Author Topic: Milling machine tram tool  (Read 126429 times)
Offline Darren
  • N/Wales
Re: Milling machine tram tool
« Reply #50 on: April 12, 2009, 02:41:29 PM »
I see, so you held the quill up and not down, I would have started on the wrong foot  :thumbup:
Been out in this incredible sun all day, started on may garage roof. Boy it was hot today, almost too hot to work outside  :dremel:
I'll have a look at the mill in a bit, btw my depth stop is a threaded bar, all I need now is a spring...... :ddb:
Thanks for the tips  :thumbup:
« Reply #51 on: April 12, 2009, 04:04:50 PM »
You've got it Darren, the quill has to be pulled up.
I tried to use the depth stop, but it just wasn't long enough before the spring got a mechanical lock, and also the diameter was wrong for the spring I eventually managed to find.
I honestly think, the bit I mentioned last time with the single pulley and a long tension spring would be the ideal permanent solution. Easily adjustable for tension, and no mechanical lock ups.
Offline Darren
  • N/Wales
« Reply #52 on: April 12, 2009, 07:30:38 PM »
Thanks John, I will look into this and give it some more thought.... :thumbup:
Offline Bourne Bill
« Reply #53 on: April 24, 2009, 02:47:47 PM »
Take a look in this site. It tells how to take the backlash out of the quill.
Micro-Machine Shop
microcosm - A small, representative system having analogies to a larger system in constitution, configuration, or development.
corollary - You can't have too many tools.
This site presents over 110 pages containing in excess of 1140 annotated pictures, 40 animations,
plus 125 reference documents on metal machining tools, tooling, modifications, methods, & projects.
Rong Fu RF-25 Mill/Drill
    Mill/Drill Specifications & Views
    RF-25 Mill DRO X Y Z Axes & Tachometer
    R-8 Spindle Accessories
    Collets, 5C Fixtures & Angled Fixtures
    Workholding, End Mills & Rotary Tables
    Coolant Misting System
Taig Micro Mill
    4-Axes Taig Micro Mill CNC Conversion
    Taig DRO X Y Z Axes & Tachometer
    Motor & ER-16 Spindle
    Screwless Vises
    Tooling Plate
    Manual Rotary Table
    Tramming the Taig Mill & Vise
Jet BD-920N 9x20 Lathe
    9x20 Lathe DRO X Z1 Axes & Tachometer
    Compound Bracket & Angle Plate Jig
    Quick Change Tool Post & Tool Bits
    Cross slide, Compound, Carriage & Feed Gears
    Tool Post Grinder
    Collet & Jawed Spindle Chucks
    Centers, Arbors & Tailstock Drill Chucks
    Locking & Tramming the Tailstock
    Boring Bars
    Ball Turners & Knurlers
    Single-point Threading
    Spindle Motor Emergency Stop
Taig Micro Lathe
    Taig Micro Lathe DROs
    Lead Screw with Split-Nut
    Micro Lathe & Mill Accessories
    Spindle Motor & its Mount
    Rocker & Quick Change Tool Posts
    Boring Bar Holders
    Ratcheting Locking Levers
    Tramming the Taig Tailstock
Metal-working Tools
    Band Saw
    Bench Grinders
    Broach Cutters
    Drill Bits, Countersinks, Reamers & Counter-bores
    Drill Presses & Chucks
    How to Drill a Hole
    Mensuration & Layout Tools
    Punches
    Sine Vises, Bars & Plates
    Tapped Threads & Reference Tables
    Vises
    Hit Miss Gas & Double-Acting Steam Engines
    Pens & Wine Bottle Stoppers
    Router Table Lift
DISCLAIMER
Opinions expressed are those of the author or the quoted source. The author is not an employee of or agent for any of the vendors referenced in the text and does not sell or represent any of the products discussed. The author is not a professional machinist or engineer.  No information provided herein should be construed to represent professional advice or best practice.  All information is provided to help hobbyists and other non-professionals gain a better understanding of the tools and techniques described. Care has been exercised to provide accurate information. However, the author cannot be held responsible for information which is incorrect or out of date. Power tools and shop practices can be dangerous. Read, understand & follow all directions & precautions provided by the equipment manufacturer. Always take all proper safety precautions such as wearing protective eyewear and appropriate clothing. Contact the manufacturer if you have any questions.
All practices described herein are to be used at the discretion and risk of the reader.
Last updated on Thursday, April 23, 2009 06:40:34 AM          Let the chips fly!
Life is short, eat dessert first...........
Offline Darren
  • N/Wales
« Reply #54 on: April 24, 2009, 03:01:08 PM »
Thanks for that, I'd read that site before but wasn't looking for that info at the time.....
Well spotted  :thumbup:
« Reply #55 on: April 24, 2009, 03:23:54 PM »
Micro-Machine Shop
Thanks Bill... got some reading ahead of me.
« Last Edit: December 03, 2010, 12:05:03 AM by Brass_Machine »
Offline Bogstandard
  • Bogs Group
« Reply #56 on: December 02, 2010, 06:06:59 PM »
Just a little update.
Anyone ever seen one of these before
http://www.youtube.com/watch?v=0-D1gNYPi3A
Location - Crewe, Cheshire
Skype - bandit175
« Reply #57 on: December 02, 2010, 07:48:35 PM »
Yup - distinct sense of deja vu. I'm sure that if you anodised yours, you would choose a more tasteful hue.
Offline No1_sonuk
« Reply #58 on: January 07, 2011, 10:16:19 AM »
Yup, I have one in my cupboard.  :thumbup:
Offline irishwoodsman
« Reply #59 on: November 14, 2011, 10:20:23 AM »
Nice jig, but i have a question, i want to use this to cut morse tapers in a lathe. do i have to space the indicators the same distance as the length of the taper. i will be useing this to set the degree of my compound so i can machine the taper  ty for any info
Offline fatal-exception
« Reply #60 on: November 17, 2011, 03:42:06 PM »
Great project Bogs! I've seen these around and have though about how handy they would be each time I have to tram the mills.
The bit about turning down the shank after it's installed in the bar is the chunk of the puzzle that makes it all good.  :D I wonder if this step could be avoided if the hole was bored on the lathe?
It seems that as your project list goes down, mine goes up!  :hammer:
Thanks for the writeup.
Paul
« Reply #61 on: November 18, 2011, 01:03:34 PM »
A more convenient way to angle the compound might be to look up the taper per inch here http://littlemachineshop.com/Reference/Tapers.php, and angle the topslide so that a dial indicator bearing on the side of it exhibits the appropriate variation when the carriage is moved along by 1". Your topslide will probably be long enough to double, treble or quadruple the figures and measure over 2, 3 or 4" for greater accuracy.
Check by rough measurement of a similar taper whether the per inch figure is measured over the diameter or the radius. If the former, halve it or you will end up with a taper twice as steep as you require, as I once found out through carelessness  :bang:
Unless you can bring a morse socket up to work held in the chuck for a test fit with engineer's blue, it would be better to turn it between centres. Then, if some tiny adjustment is needed, you won't be troubled with chucking errors when returning it to the lathe.
Andy.
Offline tel
« Reply #62 on: November 21, 2011, 04:41:55 PM »
Like this
« Reply #63 on: November 21, 2011, 04:55:26 PM »
Exactly, Tel, except that when working on a virgin length of barstock, you can centre drill both ends and use a regular centre direct in the tailstock, rather than the female one in a drill chuck you have had to use with your ready-made demo item.
PS I suppose this is all very  :offtopic: for Bog's tram tool thread, so I'd better say no more...
PPS ... Except that a dog will be needed to drive the item.
« Reply #64 on: December 01, 2011, 03:18:04 PM »
For those of you Canucks on here, I found some good quality, cheap dial indicators from Accusize Tools out of Ontario. $12 each + shipping. http://www.accusizetools.ca/products_details.asp?big=1&small=20&proid=15
I whipped up a variation of Bogs design in Solidworks and have attached it to this post. I'll post my results when it's done!
Happy chip making!  :)
Paul
« Reply #65 on: December 06, 2011, 12:37:57 PM »
 :update:
Here's mine. I deviated from the plan slightly as far as the shape goes. I adjusted a fly cutter to make the grooves in the body in a single pass. After I did the front and back, I was having so much fun I flipped the part and did the top and bottom too. I really don't like the yellow anodizing. I 'perpendicularized' the spindle post the same way Bogs did, on the faceplate of the lathe, and good thing.
The milling head of the big mill is out a bit in both directions, which can now be accurately adjusted.
If course, it can be used to tram the tailstock of the lathe too. Mine's way out in both directions:
I haven't checked my cnc router yet, but I know that it's out a bit, and it can be used to accurately set the drill press table too.
All I need to do is make a nice fitting, foam filled box for it.... :headbang:
Paul
Offline DaveH
  • Kempton Park, South Africa
« Reply #66 on: December 06, 2011, 02:20:26 PM »
Paul,
Looks very nice,  :thumbup: :thumbup: :thumbup: I quite like the yellow anodizing. :clap: :clap: :clap:
A very nice and usefull bit of kit.
Offline buffalow bill
« Reply #67 on: December 06, 2011, 02:41:04 PM »
Paul,
A question from an electrician with no previous machining experience
About checking the lathe tail/head stock, how do you know which is out tail or head?
  :Doh:
Bill.
Helensburgh, Argyll & Bute
« Reply #68 on: December 06, 2011, 02:44:52 PM »
Nice job, Paul :thumbup: . I quite like the yellow, too.
You need one of John Hill's cushiony boxes to keep it safe:
http://madmodder.net/index.php?topic=4770.0
Offline Spurry
  • Norfolk, UK
« Reply #69 on: December 06, 2011, 06:31:30 PM »
Just wondering how you reference those clocks to the bottom face of the gadget. They just seem to stick out (scientific expression  :bugeye: ) a long way.
Offline grayone
« Reply #70 on: December 06, 2011, 09:46:48 PM »
I wondered about that as well as I am planning on making one.  Dial gauges enroute from Hongkong so project 996 for when I retire :D My idea to calibrate it would be to pack up using parallels under the body with it sitting on a surgace plate.  Then simply adjust the dial gauges until they read the same and tighten the screws holding them in the tool.
Growing old is mandatory, growing up is optional
Offline 75Plus
« Reply #71 on: December 06, 2011, 10:18:39 PM »
The clocks are mounted so that the plungers can collapse inside the base. The unit is held firmly on a flat surface and the clocks zeroed. This is the reason it was so important to do the final machining on the stem while the base was clamped securely to a previously trued face plate. See reply #19 on page 1 of this thread for an explanation.
« Reply #72 on: December 07, 2011, 02:14:00 AM »
While admiring this design of tramming tooling for a long time now.......  :clap: :thumbup:
I can't get away from the concern that it must stay square to itself.
Also, it must be mounted perfectly square to the m/c spindle.
How do you know it is still in spec, after some use?  :scratch:
The last pic. above, assumes the drill chuck is perfectly true to it's arbor, and tailstock centre line.......
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #73 on: December 07, 2011, 02:19:18 AM »
I suppose you take a reading, note down the results, and then rotate the spindle 180 degrees and see if the readings for each end still match the 1st set of readings :scratch:
Tim
« Reply #74 on: December 07, 2011, 03:33:27 AM »
Tim
Thats what I do with mine its still OK after a souple of years use.
