Author Topic: ABRASIVE BELTS Joining abrasive strip to form belts  (Read 12082 times)
« on: December 16, 2012, 05:45:19 AM »
   I need to make some belts from abrasive strip, can any one advise re. joint preparation and adhesives.
                                                    David
Re: ABRASIVE BELTS Joining abrasive strip to form belts
« Reply #1 on: December 16, 2012, 08:17:16 AM »
Hi David
have a look at this
   :med:
« Reply #2 on: December 17, 2012, 05:29:30 AM »
 Hi  Rob
                  Thanks for the link, have just placed an order with ebay for the reinforced tape.
                                                        David
« Reply #3 on: December 17, 2012, 01:51:34 PM »
Hi David
Lets no how you get on with the belt joining  :thumbup: ,,, mined when that tape gets old it sheds glass fibber partials when you unwind it from the roll , very itchy .
« Reply #4 on: January 09, 2013, 05:00:18 AM »
Hi Rob
            Finally got round to repairing an abrasive belt. This one had pulled away on the original scarf joint, so stuck it back together with clear Bostick  and re enforced the back with the tape, working well.
        Cheers  David
« Reply #5 on: January 09, 2013, 03:22:49 PM »
Result David  :thumbup:
I was toying with the idea of building a small belt  linisher .
Edit :  tit , forgot to attach file .
« Reply #6 on: January 09, 2013, 03:32:59 PM »
What ? You havent got a linisher in your 'shop..... :coffee:
I  am surprised....You got everything else in there..Bit like Mary Poppins is your workshop... :D
« Reply #7 on: January 09, 2013, 04:11:18 PM »
 :lol: :lol: I have John ,,,, the type with 4"wide belt  with the disc on the side , hardly  use it , probably stick it up for grabs when i can get to it , I was thinking that a 1"or 2" wide , long belt  type would be of more use .
« Reply #8 on: January 09, 2013, 04:57:47 PM »
Rob,
I  have a small 1in wide one ( the sort from Machine Mart ) and its good for taking the corners off small lumps of metal, quicker than using a cutter in the mill....... :dremel:
