo.....
Glad to see you looking in, this whole thing really is mostly your fault....
Joe
« Reply #177 on: November 01, 2015, 01:47:25 PM »
 :lol: :lol:
Rob  :)
Offline Joe d
« Reply #178 on: November 02, 2015, 12:00:49 AM »
moving along, turned the cylinder covers, the front one is rather simple
The rear one is a bit more complex, as it has a stand-off flange for the piston-rod gland:  got carried away machining, so only a final
"as done" photo
Turned blanks for the valve and regulator glands
Spent some time fly-cutting some brass to dimension for the valve chest and regulator chest, started machining the valve chest
by doing some layout, drilling the holes for the studs tapping size to use as a template for drilling them in the block, and
milled out the centre
Turned the outside dimension of the gland boss, and then drilled and tapped  the gland in the mill
installed the gland, chucked the whole thing off-set in the 4 jaw to finish turning the boss and the gland as one, did one side, flipped it over to do the other side
Spotted the tapping holes through the chest, drilled and tapped them in the mill
And here it is mocked up with some bolts I had handy, studs and nuts will be fitted....
And here's where it's sitting in a little pot of alum solution to rot out the tap I broke off in the last hole....
Decided that it was time to quit for the day at this point!
Offline Joe d
« Reply #179 on: November 04, 2015, 05:31:11 PM »
Well, the alum thing worked, so no big drama to deal with...
Carried on with the regulator chest, just the steam chest all over again with minor dimension differences...
set it up in the 4 jaw to turn the boss for the gland
flipped it end for end to do a boss that will capture the end of the regulator rod
Once the middle was milled out, used the tap-drill size holes I had drilled in it to locate the holes in the casting, spot, drill, de-burr, tap, open up
the hole in the chest, install, repeat for the next hole...
Worked out fine, managed to not break any taps this time... and here's the family photo.. with the flashy recess milled
into the valve chest cover just for the look of it....
Cheers, Joe
Offline Joe d
« Reply #180 on: November 10, 2015, 09:38:46 PM »
Some fairly slow progress, making studs for all the stuff that hangs on the cylinder....
Small stuff, so went to the Taig lathe.  My version has the original Taig collets, a very small selection of sizes...
but, blanks are available so drilled one through the size of the studs, cut it by eye with a jeweler's saw...
Then a lot of threading, flip, thread some more and all done:  both steam chests, and enough + a couple spare
for the cylinder covers...
They are all faintly over long, I'll trim them down to final size once i have the nuts (I've ordered some commercial ones, if I don't like how they look
then I'll have to make some...)
Joe
« Reply #181 on: November 16, 2015, 07:58:40 PM »
Joe, that's lookin mighty fine!  :bow: :bow:
Offline Joe d
« Reply #182 on: November 16, 2015, 08:26:03 PM »
Thanks, Steve.
Weather's cooling off, you might be able to get back in your shop soon!
Joe
« Reply #183 on: November 17, 2015, 09:05:50 AM »
I've been a bad boy, Joe, doing more woodwork (bows)  :wack:.
Offline Joe d
« Reply #184 on: November 17, 2015, 12:12:06 PM »
Nothing wrong with woodwork, Steve.
I've been spending the morning running some cherry through the planer...
got a pair of bookshelves to build.
Joe
Offline Joe d
« Reply #185 on: November 25, 2015, 12:13:28 AM »
Well, still making some progress, albeit slowly...(been busy drooling over my birthday present to myself, a nice set of castings for a 1/8 Rider Ericsson are now hiding under my workbench)
milling out the piece that forms the pocket of the valve
And then saw it off of the parent stock
a bit of round stock gets silver soldered to that, with a little lug that the valve rod screws into
And in it's place:
Then more fasteners, need some bronze capscrews to fasten the cylinder to the boiler, so to work: turn down the end and thread with a die
turn some more to just over the overall size of the hex head, move the chuck to the indexing head on the mill and cut the hex head
move it back to the lathe and part off
and then in the collet I used for the studs, locked the carriage, and faced them all to the same size
Only needed to make 20, sure seemed to take a lot of time for such a small amount...
Cheers, Joe
Offline Joe d
« Reply #186 on: December 05, 2015, 06:52:09 PM »
well, still beavering away...
some straight-forward turning, drilling, and filing to make up the bits for the safety valve
Silver soldered it all together
here's the rest of the bits, I'll need to replace the spring, the current one out of the junk box is just a place-holder
and sitting where it belongs
Happily, had an off-cut of steel just the right diameter to use as a work-holder for drilling the mounting holes at the correct angles
bolted into place all the various bits, and trimmed the studs (still a little over long, final trimming will depend on the thickness of the gaskets)
And after a bunch of dis-assembly of the bits that will be in the way while installing the cylinder, here it is just sitting where it will go
Really starting to feel like the end is getting near now... :ddb:
Joe
« Reply #187 on: December 05, 2015, 08:51:16 PM »
Looking good I'm watching with interest.
Offline Joe d
« Reply #188 on: December 05, 2015, 11:13:28 PM »
Hi Tom
Thanks for looking in.
« Reply #189 on: December 06, 2015, 05:15:31 AM »
 :clap: :clap: :clap: :clap: Nice going Joe  :thumbup:
There sure is allot of work goes into making that cylinder block assembly  :clap: :clap:
Offline Joe d
« Reply #190 on: December 08, 2015, 12:16:26 AM »
Aye, you're right about that, Rob!
Carved the motion plate saddle out of a bit of brass from the "come in handy" pile...
Nearly all rotary table work: this is ready for the final pass with a ball-end cutter to make a nice fillet, then flipped it over and did the same thing to the other side
Used the wood cradle to hold the boiler for drilling the mounting holes for both the saddle and the cylinder in the drill press
and here they are bolted down in place.
Joe
Offline Joe d
« Reply #191 on: December 15, 2015, 11:31:59 PM »
got going on the connecting rod and it's various bits...
Turned the rod, put a purely eye-ball taper on it:
cut out the strap for the big end
Turned and threaded  some brass for the oiler, then drilled it through
Turned, drilled and tapped the oiler cap, then knurled it and parted it off
Here's all the bits, neglected to take any photos of building up the cross-head, it's 2 plates of steel soldered onto a central bit that has a relief for the small end of the con rod, with a turned, threaded, and hardened pin of drill rod, and straight-forward turning for the bearing bronzes
and here we are:
Joe
Offline Joe d
« Reply #192 on: December 28, 2015, 08:54:42 AM »
Started working on the bits for the reversing gear...
Mounted a bit of O1 steel on the rotary table to mill all the arcs
once done that, just hack-sawed them out, and cleaned them up with some filing, using the ancient hand vice to hold the
die block for clean up before hardening it
pre-drilled a number of stubs of round stock and then silver soldered them into strips of  flat stuff to make the various links,
turned the clevis for the valve rod, milled the slot in it and used some filing buttons to round over the end, and turned & drilled a bronze
bushing for it, and here's the family shot:
and here is the test installation
dug out a stub of CI from the left-overs pile, and turned the eccentric sheaves, here is clocking in for the off centre hole for the shaft
parted off, cleaned up, and drilled & tapped for the set screw
and a start on the eccentric straps:  sliced a bit of steel, drilled for bolts on each side, then in the lathe to bore the hole,
and starting to file off all the material that doesn't look like an eccentric strap
Neither of my boys was here for the holidays this year, so I'm getting a useful amount of shop time instead...
« Reply #193 on: December 28, 2015, 10:43:40 AM »
Joe,
Just to say thanks for posting, I'm silently watching and admiring the drama-free way you're cracking-on with this.
Offline kayzed1
« Reply #194 on: December 28, 2015, 03:00:10 PM »
i love it, just wish i was able to make some thing so nice..
Lyn.
Offline Joe d
« Reply #195 on: December 28, 2015, 09:07:11 PM »
Thanks, Dave.  Hope you aren't getting the floods that the mainland is getting.
Lyn:  Thanks, my advice:  just build something, each project you will find that you get better,
sadly that makes you raise your standards so it's still work to get to the level of fit & finish
that seems appropriate :doh:
Cheers, Joe
Offline Joe d
« Reply #196 on: December 29, 2015, 12:37:52 PM »
In-between bouts of snow shoveling, got the eccentric stuff finished...
silver soldered a lump on the end to make the clevis
some filing and rounding over, and one of them riveted in place
after a little cleaning up, here we are:
and from  another angle
Things are moving along at a pretty good clip just now!
Joe
« Reply #197 on: December 29, 2015, 03:52:28 PM »
Progressing very nicely!
« Reply #198 on: December 29, 2015, 04:07:58 PM »
Looking good Joe  :clap: :clap:
those parts are friggin small mate  :bugeye:  ,you must have the  patiences of a saint  :med:
Offline Joe d
« Reply #199 on: January 02, 2016, 03:00:42 PM »
Tom, Rob... thanks guys.
working on the reverse/forward lever. Pretty much all cut and file from thin gauge steel...
with a little bit of soldering to stick some of the parts together
some more of the bits
and where it goes
Joe
