The Shop > Electronics & IC Programing
Slicer software
<< < (2/2)
Brass_Machine:
I had seen something along that lines. In fact, I saved the document somewhere that talks about it. Will look when I get home.
philf:
--- Quote from: John Stevenson on July 11, 2012, 01:09:39 PM ---So as not to hi-jack the reprap thread i have started a new one.
First of all read this post.
http://www.homemodelenginemachinist.com/index.php?topic=18727.0
Forget all the naysayers what I'm interested in is doing the same but in say 3mm slices and getting a DXF of each slice.
Tried to contact Matt but no reply.
Also had a look at slic8r program but can't see how to get a DXF as opposed to a reprap G -Code.
Any clues guys ?
John S.
--- End quote ---
Possibly not quite what you want but have a look at 123D MAKE from Autodesk. (Free I think): http://www.123dapp.com/make
At the moment it only exports files in PDF or EPS format. There are free PDF to DXF converters about.
There is a plugin for Sketchup which generates slices for laser cutting but I can't see (without installing Sketchup and the plug in) what format it exports the slices in.
Cheers.
[Apologies to Chazz - I just noticed that you'd also suggested 123D MAKE]
Brass_Machine:
Yeah... What I thought was a document talking about software that does this... isn't. It is a document that talks about doing this manually!
Sorry.
woodguy:
The Meshlab page here: http://meshlab.sourceforge.net/  says:
"Slicing tool. A new tool that allows to export planar sections of a mesh in SVG format "
Inkscape will read SVG and write dxf
I haven't tried any of this.
wongster:
I've seen it done using bobcadcam. I'll try to find the video. Did the same to extract profile for lathe work. Basically a plane (or several planes) is drawn cutting into the solid model. The intersection is then taken, leaving behind the slices required.
Add: This is the video:
3G was acting up. Couldn't play the video to confirm earlier.  I can't recall if BobCad can export to DXF. Will check when I get home.
Regards,
Wong
edit: embeded link ds
Navigation
[0] Message Index
[*] Previous page
Go to full version
