Author Topic: Making a large Lathe Fixed Steady from scrap ..  (Read 15355 times)
« on: August 23, 2012, 12:47:51 PM »
I have some 5" SS pipe that  needed to be cut .... pref square !!
So I needed a large fixed steady for the lathe ... an old rear brake disc and an old lorry part for the base. Both parts are cast steel which is very nice to machine.
Cleaned the brake disc up a little to get rid of the rust ... it's a rough quick finish, will tidy later..
Need to make some locating slots for these three fingers from my normal sized steady
Used the milling machine and bolted the disc to my rotary table to index at 120 degrees
Cut one flat edge
Starting the base from a part from an old lorry ..
Which fits here
Cut a slot in the base to fit the brake disc
Cutting the bell off the disc
And here we are, nearly done ... need to weld the two parts together
A mock set-up to see if it all looks ok
Re: Making a large Lathe Fixed Steady from scrap ..
« Reply #1 on: August 23, 2012, 01:00:00 PM »
Darren
Good use for old brake rotors. Too bad a person only needs one or two steadies.  :D :D
« Reply #2 on: August 23, 2012, 01:53:23 PM »
Ahhh...they say mother is the necessity of invention..... :coffee:
Very innovative Darren..... :bow:
Nice job...
« Reply #3 on: August 23, 2012, 02:31:24 PM »
Nice work  :clap: :clap:
« Reply #4 on: August 23, 2012, 02:50:58 PM »
Excellent! I have a rusty brake rotor "ageing" to be reborn as a tramming aid.  Now I probably have to get onother :beer:
Just collecting my braincells together and trying to figure out how to make both sided really parallel. Probably have to mount faceplate first and that will need an adapter....
« Reply #5 on: August 23, 2012, 03:44:48 PM »
Now....... That's blummin clever! :thumbup:
Well done Darren.  :clap: :clap:
