Author Topic: 1906 motor bike engine  (Read 174861 times)
Offline tekfab
Re: 1906 motor bike engine
« Reply #100 on: July 14, 2013, 06:13:55 PM »
Bloody BRILLIANT  !   :nrocks:
Offline stefang
« Reply #101 on: July 14, 2013, 06:59:12 PM »
 :jaw:
Speechless of such brilliant work!
Stefan
« Reply #102 on: July 15, 2013, 01:48:33 AM »
Tom.
That is absolutely wonderful! "Just like the real thing"!!  :bugeye:
Bet you're still smiling......  :D
Blummin, well done:clap: :clap:
Offline BronxFigs
« Reply #103 on: July 15, 2013, 07:52:40 AM »
Tom....
Just viewed the short video of THE ENGINE RUNNING !!!!!!   Congratulations on a job well done.  The rest is easy.  Just some tweaking here and there....and, you're done.
Now, more than ever, you got me wanting to build this kind of engine, now that I know it can be done.
Thanks, I read your suggestions for changing a few of the parts.
Frank
« Reply #104 on: July 15, 2013, 08:07:37 AM »
And what a FABULOUS sound it makes when running. Excellent !
« Reply #105 on: July 15, 2013, 08:18:46 AM »
5 pages of posts and it runs.
Mawsons lathe is up to 14 pages and it's still not run yet  :poke:
 :lol:
 :lol: :lol:
 :lol:
« Reply #106 on: July 15, 2013, 08:29:30 AM »
Yeah but when it does he could knock engines out by the dozen  :D
Offline BronxFigs
« Reply #107 on: July 15, 2013, 08:54:17 AM »
Can any modern ignition coil, etc. be used to spark this kind of engine?  The magneto is from the period, but for demos and shows, could I substitute a more efficient, compact, easier to conceal system, to fire the engine?
@Tom:  You got mail.
Frank
EDIT:  For a similar engine, but this time of a scaled-up "HOGLETT-TWIN" check out: You-Tube.... "Home Built Engine in Old Harley Hummer" posted by ScouderFord
« Last Edit: July 15, 2013, 10:21:16 AM by BronxFigs »
« Reply #108 on: July 15, 2013, 11:21:13 AM »
 :lol:
 :lol: :lol:
 :lol:
Not quite factual John but  I won't rise to the bait  :headbang:
(Collected 3 metres of 50mm EN8 today - now what's that all about? )
Offline Anzaniste
« Reply #109 on: July 15, 2013, 12:47:38 PM »
@Tom:  You got mail.
Frank
There's nowt wrong with a magneto otherwise why would aeroplane engines use them? :thumbup:
Offline BronxFigs
« Reply #110 on: July 15, 2013, 01:26:04 PM »
Anzaniste...
Just wondering if any alternative ignition systems would work other than a Magneto.  If I am successful in building this engine, I will only run the engine for demos and possibly at outdoor shows.  I just wondered if anything else could be used for sparks.  It's nice to have options.
@ Forum Members:
Questions.....
I have some thick-walled (0.3750") steel tubing that I can use for cylinder material in lieu of a cast iron liner.  Can I run a 6061 Aluminum piston with cast iron rings in the steel tube?  Should I just buy a commercially available piston, and ring set?
This engine is air-cooled, and designed to have fresh air blowing across the cooling fins for heat dissipation.  Will cooling fins be adequate for stationary demos and intermittent running at shows etc.  With the large amounts of iron mass at the top of the cylinder, will this be enough of a heat sink to keep the engine at working temps?  Do you think an accessory fan blowing across the engine cylinder will be needed?
Thanks for the help.
Frank
Offline OKTomT
« Reply #111 on: July 15, 2013, 02:18:40 PM »
Thanks guys
Frank I built the mag. its not really a mag. it just has a set of point in it . The battery and coil are hidden in the gas tank shell that also has a small gas tank in it. you can use the a steel liner and aluminum piston with cast iron ring for your engine if you don't plan on running it much. As for the cooling it helps to run low octane fuel like coleman. No fan needed. I got your mail. it might be easer if I call you to answer some of your questions. Tom
Offline BronxFigs
« Reply #112 on: July 15, 2013, 03:12:29 PM »
Tom...
Thanks for the new, and unexpected information regarding the "magneto", the cooling, and the fuel recommendations.  Now, I may want to re-think my piston material choice judging by your answer..."if you don't plan on running it much"....  These last few words have me a bit concerned.   I'll be a little more specific when I contact you in the near future.  I want to get some materials, and questions ready.
Many thanks.  Looking forward to new photos, and postings.
Frank
« Reply #113 on: July 15, 2013, 05:39:29 PM »
 :lol:
 :lol: :lol:
 :lol:
Sounds like tool holders ?
Offline OKTomT
« Reply #114 on: July 21, 2013, 08:43:06 PM »
I reworked the ignition system and put the Honda carb. back on after drilling out the jet.It runs a lot better now.  looking at this video the timing needs advanced.  Tom
Offline AussieJimG
« Reply #115 on: July 21, 2013, 08:57:20 PM »
That sounds great. And I do like the dummy magneto - that is very clever.
Jim
Offline BronxFigs
« Reply #116 on: July 21, 2013, 10:35:51 PM »
Still here.  Still interested.
Frank
« Reply #117 on: July 22, 2013, 02:10:19 AM »
It just keeps on improving.......  :thumbup: :clap: :clap:
« Reply #118 on: July 22, 2013, 03:38:51 PM »
I've been following you on this build great job!!  the flames out the back could be the exhaust pipe not sealed and some air getting in or it may be too much gas being a one cylinder. An old amal carb would look sweet like a pre-monoblock or a t.t series   http://amalcarb.co.uk/  .
 Another thing I just remembered I bought my norton back in 74 the problem I had with it was it would kick back when starting to the point of not being able to put pressure on the foot and would occasionaly backfire no matter how many times I timed it or had the shop look at it nothing could be found out of place. It turns out the auto advance unit was worn causing the spark to fire at various times. So by looking at your video the chain drive to the points should have a slip or a idler to take up the slack.
Tom
« Last Edit: July 22, 2013, 04:19:43 PM by tom osselton »
Offline OKTomT
« Reply #119 on: July 22, 2013, 09:20:20 PM »
Thanks guys
Osselton  thanks for posting the carb. link. mabey I can find one of them. it would look real nice on this engine. if the chain slack gives me trouble I will add a idler good call on that.  Tom
Offline alspeed
« Reply #120 on: July 24, 2013, 05:08:08 PM »
What a fantastic project, i have followed it with interest, great work, and brilliant to hear it run, well done.
For yourself and maybe others interested in scratch built motorcycles, have a look at this guys website, i came across it whilst searching
youtube for homemade V twin engines, stunning work from a man in a shed.
http://www.mwv2.com/saltster.html
Alan.
Offline OKTomT
« Reply #121 on: July 24, 2013, 10:17:55 PM »
Alan thanks for the link . I just spent two hours there. He builds some very unique bikes.
Offline alspeed
« Reply #122 on: July 25, 2013, 12:03:58 PM »
Glad you enjoyed it as much as me Tom  :thumbup: I can't seem to get my head round the rotary valve
bit though, i think i understand the principle of it, but can't figure out how it works in practice with regard to
actual machining or holding compression etc.
Think i will have to do some more research on the subject.:scratch:
Alan.
Offline BronxFigs
« Reply #123 on: July 25, 2013, 04:01:21 PM »
Post # 120:
Followed the link, and now my head is about to explode.  Just incredibly inventive minds at work here and on the motorcycle link.
Very very interesting designs that showed up within this thread.
Tom, still here till the end.
Frank
Offline BronxFigs
« Reply #124 on: July 25, 2013, 04:17:09 PM »
Just this minute I did a search for "Scratch-Built Motorcycles", and hit pay-dirt.
Check out  this You-Yube tutorial on how to fabricate, and machine a 155cc engine made from beer cans...yes, beer cans!  Smelted, beer cans.
Go to:  You-tube: "Fabricating and Running a Scratch Built Engine From Beer Cans" posted by Beercan Engines
Enjoy....
Frank
