The Shop > Our Shop
Hello, my name's AdeV, and I am a machinaholic...
<< < (2/2)
AdeV:
Swarf!
David - I'm already mesmerised by it... in the pic, I'm shaving the bottom off an oversized tool bit (it won't quite fit in the holder... I do need a better vice though, or maybe just need to make a T-nut to replace the missing one, you can see the vice base twitching every time the tool hits the work...
Phil - nice looking machine, I presume yours is motor driven rather than line shafting (how envious would I be if you had line shafting....) - there are some older pics of mine here: http://madmodder.net/index.php/topic,2149.0.html It's not quite that pea-green in the flesh, the flash has washed the colours out a bit, it actually looks quite respectable in its green clothes.
philf:
--- Quote from: AdeV on October 07, 2012, 09:18:58 AM ---I do need a better vice though, or maybe just need to make a T-nut to replace the missing one, you can see the vice base twitching every time the tool hits the work...
--- End quote ---
Ade,
Am I missing something? (or are you?). Where's the bolt holding the vice to the base?
AdeV:
--- Quote from: philf on October 07, 2012, 09:56:19 AM ---
--- End quote ---
Ade,
--- End quote ---
Yeah, there's one missing - the complete t-nut, threaded bar & bolt unit - which means the one on the other side is doing all the work, but it's not quite enough - I can see the vice moving under the cut.
This is only a lashup to try it out, I need to find a better (bigger) vice.
Mike Cole:
Hi Adv
My wife says I watch far too much machine porn on the computer :drool:
. I only have a 10 inch stroke , dare I tell her of your 20 inches.   :bow:
Mike
Rob.Wilson:
 :bugeye: now thats a shaper Ade  :headbang: :headbang:
Navigation
[0] Message Index
[*] Previous page
Go to full version
