Author Topic: Steam Engine Cylinder Casting  (Read 24129 times)
« on: August 12, 2012, 03:51:15 PM »
Lads
I made use of the sand cores i made last week and cast my cylinder
This picture shows the sand core in the mould
The small round bit is where the metal is poured in (sprue) the rectangulsr bit is the riser
This feeds the casting as it cools
This shows where the riser has been cut off (nice clean solid metal)
This is always a welcome sight
Very happy with it
I cast this yesterday with poor results
Nasty void in the riser (scrap casting)
At least you can always cut it up and re melt it
I could not resist machining at least one face
Good clean metal
Re: Steam Engine Cylinder Casting
« Reply #1 on: August 12, 2012, 03:57:42 PM »
Cylinder casting looks spot on  John  :thumbup:   :clap: :clap: :clap:
« Reply #2 on: August 12, 2012, 03:59:38 PM »
Thanks to You Mate :thumbup: :thumbup:
I think i have found the shiney button on my new camera  :ddb: :ddb: :ddb:
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
« Reply #3 on: August 12, 2012, 04:24:01 PM »
Nice work  :thumbup: :thumbup:
_________________________
Greetings / Benni
Offline DaveH
  • Kempton Park, South Africa
« Reply #4 on: August 12, 2012, 05:16:47 PM »
I bet you have nicked Rob's camera  :) :) :)
Really nice job on the casting  :thumbup: :clap: :bow:
Offline ironman
« Reply #5 on: August 13, 2012, 12:32:17 AM »
Nice work, what was the metal? Brass or Bronze?
« Reply #6 on: August 13, 2012, 02:43:49 AM »
well dun john it looks brill
Offline jb3cx
« Reply #7 on: August 13, 2012, 07:43:20 AM »
nice finish john.just watch for JS and his ju ju dolls,as your good mates with "the twat in the yellow mac"
« Reply #8 on: August 13, 2012, 03:52:53 PM »
Looking good John  :thumbup: :thumbup: :clap: , the inside looks very shiney too  :)
  Cheers Mick
« Reply #9 on: August 13, 2012, 04:06:02 PM »
Thanks Mick
I have a new camera  :drool: :drool:
« Reply #10 on: August 14, 2012, 04:46:56 PM »
Lads
Got a bit more machining done on the cylinder
Next job is to mount it on the lathe saddle & poke a hole through it
Offline saw
  • lucky amateur
« Reply #11 on: August 14, 2012, 05:20:27 PM »
Wow, looking fantastic..  :bugeye: :bugeye:
Greetings / Benni
« Reply #12 on: August 15, 2012, 12:50:03 AM »
Looking very good John  :thumbup:
Nice pics as well:- happy new camera  :headbang:
« Reply #13 on: August 15, 2012, 02:02:37 AM »
well thats it you will just have to mace me a set of castings well dun john
Offline HS93
« Reply #14 on: August 15, 2012, 02:36:28 AM »
I think it might be the light in the North east or the fumes from the Newcastle brown plant smoke. but the finish is fantastic something for me to stride for.(both of you) what camera is it by the way and do you use flash or other lighting
Peter
« Reply #15 on: August 15, 2012, 06:34:28 AM »
don't think they mack newcastle brown all at newcastle any more
« Reply #16 on: August 15, 2012, 04:10:04 PM »
Peter
Peter
The camera is a Cannon 300 D
It is fairly old
SLR Type
I just use it on automatic if it needs a flash it just fires it off
Offline NickG
« Reply #17 on: August 16, 2012, 11:18:15 AM »
Looks great John and is in perfect proportions! Brilliant project!
Nick
« Reply #18 on: August 16, 2012, 12:48:28 PM »
Hi Peter
Panasonic Lumix DMC-FZ38 , only use two settings IA (smarter than I) and Flower  :palm: , no flash just point and shoot . I must learn  to take popper photos ,instead of the usual rushed last minute shots .
Lookin good John  :thumbup:
Offline DaveH
« Reply #19 on: August 16, 2012, 05:25:05 PM »
Does look good John  :thumbup: :clap:
Offline HS93
« Reply #20 on: August 16, 2012, 11:57:01 PM »
Peter
Peter
It is fairly old
SLR Type
Thank you for that
Peter
« Reply #21 on: August 20, 2012, 05:59:44 PM »
Lads
Started boring the cylinder
Mounted on the lathe saddle
Body filler is used to plug the end and the centre marked
It is mounted on the face that it will sit on
This should keep the bore paralell with the base :D:D
The bottom of the cylinder is held against the face plate this should keep the bore and the botton face in line (note use of tab papers) as a "slip guage)
After a few cuts it was obvious that something was wrong
Sand inclusion in the casting (core sand)
I may as well keep going
Cleaned up at just under 2 1/4 inch
Should be ok with one more fine cut when it cools off
I was aming for a bore of 1 7/8 the same as my marine engine
2 1/4 will give it a bit more power
« Reply #22 on: August 20, 2012, 06:38:07 PM »
Looking good John  :clap:, a bit more power never hurt anyone :thumbup:
  Mick.
