Author Topic: Milling Steam Ports  (Read 8920 times)
Offline Aestus57
  • Country: scotland
  • Caithness, Scotland
Milling Steam Ports
« on: June 16, 2012, 10:04:07 AM »
Hi there,
I have "acquired" a Cast Iron Cylinder casting which I'm using to make a horizontal Mill engine, its 3/4" bore X 1 3/8" stroke.
I've bored it out and have now come to the stage of cutting out the steam ports for the slide valve.
Whats the best way of doing this?
Do I drill a series of holes then link them up with a slot cutter, or go staight in with the slot cutter without drilling... or drill a hole at each end and mill out in between?
I have seen situations where people have made a gang milling cutter, but don't think thats for me with my level of exprience just yet.
The ports are 3/32 wide inlet and 3/16 wide exhaust X 3/8 long.
Thanks in advance!
Regards
Peter
Think I'm suffering De Ja Vu and Amnesia at the same time, I'm sure I've forgotten this before!
lordedmond
Re: Milling Steam Ports
« Reply #1 on: June 16, 2012, 11:32:47 AM »
just leave them as a series of holes you will break the milling cutter trying to make a slot of that size
start with a small drill to check the alinement
It will make very little difference
Stuart
