Author Topic: Resurrection Time Again.......  (Read 15480 times)
« on: May 09, 2012, 04:24:36 PM »
As most of the workshop and home, round toits are now sorted. It's time to make a start on this year's resurrections, from the orphanage.  :thumbup:
This one took no time at all......... It's scrap!
This big wobbler took an hour or so........
Time to start on Robbo......
You've all seen the story, up to pres..........   http://madmodder.net/index.php?topic=6110.0
First off. I don't like relatively thick wall, brass hot caps........
Too much heat can pass to the cool end.
So, I sawed it off, to replace with a piece of steel vacuum cleaner pipe......
I noticed the original end cap was concave copper, and painted black, to absorb the heat.
A rub with emery highlighted the hammer marks........
I radiused a piece of delrin, and gave it a tap, or two........
Looks good now........
Carefully parted off, just behind the cap........
Bored the cool end 1/8" deep to take the chrome pipe, and cap.
Looks ok, I think.........
I emeried away the chrome, and silver soldered the cylinder in place........
Then after a clean up, replaced the original copper cap......
Another clean, and a quick assemble. I think they look made for each other......
Not a bad day's work.......
Need to sort out how to make a lightweight displacer now, cos I don't like the wasted volume of the regenerator.
It's nice to be back to it again!  :D
« Last Edit: May 09, 2012, 05:46:21 PM by Stilldrillin »
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
Re: Resurrection Time Again.......
« Reply #1 on: May 10, 2012, 12:47:00 AM »
Good to see you back to it too, David.  That hot cap looks better than new!
I think you had a good day, all told.  : )
Dean W.
Shop Projects:
« Reply #2 on: May 10, 2012, 02:28:19 AM »
Thanks Dean!
The bundle of bits was sent to me from Australia, as you know. To be auctioned for the Junction 26, Children's Hospice Appeal.
Like me, you also realised it was beyond any sensible hope of running........  :palm:
I fretted, all winter..... What  would the owner think?  :scratch:  :(
I sent him this pic, and an explanation. I'll give£10 to the charity, and call it Stilldrillin's Failure.......
Bless him! He fully understood. Told me to bin it, and promised to match my tenner!   :D
My Scottish pal rang, that evening. He has a fetish for these 'orrible things......
I'm posting it up north, and he's also giving a tenner!  :D
Thirty pounds, for the Children!  :bugeye:
The oscillator is to be auctioned too.
What a lovely, caring collection of friends we are..........   :clap: :clap: :clap:
« Reply #3 on: May 10, 2012, 03:12:17 AM »
Dave SD
Want this for your auction ??
J-Tech 1/4" drive socket set.
4-14mm sockets.
+ ph, torx, hex & pzd bits.
Can't seem to do piccys on a PM ..  :doh:
Might raise a quid or 2 .. It's very nearly new .. unlike myself ...  :(
BC
« Reply #4 on: May 10, 2012, 04:27:36 AM »
Dave SD
Can a duck swim?  :D
Dave. Haven't I always said yer a GEM?  Thank you very much!  :thumbup:
The big day is June 2nd. I'll be posting details, nearer the time.
Thanks again Mate!
« Reply #5 on: May 10, 2012, 06:33:26 AM »
Do you want one of these ?
« Reply #6 on: May 10, 2012, 12:06:50 PM »
Ohhh...... Stew!  :bugeye:
How I/ we would love to put one of those to good use! Bless Yer!
Will be in touch, later.  :thumbup:
« Reply #7 on: May 10, 2012, 04:37:25 PM »
Having now had the time to examine what I'd achieved with the hot cap. I was feeling very pleased with meself.  :D
I had only ever silver soldered two small joints before.
It just goes to show, if enough notice is taken of techniques shown on here, the beginner can produce some very satisfactory work.  :thumbup:
Displacer time!
The cap bore is 1.4". I cut some steel sheet .020" thick, and wrapped it around a 1.25" ali bar.
Ground the inner overlap to a feather edge, and strapped it tight.
Then turned the outer feather edge. Moving the pie clip section by section.......
Swapped the clip for some stout wire, and fluxed........
Then silver soldered........
Just a nice line showing in the bore........
Cleaned up nicely.........
I think that will do nicely........
A busy few days ahead, including Harrogate. End caps next. As, and when.......
Thanks for watching!  :)
Offline stirling lad
  • Stirling Scotland
« Reply #8 on: May 10, 2012, 07:04:00 PM »
Your Off to a great start David, :thumbup:
I love those little robinson engines :drool:
AND some really nice things to auction as well,,
especially  them twin engines,, What a fine bunch of folks :mmr:
and I'm sure the torx set will raise a few quid for the kids , no problem.
All in all, A very productive day Mr Drillin,... Well done that man :clap:
  ...mike...
