Author Topic: Cap bolt question  (Read 12877 times)
Cap bolt question
« on: November 19, 2011, 11:12:37 AM »
What size hole do I need to drill to clear the head of an M10 cap head bolt? I'm drilling into the under section of my sump, and I want to countersink the bolts nice & deep, so they don't get in the way of anything, and to reduce the temptation to remove them... (I may plug the holes once the bolts are in)
Thing is, I don't have any M10 cap-head bolts yet... & can't get any until Monday, so I can't measure myself...
Thanks in advance!  :nrocks:
Offline rleete
Re: Cap bolt question
« Reply #1 on: November 19, 2011, 11:16:02 AM »
Solidworks uses a 10.0mm diameter hole, by 18.0mm deep as standard clearance  for a 10mm S.H.C.S.
« Reply #2 on: November 19, 2011, 11:43:23 AM »
AdeV,
I measure with my trusty calipers, the head is 16.12 mm dia by 9.90mm high..
HTH
Offline Jasonb
« Reply #3 on: November 19, 2011, 11:45:53 AM »
Best to measure your screws as they do vary from the proper BS spec as you can see by comparing your sizes with the following.
http://www.roymech.co.uk/Useful_Tables/Screws/cap_screws.htm
J
« Reply #4 on: November 19, 2011, 11:46:32 AM »
There's a table here, Ade, which indicates that a 16mm dia x 10mm deep counterbore should be OK for M10. If the bolt heads are a mite too big when you get them, you could always turn them down to fit.
« Reply #5 on: November 19, 2011, 12:41:53 PM »
Excellent, thanks chaps. I'll make the holes 16mm for now & either enlarge them or turn down the bolts if they won't fit.
Look out for some sump progress tonight  :)
Offline buffalow bill
  • Country: scotland
« Reply #6 on: November 19, 2011, 01:47:47 PM »
Well, looking out for flying sumps, nothing here yet Ade. Still its only 6.45, time yet.  :lol:  :lol:  :lol:
Helensburgh, Argyll & Bute
Offline kvom
« Reply #7 on: November 19, 2011, 02:10:55 PM »
G-Wizard says 17.5x10 countersink.  Head diameter is 16.
« Reply #8 on: November 19, 2011, 02:13:59 PM »
So is this bolt a countersunk head or is it a standard cap head that requires a counterbore ?
Gone to get me kevlar armour....
« Reply #9 on: November 19, 2011, 02:37:10 PM »
Um, I suspect you're right John, I need a counterbore to hold the cap-head of the bolt...
Damn these pesky machining terms. Look, I need a hole, that's big enough for the head to go into, but not all the way through.... the upright section is drilled 10mm clearance, the sump itself is drilled 8.5mm tapping (& then tapped m10) to take the cap-head bolt, that.... you get the picture...
Anyway, a new sump post will be coming right up... just got to fettle the pictures & write the text.
« Reply #10 on: November 19, 2011, 04:17:30 PM »
In that case my previous post provides the dimensions....... :thumbup:
Sorry for being so picky....
« Reply #11 on: November 21, 2011, 12:19:50 PM »
John, your cap-head bolts measured exactly the same as mine: 16.12mm...
Predictably, my 16mm milling cutter cut a dead accurate 16mm hole... so the heads wouldn't fit. Rather than adjust the main sump, I just turned a few thou off each cap head (as suggested by Andy) so it fitted nicely, job done! I should probably put some kind of rust-proofing on it, if I can be bothered...
