Author Topic: Lathe conversion to 3-phase power  (Read 25769 times)
Offline WillieL
  • This space for rent.
« on: February 13, 2012, 07:44:27 AM »
I just thought I would put up a few pics of my attempt at making a silk purse from a sow's ear.   :D
I bought this lathe (12x36) to be a step up from my little 7x10 mini-lathe. It was nice to be able to work on larger diameter and longer items with the new lathe. But something that I missed compared to the mini-lathe was the restricted number of spindle speeds available to me on the larger lathe. This became a real problem for me when threading to a shoulder because the lowest speed on the lathe was 60 RPM (66 actual). The chuck would free wheel for quite some time after being shut off, and it is not equipped with a spindle brake. I'm afraid I am just not that coordinated to pull off that kind of timing.   :palm:
So I set about trying to resolve that issue. I purchased a new 2 HP 3-phase motor to replace the factory 1-1/2 HP single phase motor. Bigger is better, right? (LOL) One of the first problems encountered was that the motor shafts were a different size, which meant that the factory drive pulley would not fit the new motor. And of course I could not find a new double pulley in the configuration I needed. But I did find single pulleys of the proper sizes. Time to modify!   :dremel:
After getting the motor mounted it was time to install a VFD to supply the 3-phase power to it. My lathe sits in the middle of the floor so there aren't any near by walls to mount it to. I just attached it to the rear of the factory electrical box and attached some lexan sheets to serve as a shield against getting any swarf/chips inside the VFD. I also added a large braking resistor.
To finish it off I mounted the VFD control unit remotely near the front of the lathe for convenience and also installed a "tachulator" from LMS, which displays spindle RPM and SFM readouts. I made an encoder wheel and mounting block to simplify the installation of the optical sensor on the lathe.
I also added a toggle switch on the right side of the VFD control box, that allows me to switch control of the lathe motor between the VFD panel and the factory control lever on the lathe apron. Flip the switch UP, and I can start/stop the lathe with the VFD push buttons. With the switch DOWN, the normal lathe lever is in control.
After some fine tuning I am now able to run the lathe as slow as 2 (TWO) RPM!
Threading to a shoulder is no longer a problem.   :clap:
WillieL
Midwestern USA
Re: Lathe conversion to 3-phase power
« Reply #1 on: February 13, 2012, 01:35:09 PM »
Great work and description. :thumbup:
But I am a little concerned at that switching between VFD panel and lathe control lever, I hope you have it so that the control lever will always stop the lathe no matter what the position of the toggle switch.
Offline WillieL
« Reply #2 on: February 13, 2012, 02:56:05 PM »
I see your point John, but unfortunately this VFD does not have a way of wiring/programming that kind of function. Actually I always use the normal lathe control lever anyway. I just added the toggle switch as an after thought, in case I ever had a switch or wiring failure on the apron control. That way I could at least finish whatever job I was working on at the time.
If I ever had a problem while using the start/stop buttons on the VFD control, I would head straight for the big red E-stop button on the front of the lathe anyway, instead of trying to find the little stop button in a panic. I have the E-stop wired to kill the single phase input power to the VFD. It stops everything.
That's the best I could come up with given the options available on the VFD I have.
WillieL
Midwestern USA
Offline DaveH
  • Kempton Park, South Africa
« Reply #3 on: February 14, 2012, 09:55:45 AM »
Hi Willie,
Nicely shown, a good job. :thumbup: :clap:
Because I don’t know a lot about these things I would like to ask a few questions.
The last photo - The VFD unit it is displaying 52.9 Hz – so what, does that tell me? What is it for?
Underneath (still on the last photo) you have a display showing RPM – was this purchased separately?, and did it come with the “encoder disc”.
One more,  why did you need a double pulley?
As my lathe is the same as yours so I have quite an interest in it.
« Reply #4 on: February 14, 2012, 12:06:47 PM »
Hi Willie,
Nice job on the conversion
I have a VFD unit on my boxford it ios great for screw cutting :) :) :)
Be carefull you dont run the motor that slow that it overheats
« Reply #5 on: February 14, 2012, 01:23:58 PM »
Hi Willie,
The rev counter is the tachulator from LMS...He made the encoder wheel himself...
The frequency readout you see, is the frequency of the electrical power supply going to the motor...
Normal mains frequency is 50Hz, so for 3 phase motor its speed will be  3000rpm.  Changing the frequency alters the speed at which the motor runs...
 If you look at the formula for a typical 3 phase motor which is:
         nS=(120*f)/nP
Where: nS = nominal speed
             nP = number of pole pairs ( minimum number of two...)
              f = frequency
So (120*50)/2 = 3000rpm
So if the number of poles is constant then speed becomes a function of frequency...
« Reply #6 on: February 14, 2012, 02:19:23 PM »
Mains frequency in the US is usually 60Hz, also Canada, parts of Japan and a few other countries (which I cant remember) the rest of the world uses 50Hz.
The standard motor speeds in 60Hz countries is higher therefore than in 50Hz countries and I presume 50Hz motors will tolerate lower speeds than 60Hz motors but dont quote me on that! :beer:
« Reply #7 on: February 14, 2012, 02:35:53 PM »
I specifically mentioned 50Hz in my post as DaveH currently lives in South Africa and having lived there, I know the mains is at 50Hz...
But you are correct that elsewhere there is the possibility of 60Hz mains, notwithstanding that, the formula still stands and motors will runs as expected when powered by a VFD irrespective of mains frequency..
Offline DaveH
« Reply #8 on: February 14, 2012, 02:45:20 PM »
John & John,
Thanks. :bow:
I haven't finished yet :D
So do all VFD's just show the frequency, don't suppose they show motor speed, or say % motor speed. Such as 50hz = 100%?
Just thought I would ask.
« Reply #9 on: February 14, 2012, 02:53:14 PM »
I dont know what the VFDs display as I do not have one however we should bear in mind that the speed of induction motors is only 'nominal' and all such motors will run a bit slower than you might expect from calculation of frequence and number of poles.  The difference is 'slip' and is essential to the operation of the motor.
« Reply #10 on: February 14, 2012, 03:20:08 PM »
Dave,
I have a number of inverters driving a bench drill, bandsaw, lathe and CNC miller. The most recent one (an Allen Bradley Powerflex) is for my CNC miller and it has by far the most comprehensive set of display features and general parameter settings.
For a machine with only one pair of pulleys and no gearbox between the motor and spindle it can be set to display the approximate spindle rpm. Most inverters display the output frequency but mine has a parameter - Process Factor - which you can set to anything between 0.00 and 9999 which is a multiplier for the output frequency. So if your spindle rotated at 3000 rpm for a 50Hz input frequency you would input a value of 60 for the process factor. (60 x 50 =3000)
If your machine has more than one pulley or a gearbox then it's of no practical use and a seperate speed sensor would make more sense and would (hopefully) give a more precise speed reading.
My CNC has 3 pulleys so I have a magnet embedded in the spindle pulley and a hall-effect sensor connected to the Mach3 controller which displays the speed accurately - unfortunately the displayed speed is never the speed I select - it's always about 50 rpm higher! (Not a major problem but niggling.)
Cheers.
Offline Country Bubba
  • LaGrange, GA USA
« Reply #11 on: February 14, 2012, 03:21:20 PM »
My vfd on my mill/drill can be configured to show Frequency or speed amongst other things. As noted above, it is not the most accurate thing in the world, but a lot closer than when I was having to guess based on the chart of various belt change speeds which was also wrong by several rpm :scratch:
Art
Country Bubba
« Reply #12 on: February 14, 2012, 03:38:40 PM »
I dont want to divert from the original theme of this thread...
But, I own a machine that has pulleys for varying the spindle speed and it also benefits from a vfd....
So to recap..
The vfd has a readout that can display the frequency of the electricity going to the motor...
If there are no pulleys involved then frequency is a direct function of motor speed...refer back to what I said about speed and frequency....
If you have pulleys then all is not lost...if you know the ratio of the pulleys, then factor that with the frequency readout of your vfd to arrive at spindle speed.
Or else use a seperate tacho that reads direct spindle speed via an interruptor mounted on the spindle or some other means be it a Hall device or proximitor...
Suffice to say, the best combination is a vfd with pulleys, as this allows the motor to run at a speed using the lowest pulley ratio to give the lowest spindle speed desirable without overheating the motor....
Offline DaveH
« Reply #13 on: February 14, 2012, 03:42:08 PM »
Phil & Art,
Thanks guys appreciate your help. I also understand it can get a bit tricky with the gear box  :)
I just think a % "speed" output would seem a little more sensible. Than,  what's the motor speed DaveH, " No idea but the frequency is 32.7 hz"  :Doh: :Doh: :Doh:
I suppose if one is good at metal arithmetric then it's fine.
« Reply #14 on: February 14, 2012, 03:46:17 PM »
I suppose if one is good at metal arithmetic then it's fine.
 If the mains frequency is 50Hz and the nominal motor speed at the that is 3000rpm, the its a simple ratio of 32.7/50*3000...which is errmmmm( reaches for calculator.... :Doh: )   1962rpm.. Easy aint it...( if its direct drive....)
Offline DaveH
« Reply #15 on: February 14, 2012, 04:01:27 PM »
Thanks John,
 :lol: :lol: :lol:
If they are available with a speed output reading, or a % output, I would find that a lot easier.
Even using the gear box. If the selected gear(s) gave a spindle speed of 580 rpm and the VFD says 60% that gives approx. 360 rpm.
Any spindle speed (+ or -) 100rpm  won't bother me much, I guess most of the the time anyway :lol: :lol: :lol:
I can certainly see the usefulness of a proper spindle speed measurement/display - a separate one that is.
Offline 75Plus
« Reply #16 on: February 14, 2012, 04:18:37 PM »
On this side of the pond all our AC power is delivered at 60 hz. The calculated speed for a 4 pole motor is 1800 rpm but due to internal losses the full load rpm is listed as 1725. Two pole motors F.L. rpm is listed as 3450.
  • LaGrange, GA USA
« Reply #17 on: February 14, 2012, 04:19:51 PM »
Again on mine, I have one basic pulley set that I use most of the time. So I set the max rpm reading to what the spindle will be at the max freq. setting. In my case, that is 4000 spindle rpm. Adjusting the vfd potentiometer to say 3000 (and that shows on the display when the motor is not running) and the speed of the spindle will be close to 3000 rpm.  It just so happens that if I choose the other belt change the ratio is approximately 2:1 so if I set the speed to 3000, then the spindle will be running about 1500 rpm. Still a lot closer than the amount available with the belt changes. :smart:
Art
Country Bubba
« Reply #18 on: February 14, 2012, 04:35:33 PM »
Dave,
The easiest way to do what you want is to make a scale for your potentiometer scaled appropriately.
On my lathe I use a 10 turn potentiometer with a 15-turn dial which starts at 2 and goes up to 12 corresponding to 20% to 120% of the speeds on the gearbox plate. (The inverter is hidden away in an enclosure and I can't see the display.)
Hope this makes sense.
Offline DaveH
« Reply #19 on: February 14, 2012, 04:47:43 PM »
Phil,
 :lol: :lol: :lol: :lol: :lol: :lol:
Dave,
"Whot"
 :med: :med: :med:  :doh: :doh: :doh:
Offline kvom
« Reply #20 on: February 14, 2012, 04:50:38 PM »
It's always been my assumption that switching power other than with the VFD switch will eventually cause the VFD to fail.
I am also wondering why you would need to power off the lathe when single-point threading.  The technique I was taught and use has one hand on the cross feed and the other on the thread-dial lever.  At the end of the thread the cross slide is retracted quickly and the feed disconnected.  I leave the spindle turning, and 60 rpm is actually pretty slow.  In class, the first thread I ever did was at 80 rpm and wasn't that fast.
« Reply #21 on: February 14, 2012, 05:12:28 PM »
Hi Dave,
I guess you dont want me to try to give a simpler explanation!
Offline DaveH
« Reply #22 on: February 14, 2012, 06:04:03 PM »
Hi Phil,
It's ok, I'm with the 2 to 12 bit - 20% to 120% of the gear box speed. Thats fine Phil.
10 turn pot. with a 15 turn dial - now that's tricky - not a clue  :palm:
« Reply #23 on: February 14, 2012, 06:19:25 PM »
Kvom,
I agree that you should never switch the output of a VFD when it's output is on and should use the VFD control inputs to start/stop/reverse the motor.
You say "I am also wondering why you would need to power off the lathe when single-point threading."
If you are single point cutting say a metric thread on a lathe with an imperial leadscrew it's usual to stop the lathe, retract the tool, (or vice versa) and then reverse the lathe to get the tool back to the start of the thread. A VFD can usually stop a spindle very quickly and so cutting up to a shoulder isn't that difficult.
Tapping in the lathe is made a joy with a vfd. At low speeds switching from forward to reverse is almost instant.
I should add - with screw on chucks there is always a danger of the chuck unscrewing on quicly reversing the direction. Mine is a camlock so can be reversed quickly with no problems.
Cheers.
Offline DaveH
« Reply #24 on: February 14, 2012, 06:35:37 PM »
Sorry Willie,
Sort of messed your thread up a bit, :lol: :lol: :lol:
