I've got a big one!!
cfellows:
How about a foot powered treadle engine...
Chuck
Ronkh:
--- Quote from: cfellows on March 07, 2012, 10:30:15 AM ---How about a foot powered treadle engine...
Chuck
--- End quote ---
Hi Chuck.
Yep,
That's what I have been thinking of these past couple of days. I have some robust bearings and some decent sized ali. (Apart from a base which I think I will source from the ali scrap bin at work)!
All I'll need then are some robust thighs!
Kind regards,
Ron.
Chazz:
I can just see SHMBO at her next bridge party bragging about her new 200lbs spinning wheel capable of spinning 1" thick yarn at 600RPM! :thumbup:
Chazz
steamman:
You say this Flywheel is 23" diameter what is it width ?and what is the bore size? You could use this on a 6" scale Road Locomotive if the width is about 3"-4" say a Burrell or a McLaren,but you would have to build one Do you fancy that?
Ronkh:
--- Quote from: steamman on March 08, 2012, 06:41:20 AM ---You say this Flywheel is 23" diameter what is it width ?and what is the bore size? You could use this on a 6" scale Road Locomotive if the width is about 3"-4" say a Burrell or a McLaren,but you would have to build one Do you fancy that?
--- End quote ---
Hi Steamman,
Sounds good. I'll get back on here with this idea and the sizes.
There will be some serious questions asked once I plan/collate them!
I have always liked the thought of making a McLaren engine as I used to work for the F1 team McLaren!
From one extreme speed to the other!!
Kind regards,
Ron.
Navigation
[0] Message Index
[*] Previous page
Go to full version
