Gallery, Projects and General > The Design Shop
Small sawmill
<< < (3/3)
vtsteam:
Saw dogs is the term I use for that. Here are some I came up with -- they not only immobilize the log but they also jam fit on the cross beams. I just tap at the bottom and it locks on the cross beam (I think mine are 3"channel set on edge) then tap in the top into the log. To release just tap away from the log at the bottom.
They are nice because they aren't a permanent part of the track way, and can be moved around wherever needed. I pt them at the far edge when rolling a log onto the track to serve as stops. These are much faster to work with than permanently attached dogs. Kind of proud of this design.
vtsteam:
My saw is a "Simple Saw" designed by Bill Rake. another unsung mechanical genius -- much like David Gingery (though he at least is well known now).
Unfortunately I'm afraid Bill Rake may not still be with us, as his website disappeared. Last I spoke to him about 10 years ago he'd just had a triple bypass operation. I've been trying to find out if he is still okay, but haven't been able to.
The best website devoted to his saw design, with tons of good information added by Phil Kruppt is here:
http://kruppt.tripod.com/
I think Bill Rake built and designed over 30 different saw mills, both band and circular, and built many more. I sure hope he's okay. Best to you Bill wherever you are.
mhh:
--- Quote from: vtsteam on February 20, 2013, 02:27:51 PM ---My saw is a "Simple Saw" designed by Bill Rake. another unsung mechanical genius -- much like David Gingery (though he at least is well known now).
--- End quote ---
Aaaand now I have to design a set of wheels for it!  :D
Do you have a picture of how you use your saw dogs?
vtsteam:
I don't mhh, and right now my saw track is buried under about a foot of snow and ice, so I can't take a photo. If we get a thaw any time soon, I'll take a pic.
mhh:
That would be great.
Navigation
[0] Message Index
[*] Previous page
Go to full version
