Gallery, Projects and General > Gallery
minimill dro revisited.
wheeltapper:
Right, calipers chopped and a bracket fitted under the vise plate.
Sorted.
and I cut the movable feeler off at an angle so when its not on the mill I can use it as a digital scriber.
perhaps I should be getting back to the engine now.
Roy.
Stilldrillin:
Thanks Roy! That was much easier than I expected.... :thumbup:
Here's how I tackled it.
Took off the sticky label, and cleaned off the sticky stuff. It gets everywhere! :palm:
Opened up carefully. Noting the fine thread screw, top left........
The depth probe is held on by a whisker, only........
Removed anything which didn't look like a DRO, and re assembled.......
Two existing M4 tapped holes, took a 40mm wide piece of filing cabinet.
Add a couple of magnets, and it looks/ works ok.........
Another Round Tuit, finally sorted, and put to bed........
wheeltapper:
Now that is neat. :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks:
Roy
Stilldrillin:
--- Quote from: wheeltapper on August 23, 2011, 12:40:40 PM ---Now that is neat. :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks: :nrocks:
Roy
--- End quote ---
Thank you, Sir!
I wouldn't have done it, without your nudge...... :thumbup:
doubleboost:
Nicely modded :clap: :clap: :thumbup:
I have a one on the quill of my mill
The x y axis has a Newall dro which has given me no end of problems
Trouble is once you have used one they become very adictive :bugeye:
Navigation
[0] Message Index
[*] Previous page
Go to full version
