Author Topic: Small 10-20-40 blocks that actually work  (Read 24858 times)
« on: November 15, 2011, 06:08:06 PM »
Plus 20-40-80's
Come on lads get your hard earned coin out and get splashing.
http://www.arceurotrade.co.uk/Catalogue/Workholding/Vee-Blocks-Angle-Plates
Top of the page.
Bit of history first, the original 1-2-3 blacks were made by Starrett and the idea was they bolted together to form angle, tee's, used as packing or to bolt items to to preserve squareness.
One of those items that never had a specific designed use but was different thing to different people, very useful.
However at some stage these blocks went over to Taiwan and were copied but they drilled all the holes tapping size for 3/8" UNC, tapped some then hardened and ground them before changing the un-tapped holes to clearance holes.
Result is they wont bolt together as designed and since then millions of sets have been copied and made in India,  and China. Even the Starrett ones are now wrong as they have them made out.
Another problem even for people with decent sized machines is they are too large, at 1" high they are 2" wide and at 1" wide they are usually taller than the average vise.
Soooooooooo, may I present these blocks above?
Again hardened and ground but they CAN bolt together and are of a size to suit most muddle enjuneers.
Listed as The Stevenson blocks because that cretin Ketan at ARC is still pissed off I gave him a quid for a nearly new X3 CNC mill and I told him not to name them after me. Wouldn't have been bad if I got royalties but the tight bastard wants the mill back first and not prepared to give me the quid back.
Seriously nice bit of kit and my pre production set has been in use daily for the last couple of months, in fact the 1-2-3's haven't been out the drawer.
Full marks to Ketan for listening and getting something done about them.
John S.
« Last Edit: November 16, 2011, 03:43:11 AM by John Stevenson »
Offline GerryB
Re: Small 10-20-30 blocks that actually work
« Reply #1 on: November 15, 2011, 06:41:23 PM »
G.Day John,
Just received a set of 1.2.3.Blocks from CDCO.(Made in China)
They are the same size as your 20.40 80 mm.
The difference in cost may surprise you.
I do realize that you are in the UK and CDCO is in the USA.
GerryB
Offline DaveH
  • Kempton Park, South Africa
« Reply #2 on: November 15, 2011, 07:17:40 PM »
Hello John,
Arc says they are 10-20-40
« Reply #3 on: November 15, 2011, 07:23:19 PM »
Gerry,
If they are 1" - 2" - 3" how can they be 20mm - 40mm - 80mm ?
I know there are a lot of cheap 123 blocks out there but they won't bolt together.
Dave,
They do two sets 10-20-40 and 20-40-80
John S.
« Reply #4 on: November 15, 2011, 07:24:38 PM »
I'll ask for a set when I write my letter to Santa, John. Thanks for the tip-off.
Gerry: are the unthreaded holes in yours drilled clearance size for bolts to hold them together, or are they the pilot size for taps so you can't get a bolt through them?
Offline HS93
« Reply #5 on: November 15, 2011, 08:07:35 PM »
mine are now on order..with Arc Euro.
Peter
Offline Miner
« Reply #6 on: November 16, 2011, 12:25:29 AM »
Awesome Sir John, Now we just need a set for the unwashed heathens who still work/think in Imperial like me. 1"X2"X3" and 5/16ths or 3/8ths thread. But even without that, It's great to see someone has finally worked on a fix for a huge problem that never should have happened. Every manufacter knows the reason they won't bolt togeather, But no one would fix the problem till now. :beer:
« Reply #7 on: November 16, 2011, 02:30:09 AM »
Hello John,
Dave,
They do two sets 10-20-40 and 20-40-80.....
I think what Dave H was querying was that the title of the thread was "Small 10-20-30 blocks..."
cheers / Dave M.
« Reply #8 on: November 16, 2011, 03:42:53 AM »
OOps.
There are 10-20-40, My mistake.
I'll see if I can edit the title.
John S.
Offline Henning
  • All the kit and no clue!
Re: Small 10-20-40 blocks that actually work
« Reply #9 on: November 16, 2011, 04:00:27 AM »
That was an early christmas present to myself sorted, then!
I can see a lot of easier setup in my future  :D
Mr. Stevenson and ARC you rock!  :headbang:
Henning
« Reply #10 on: November 16, 2011, 04:54:39 AM »
Got mine ordered,
Bin after those little roosters for some time, I've got the dodgy hole ones and a keep cussing that they are not correct, also bin after a small cube but I recon these will do that job as well.
Good one John  :thumbup:
Offline Spurry
  • Norfolk, UK
« Reply #11 on: November 16, 2011, 05:02:03 AM »
Those items have just moved to the top of my Christmas list. Thanks John.
It's well overdue for someone to make something metric for a change, with proper metric screws/bolts. Are we on the way to metrication..... :-)
« Reply #12 on: November 16, 2011, 09:28:54 AM »
Why would you want 10" X 20" X 40" blocks.  :scratch:
Running, ducking and finding cover.  :lol:  :lol:  :lol:  :lol:  :lol:
« Reply #13 on: November 16, 2011, 10:17:00 AM »
Thanks for the history.  I've always figured I was just missing the point of the threaded holes but now I see that's not quite the case.
For all of the setups I've ever used the standard 1-2-3 blocks for, the holes were completely unnecessary!
Although I like the idea of a smarter "general purpose" block of whatever size, there are way too many cheap ones out there of the 1-2-3 style to just discard them.  Perhaps a thread showing the various creative ways everyone uses their 1-2-3 blocks would be in order?
-Sparky
Offline jim
« Reply #14 on: November 16, 2011, 02:15:59 PM »
typical!
just had a £300+ order come on monday!!!
 :doh: :doh: :doh:
Offline HS93
« Reply #15 on: November 16, 2011, 08:52:00 PM »
I ordered some and the postage was only £2 . Bargin considering they are big chunks of metal, there postage has always been reasonable, allthough some UK stores are doing Free postage, this is handy as you don't worry and just buy when needed, so I then tend to buy a lot more but in small orders.
Peter
« Reply #16 on: November 17, 2011, 01:55:05 PM »
Just ordered one set of each size :thumbup:
Offline GerryB
« Reply #17 on: November 17, 2011, 10:36:40 PM »
 :doh:
G.Day John, I do apologise for stating that the 1,2,3.blocks i purchased were the same as your 20.40 80. i jumped to the conclusion when i measured the blocks whilst they were still in their packaging.
I also found that the threads were 3/8UNC,
Now this is a very common thread somewhere on this Planet!
I cannot for the life of me understand why a Manufacturer of these Blocks would go in to production and turn out items that were useless for the purpose that they were intended.
Also why Harden them?
Yes Andy you are correct in thinking that the holes for the bolts to go through are sized for tapping.
Now i realise that i have purchased a block that will not do what they were intended for but then again i have two of them.
I am sure that with a little thinking some one out there has the answer to the problem of unhardening the blocks and to open out the offending holes,they do not have to be rehardened.
GerryB
« Reply #18 on: November 18, 2011, 04:02:38 AM »
Gerry,
This is an idea that I have had for a while. In all the time that I have had my two sets the fact that they are hardened has never been a deciding issue, in fact a lot of my parallels are unhardened.
 I look on the fact that if they get dinged they can soon be dressed up and it won't have cost me a cutter if I make the odd mistake.
The fact that they are exactly 123 is also a disadvantage as I have never had to rely on an exact size. The disadvantage to me is that if I use one in a vise as packing with a 1" bar is it gripping the block or the bar, I find that with my home made packings that a quick lick on the surface grinder to purposely go under stock size is an advantage.
Next time I do to the hardening shop I'll get these annealed and do what I have been promising for ages, tap some holes first as their selection isn't what I would choose, then drill the rest out.
Finally a quick lick all round on the grinder.
John S
Offline Deko
« Reply #19 on: November 18, 2011, 05:05:46 AM »
You should'nt have said all that John !   I now have a vision of you peering over a mountain of 123 blocks, and thinking what the hell have i done.
« Reply #20 on: November 18, 2011, 05:19:16 AM »
Great job with the blocks John
For you'r next little project how about a small cube  80*50*50 ish:- Elipse use to do an imperial one and i've been trying to get my sticky mits on one for ages, but they are as scares as rocking horse turds.
Offline AndyB
« Reply #21 on: November 18, 2011, 04:45:16 PM »
Thanks John,
Got my set of each on order (had to have them delivered to work as ARC will not accept any postage where they can't get a signature! :bang: Don't they realise that some of us have to work? :doh:)
Stew,
Great idea, I would have one of those too.
Offline Ned Ludd
« Reply #22 on: November 19, 2011, 07:24:23 AM »
Hi Stew,
If you are going to Sandown, you might find a homemade "copy" on the SMEE stand. They are not difficult to make, just time consuming.
Ned
Leafy suburbs of NW London
« Reply #23 on: November 19, 2011, 09:36:51 AM »
Got mine today - the smaller ones wring together on the thin edge so they aren't half bad - easily good enough to satisfy my meagre skills.
Offline PeterE
  • Gothenburg
« Reply #24 on: November 19, 2011, 12:41:49 PM »
I have been thinking of such blocks for a longer time. At one point I contemplated on making a pair since I have a ground 25x50 mm bar to hand, but time has yet to be found.   :(
I therefore ordered  a small set as they seem to be extremely useful when setting up.   :D
BR
/Peter
