Author Topic: Minnie TE Long term project  (Read 160606 times)
Offline Jasonb
Re: Minnie TE Long term project
« Reply #100 on: March 21, 2015, 03:50:20 AM »
Comming alonge nicely Joe
Its not quite as simple as setting a rotary table at and angle and milling slots, the slots actually need to follow a helix around the rim, thats why it would be more like cutting a multi start thread. Each of the rear strakes need to be twisted slightly to follow the same helix before being rivited on.
J
Offline Zadig
« Reply #101 on: March 21, 2015, 05:42:30 AM »
J
I don't see how this cannot be done comfortably on such a small scale - keeping any error to an aesthetic minimum.
The helix is hardly discernible on the bigger scales. Twisting is only necessary to bring the strake in line with the rim. If the rim was machined as per the front wheels then the helix is already incorporated. It would only be the sides of the strake that would not follow and I cannot see how this would be noticeable to an extent that would offend the eye.
Offline Zadig
« Reply #102 on: March 21, 2015, 05:50:50 AM »
Now I have thought about it, I can see my error. Ignore my last remarks.
Offline Joe d
« Reply #103 on: March 21, 2015, 08:52:58 AM »
Zadig  I enjoyed building the pillar tool, haven't quite finished all the extra bits for it yet.  The biggest problem was finding somewhere to bolt it down.  It really does make tapping less nerve wracking.  I've started reading your thread about your Burrell, wish I had both the room
and the machinery to tackle one that size.
Mexican Jon:  I suspect that I learned that trick on one of these fora, essentially a factory-made form tool.
Jason Thanks
Joe
Offline Zadig
« Reply #104 on: March 22, 2015, 07:12:23 AM »
Joe, I thought the pillar tool looked like a bit of quality, I had a vain hope that it was Chinese!
Offline Joe d
« Reply #105 on: March 22, 2015, 08:20:20 AM »
Hi Zadig
It's from George Thomas' plans, got some really nice castings from Gary Martin in the US a little more
affordable here than shipping them in from the UK.  Like your gear cutting, still finding the occasional
bit of cast-iron dust here and there...
Joe
Offline Joe d
« Reply #106 on: March 24, 2015, 11:57:49 PM »
Some more progress:
but first, here's the obligatory beauty shot.... a coat of primer to stop any rust while they sit around waiting for me to finish everything else
Wheels done, decided to carry on with some front-end stuff (was still waiting for stock to arrive)
so cleaned up an off-cut of the boiler barrel, and slit it lengthwise on the mill
once cut, opened it up a bit by pushing it over a piece of stock the same diameter as the boiler shell, then soldered in a little piece of copper
to fill the gap.  This then becomes the smokebox, so set-up the handy-dandy indexer again to lay out some rivet holes
That done, started on the perch bracket by rolling a piece of steel for the baseplate
and bent up another piece of steel and silver soldered them together
Then made a hole in the bottom of the bracket,  turned up a bronze bushing, and milled a steel fitting for the push pole, and soldered them
in place
two pieces of flat bar get a turned spigot on each end which is then threaded, these are riveted in place to provide studs for securing cover plates fore and aft (which were straightforward hacksaw and file work)
more to come...
Offline Joe d
« Reply #107 on: March 25, 2015, 12:04:10 AM »
the story continues...
milled the fork which will hold the front axle:
turned a retainer for the inner end of the fork, tapped for a setscrew
turned the pin that will hold the axle, and here's what it looks like behind the cover plate
So only have the axle, a couple of washers, and the hub covers to do and the front wheel assembly is done.....
and a very good thing too, as my pal the mailman brought me this:
so I can get back to the rear wheels!
Cheers, Joe
« Reply #108 on: March 25, 2015, 09:35:42 AM »
Still watching and and quietly applauding every step Joe!  :clap: :clap: :clap: :clap: :clap: :clap: :coffee:
« Reply #109 on: March 25, 2015, 01:51:56 PM »
 :clap: :clap: :clap: :clap: :clap: Front wheels look cracking Joe  :thumbup:
You seam to be flying along with this build  :dremel:
 :offtopic: but must ask  , how did you musket shoot ?  did you hit anything ?  :poke:
« Last Edit: March 26, 2015, 06:13:53 AM by RobWilson »
Offline Joe d
« Reply #110 on: March 25, 2015, 09:33:15 PM »
If you clap really loud, and the wind is from the sou-east, I could hear you! :clap:
Rob:
Thanks, Mate.  The flintlock came out nicely if I must say so myself, get it on the range a couple of times per year,
grouping is good, playing with sight adjustment still (fixed blade and v-notch) got the fall of shot on the centre of
the target horizontally, still got to bring it up a bunch.  This is pretty easy, file a little off the front blade, fire a string of shots,
measure how far up it moved, repeat.
Have to ensure that I don't do this right before going through airport security, black powder sets off their little
sniffer machines :)
Joe
« Reply #111 on: March 26, 2015, 06:17:22 AM »
Good to here your getting some range time  :thumbup: aye I bet the GSR is a total body thing after a few rounds  :lol: :lol:
« Reply #112 on: March 26, 2015, 08:36:29 AM »
 Hi Joe,
                    The Engine is coming on really well, and looking great.
Offline Joe d
« Reply #113 on: March 26, 2015, 10:21:32 AM »
Thanks, David.
chucked a piece of flat bar in the 4-jaw and turned a spigot on each end, this was then drilled and tapped for
a retaining screw.  Moved over to the mill and made some angled cuts
hand filed some decorative chamfers on the edges, some straightforward turning to make the brass hub covers
and here it is all together.
still have some cleanup to do on the axle, but pretty much done!
Cheers, Joe
« Reply #114 on: March 26, 2015, 04:17:26 PM »
Hi there, Joe,
That's looking very good.   :bow:   :bow:   :bow:
Please could you explain how the front wheels are retained on the axle?
A second question, please forgive me for being thick: you've marked-out fixing holes on the smoke box - does the boiler shell protrude forward of the smoke box tube-plate?  Surely the smoke box fixings don't penetrate the pressurised part of the boiler?   :scratch:   :scratch:   :scratch:
Offline Joe d
« Reply #115 on: March 26, 2015, 04:55:05 PM »
Hi Pete
Thanks for the kind words.
The end of the axle is drilled and tapped, once the wheel is on there is a washer slightly larger than the axle
diameter held on with a cap screw, all of which is hidden by the hub cap.
As to your second question, hard to tell in the photo but yes the shell extends a good 1/2" beyond the tube plate just for that reason.
Cheers, Joe
Offline Joe d
« Reply #116 on: March 28, 2015, 11:25:07 PM »
Well, started having at the nice bit of brass that came in last week.
Well hidden inside there are some rear-wheel hubs screaming to come out...
Set up in the mill to carve off some of the excess material
then mounted on the dividing head for a lot of passes to round it over, went with very small increments which leave me with next to
no clean up to do to remove the facets left by the indexing as they are really slight
changed to the other centre to mill the smaller radius
once that was done, still on the same centres started to mill out the inside of the hub.  So far once around with an end cutting mill,
next will go around each side of this slot with a 1/8' ball nose cutter, taking off another 1/16' on each side bringing the slot to size,
and giving me a nice little radius at the root.
Once that's done, remount once again on the other centres, and finish off the slot milling.
However, that's for tomorrow, it's time  :coffee:
Joe
Offline Joe d
« Reply #117 on: April 01, 2015, 09:55:39 PM »
Made some progress with the wheels.
Went around the material with the ball nose cutter to finish off the slots
Then a lot of back and forthing, in the 4 jaw in the lathe to face the end, in the bandsaw to cut off, back in the 4 jaw to reface, cut off, turn some spigots, cut off, etc etc, then faced the cut sides and end up here:
put the centre sections on the rotary table to mill the slots for the spokes
made up another jig to install the spokes
and here's one done ready for some rivets
Looks like a wheel now.
Cheers, Joe
Offline Zadig
« Reply #118 on: April 02, 2015, 01:54:19 AM »
They look lovely Joe, you'll be booking your steam test for the end of the month at this rate.
I was at a plant and machinery auction the other day and had you in mind for a long while. There was a construction book for the Minnie by L C Mason. I was tempted to bid for it for posterity, but things were going on elsewhere and I didn't get to see it go through - pity.
Offline Joe d
« Reply #119 on: April 02, 2015, 07:13:41 AM »
Thanks for that,  Zadig.  I do in fact have a copy of the book, worthwhile even if you weren't building one as an aide
in understanding the relationship of the various bits to each other.
Incidentally, have finished reading the 120+ pages of your project:  all I can say is WOW.  Looking forward to more,
so get busy  :whip:
Cheers, Joe
Offline Joe d
« Reply #120 on: April 03, 2015, 09:38:33 PM »
 Well, have hit one of those really enjoyable milestone moments in the project:
Soldered the hub bits together
Got the rim turning true in the 4-jaw, finished boring the axle hole and ran the reamer through it,
and did the final facing of the hub
and here we are, standing on our own 4 wheels:
I'll have to make another slightly shorter fork for the front axle, got a bit of an upwards tilt at the moment, but that won't take long,
meanwhile  it sure is nice to see it on wheels!
Cheers, Joe
« Reply #121 on: April 03, 2015, 09:40:49 PM »
By gum if it ain't a tractor!  :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :clap:
Offline mexican jon
« Reply #122 on: April 03, 2015, 11:21:57 PM »
Well Done That Man  :thumbup: :thumbup: :thumbup: :thumbup: :D :) :D :)
Offline Jasonb
« Reply #123 on: April 04, 2015, 02:50:12 AM »
Upwards tilt is a good thing see my reply elsewhere.
« Reply #124 on: April 04, 2015, 04:05:49 AM »
 :clap: :clap: :clap: :clap: :clap: :clap:  Bloody marvellous Joe  :thumbup:
