Author Topic: DIAMOND GRINDING WHEELS  (Read 14181 times)
Offline Mr.B
  • Country: scotland
« on: July 03, 2012, 10:48:55 AM »
How do you clean the surface of a diamond grit grinding wheel.
Can anyone enlighten me?
Bernard (the owner of a dirty faced wheel)
Re: DIAMOND GRINDING WHEELS
« Reply #1 on: July 03, 2012, 12:10:30 PM »
Bernard,
Brake & clutch cleaner, is good for that type of cleaning job.
This is the one I use.     http://www.ebay.co.uk/itm/6-X-BRAKE-AND-CLUTCH-CLEANER-400ML-SPRAY-CAN-AUTOCARE-/400162617646?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2b8cf92e
I wouldn't be without a can, or two, in the workshop.  :thumbup:
Offline hopefuldave
« Reply #2 on: July 05, 2012, 06:00:56 PM »
Good stuff, but way cheaper in a 5 Litre can from a motor factors near you!
N.B. motor factor != "Halfrauds"
Dave H. (the other one)
« Reply #3 on: July 06, 2012, 02:07:43 AM »
Hmmm...... Thanks Dave!  :thumbup:
I'd forgotten. I used to obtain tricho in those quantities from work, when I did!
These days I use much smaller quantities, on much smaller widgets. Usually before loctiting.
The aerosol, wet blast is a useful feature too......
Offline Doc
    • My Youtube Channel
« Reply #4 on: July 06, 2012, 12:11:51 PM »
To clean a diamond or CBN wheel it is best to use a cleaning stick.
Here is what I am talking about.
Diamnon/CBN cleaning sticks
After cleaning your wheel will preform as it did when it was new.
Offline Russell Nash
  • Obsessive Compulsive Slob
« Reply #5 on: August 01, 2012, 07:51:21 AM »
I was a CNC toolmaker.  We used diamond wheels over 95% of the time.  Just like with sandpaper, the wheel is made up of grit and the material that holds it together.  Your wheel is full of crud from your grinding and the diamond bits have either been knocked off or gooped up.  Using the sticks (white Aluminum Oxide) on the wheels removes a layer of the wheel material and exposes new diamond.  Push the stick lightly straight into the cutting face of the wheel.  When the wheel starts eating your stick faster, it's clean.  You can do this hundreds of times before the wheel is used up.
Veni, Vidi, Velcro
I came, I saw, I stuck around
