Author Topic: elmers 25  (Read 19717 times)
Offline AcieraF3
elmers 25
« on: November 16, 2011, 06:48:48 PM »
I have almost finished building an Elmers 25 wobbler engine. The only thing I need to do is drilling the port hole in the cylinder. I was triggered by this discussion in Spuddevans project report:
Now, I went back and looked at your cylinder with the pivot in it. Are you going to forget to drill the entery hole for the air into the cylinder?  :poke: Just wondering.  :)
Well spotted!! Actually I deliberately have not drilled it yet. I figure on assembling the whole       gether, positioning the crank so that the cylinder is in the right position for the exhaust hole in the frame to line up with where the inlet hole is meant to be on the cylinder, and then spotting through to accurately mark up the postion. Does that make any sense outside of my head?
Tim
My question is: what is the position of the crank so that the cylinder is in the right position for the exhaust hole. A sketch would be very helpful.
thanks all :Doh:
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: elmers 25
« Reply #1 on: November 17, 2011, 04:58:25 AM »
Hi there AcieraF3 :wave:
I'm not sure if what I did was the correct way, but it worked for me. What I did was to assemble the engine, and position the crank with the crankpin at the very top of its rotation. That will position the cylinder at the right angle. Then I just made a little mark with a drill held in a cordless drill, guided by the exhaust hole in the frame. Then I dissasembled it and then drilled the inlet/outlet hole in the cylinder on the mill.
It may not have been the proper way, but it worked for me.
Let us know how you get on, even better, take some pictures and show us  :worthless: :D
Tim
Re: elmers 25
« Reply #2 on: November 17, 2011, 08:19:26 AM »
The correct position of the crank for alignment, is at 70*. Not the 90* that most engines are drilled at.......  :scratch:
This gives an overlap of the holes, allowing longer opening time of the port.  :thumbup:
Offline AcieraF3
Re: elmers 25
« Reply #3 on: November 17, 2011, 02:38:17 PM »
David, what do you mean exactly by 70 degrees. A small sketch would be very helpful. :Doh:
thanks
Re: elmers 25
« Reply #4 on: November 17, 2011, 03:24:59 PM »
thanks
Ace.
I really hoped you wouldn't say that!  :palm:
Please excuse the 'orribly horrible scribble........
Drilling the valve plate at the 70 degree position, allows the cylinder port to slightly pass, (but not close) the valve port, before returning. Giving a longer opening time.....  :thumbup:
Hope this makes sense!  :scratch:
Offline AcieraF3
Re: elmers 25
« Reply #5 on: November 17, 2011, 04:10:11 PM »
 :clap: What do you mean horrible. It is great and very clear. Thanks very much, I will drill the port this weekend hopefully and show you a runner!!?
Teun
Offline winklmj
Re: elmers 25
« Reply #6 on: November 18, 2011, 09:15:13 AM »
To mark where to drill the holes when I did mine, it took a tiny piece of shapened rod and stuffed it into the port in the cylinder wall--so it protruded only a tiny amount. Then bolted it all up and spun the crank a few times so I got a small scribed line. Then I just drilled the holes at the ends of the lines.
Mike
Offline jgroom
  • Kansas USA
Re: elmers 25
« Reply #7 on: November 18, 2011, 01:30:35 PM »
I may be seriously confused (usually am  :palm: ), but why not just use Elmers drill jig?  :scratch:
Offline John-Som
    • Start Model Engineering
Re: elmers 25
« Reply #8 on: November 18, 2011, 11:09:02 PM »
I agree with Jeff. Elmers drill jig has worked just fine for me and in fact it is one of the attractions of this design for the newbie.
John-Som
start-model-engineering.co.uk - a friendly place for model engineering beginners
Offline AcieraF3
Re: elmers 25
« Reply #9 on: November 23, 2011, 04:09:13 PM »
Jeff and John-som, I did use the jig but I thought is was only an aid for drilling the ports in the stand and not in the cylinder. Probably I am confused now :scratch:
teun
Offline jgroom
  • Kansas USA
Re: elmers 25
« Reply #10 on: November 23, 2011, 07:21:06 PM »
Yea, he didn't explain very well.  For the cylinder you put the piston/rod in the cyl, put the jig on the pivot, and use a piece of rod/drillbit through the 3/32" jig hole and connecting rod hole.  This lets you drill the 1/16" hole in perfect alignment with the port holes.
Hope that makes sense.
Offline AcieraF3
Re: elmers 25
« Reply #11 on: November 25, 2011, 10:49:36 AM »
It makes perfectly sense. I was already wondering where the second 3/32 hole was for. I should have thought a bit out of the box  :doh:
thanks Jeff.
Offline AcieraF3
Re: elmers 25
« Reply #12 on: November 27, 2011, 08:20:48 AM »
 :D  :ddb:
Thanks for all your help; I did it, it is a runner!!!!!!!!!! I have made a very crude movie to prove it. The next job will be blinging.
Teun
« Last Edit: November 27, 2011, 02:39:24 PM by spuddevans »
Re: elmers 25
« Reply #13 on: November 27, 2011, 09:11:23 AM »
YEeee...... HAaaaaarrrrrrrrrr   :ddb:   :ddb:   :ddb:   :ddb:   :D
It's alive! Well done Teun!  :clap: :clap: :thumbup:
Offline jgroom
  • Kansas USA
Re: elmers 25
« Reply #14 on: November 27, 2011, 02:32:52 PM »
Nicely done Teun!!!  :clap: :clap: :clap:
Offline spuddevans
    • My Photo website
Re: elmers 25
« Reply #15 on: November 27, 2011, 02:40:13 PM »
Well done Teun :clap: :clap: :clap:
I fixed your link to embed the video into your message.
Tim
Re: elmers 25
« Reply #16 on: November 27, 2011, 03:35:12 PM »
Nice, congrat  :clap: :clap:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
Re: elmers 25
« Reply #17 on: November 28, 2011, 03:24:39 AM »
Well done Teun  :thumbup: :thumbup: :clap:
Great fun to have that first runner isn't it ?  :D - It becomes addictive  :D
 :beer:, Arnold
Offline AcieraF3
Re: elmers 25
« Reply #18 on: December 01, 2011, 04:27:41 AM »
Thanks again
Arnold you are right it is addictive. any suggestion for a follow-up project
Teun :proj:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
Re: elmers 25
« Reply #19 on: December 01, 2011, 05:23:59 AM »
 :lol: I know just how addictive it is  :ddb: :ddb:
Hmmm...  For a follow-up, it's difficult to recommend something.  It depends on what you'd like, and what skills you'd like to improve.
If you want to work a bit on the bling factor, Elmer's Fancy is a great build.
If you want to test your skills at making something small, Tiny is a great little engine.
For a really nice, but longer-term project, I can really recommend the Grasshopper.
Then there's also always the option of making a bit of tooling you need  :thumbup:
My best advise would be to follow your heart and build something that draws your interest and that you really want to build  :dremel:
 :beer:, Arnold
Offline spuddevans
    • My Photo website
Re: elmers 25
« Reply #20 on: December 01, 2011, 05:31:15 AM »
After I built the #25 I chose to go for a more challenging build, Bog's Paddleducks twin marine engine, build log here:- http://madmodder.net/index.php?topic=1525.0 and the plans can be downloaded here :- Click me
Even if you don't want to build it, the plans are well worth reading through, many good hints and tips are there.
Tim
