Table mounted collet chuck.
<< < (2/2)
Pete.:
Nice job Ian. I like te dividing-head centering stub.
Davo J:
Nice job, :beer:
Just a suggestion
If you open it up to 20mm all the way through, the maximum size for the ER32(20mm) stock could go right to the bottom. It would mean making a new 20mm spigot though.
dvbydt:
Thanks for your interest guys.
Dave, yes I did go through that idea but the soft end arbor was not big enough where I needed it. So, I decided that I would just use a table mounted 3 or 4 jaw chuck when necessary.
The concentricity errors build up so that it is about 0.10mm (0.004")  TIR, but this can be reduced to 0.03mm (0.001") with a tap from a soft hammer.
Ian
Davo J:
If you ever have a need to use the full depth, you could shrink fit a larger piece into you arbour.
Nice work with what you have done though. :beer:
dvbydt:
Yes Dave, I may do that. It has the advantage of being able to finish machine the spigot diameter on the mill, so getting it more concentric.
Ian
Navigation
Message Index
Previous page
Go to full version
