Author Topic: Building a 31/2" Gauge Locomotive Engine  (Read 266070 times)
Offline kvom
Re: Building a 31/2" Gauge Locomotive Engine
« Reply #175 on: July 13, 2009, 08:20:04 AM »
I'm getting to the point when the chickens come home to roost.
I know just that feeling as that's where I am with my build.   :thumbup:  No worries!  Looks great!  :beer:
Offline shoey51
« Reply #176 on: July 13, 2009, 03:40:25 PM »
Im picking the loco up next weekend so no pictures till then Im afraid
Er..... Graham?  :wave:
Graham!!  :wack:
Don`t you think these good people have waited long enough, to see what I`ve seen?  :poke:
Perhapse, not on Stew`s posting though........   :thumbup:
Here you go David and for any one else thats interested :D
http://madmodder.net/index.php?topic=1447.0#new
« Reply #177 on: July 28, 2009, 12:11:20 PM »
Well I've bitten the bullet and a few days ago I started assembling the valve gear.
Its quite a fiddly little job with lots of small fasteners to do and undo, and its one of those jobs you just can't rush.
Any way first thing I did was to strip the wheels off the frame.
Ther's lots of little bits you have to carfuly put away and label.
When doing thes jobs you realy apreciate the assembly frame, that allows you to turn the loco through 360 deg, so you can move it about to gain access to bits, the one I'm using I made myselve, I'd seen a number of frames in use and I just came up with a design that suited the bits I'd got, I used some ally angle, box section, some 10mm studding, and bit of steel and wood and cap screws.
This is a close up of one of the pillars.
One problem from not using a casting for the cylinders was that the square section fouled the leading wheel horn block, to get round this I just milled a chamfer on the cylinders. Note the use of a ball race ring used as a parallel.
The cylinders are positioned 1" from the buffer beam and 5/16" from the top of the frame, it was carfully put in position and a big clamp put over the frame whilts the clamping hole positions were spotted through the fram with a hand drill. The cylinder was then transfered to the mill and the holes drilled in the side of the cylinder taking care not to drill through into the bore.
To keep them nice and square the holes were tapped 5 BA using the stand. Note the valves port faces are protected with masking tape.
The motion frame was assembled using the same technique (no pics forgot)
This is the asembly so far next job the valve linkage.
Having fun
« Last Edit: July 28, 2009, 12:23:01 PM by sbwhart »
« Reply #178 on: July 28, 2009, 12:44:37 PM »
Looking good Stew..... Glad you're taking the time to explain a few of the bits  :thumbup:
 :nrocks:
« Reply #179 on: July 28, 2009, 12:55:02 PM »
Stew,
That`s looking very complicated!
You might be having fun...... I`m holding me breath!  ::)
Hope it keeps on developing successfully for you......  :thumbup:
Offline zeusrekning
« Reply #180 on: July 28, 2009, 04:49:53 PM »
WOW man, Now this is a deep project. I just scanned all the pics, but this is definitely on my must read list.
Offline shoey51
« Reply #181 on: July 28, 2009, 04:53:54 PM »
Stew that is great progress so far  :thumbup: :clap:
I have slowed on my O gauge will have to get on with it again soon
  • Country: nz
« Reply #182 on: July 28, 2009, 04:57:41 PM »
Oh dear!  Stew you make me feel so inadequate! :lol:
It seems in the time I have spent on my little engine you have built half a locomotive! :thumbup:
« Reply #183 on: July 29, 2009, 01:43:16 PM »
Looks like it's going well Stew. It's amazing to think that this thing will be puffing around merrily pulling a few passengers!
« Reply #184 on: August 01, 2009, 05:21:24 PM »
Well I've spent a fiddly couple of days trying to assemble the linkage into the loco frame its a bit like knitting steel.
The drawings a write are are a bit fague as to how to fit it together it just say use BA fixing, all the holes are 1/8 so I used M3 threads as I have a supply of self loc M3 nuts, but as I started to get thing together I realised there wasn't enough room to fit nuts, all the pivot pins would have to loctited in place, a job I will leave untill last.
This is the assembly from the top
And from below
I tried turning it over by hand but everything loced up, I fiddled about a bit and it still loced up, fidled a bit more still loced.
So went for me tea and a think  :scratch:
I havn't set the timing I think thats the problem and I havn't connected the valves rods so tomorrow that what I'll do and have another go.
wish me luck
« Reply #185 on: August 02, 2009, 03:45:49 AM »
Stew,
I hate ordinary jigsaw puzzles........  ::)
Here`s wishing you the very best of good luck with yours!  :thumbup:
« Reply #186 on: August 02, 2009, 03:55:47 AM »
If you are still having trouble Stew, a new pair of eyes and hands are available if you need it.
Sometimes you can't see the forest for all the trees.
That is coming along just wonderful.
« Reply #187 on: August 02, 2009, 06:05:01 AM »
Thanks Chaps
Thanks for the offer for a second pair of eyes:- I've slept on the problem, the basic action of the linkage seems to be doing what it should. I think the problem comes from two areas:- I haven't set the eccentric timing correct it all over the place, and I haven't connected up the reversing rod I think it needs this to ancore the motion.
I've stripped it down made the gaskets and started to fit the studding for the valve chest, I'll put it all together getting all the pins to the correct length and fix them with loctite, and then see how it goes:- (there should be a finger cross smiley for times like this)
I may be calling on you if I'm still in trouble.
I'm nipping over to Macmodels tomorrow for some more studding is there anything you would like me to pick up for you.
« Reply #188 on: August 02, 2009, 06:21:35 AM »
Nothing needed Stew, I have everything for the project I am on now.
Thanks anyway.
Offline CrewCab
« Reply #189 on: August 02, 2009, 09:06:41 AM »
That is looking impressive Stew, good luck but I'm sure you'll sort it ..................... we're all watching and waiting with fingers crossed for you  :thumbup:
CC
« Reply #190 on: August 02, 2009, 12:24:46 PM »
Sure looks like a tight fit with all those parts in there.
Would like to see that in motion. Nice work Stew. :thumbup:
« Reply #191 on: August 03, 2009, 04:59:45 AM »
Well this has been a good and bad day
Made the gaskets for the cylinders using the gasket material John gave me:- thanks John
This is the gasket for one of the cylinder covers
Then spent some time fixing the studding to hold the valve chest in place but ran out of 6BA studding  :bang: Ok so I've got to go to Macmoddels today to get some along with some other bits a pieces. When I told the Boss I was planning on going to Macclesfield she said:- " ho ther's a good furniture shop in Macclesfield I'll come with you and we can look for new sofa and chairs"
 ££££££££££££ Translation $$$$$$$$$$$
Dam Dam Dam,
Any way assembled all the linkage sorting out the pins etc, quite happy with the results and fairly confident that it will work.
As you can't see it very well when its inbetween the frames this is it.
Then desaster I placed it up against the cylinder to see how it lined up with the valve rods.
Spot the deliberate mistake:-
I've off set the arms 1/8" too much.   :bang: :bang: :bang: :bang: don't know how I did this probably measured from the wrong point.
So option for putting it right 1:- Re bend them 2:- Re make.
I think I go for option 2 it wont take too long and I was not too happy with result from bending the crank method, I think I'll fabricate them up using a different method.
My scrap collection is growing
Still having fun
« Last Edit: August 03, 2009, 06:17:22 AM by sbwhart »
« Reply #192 on: August 03, 2009, 06:10:37 AM »
What's the fun in having everything fitting perfectly every time Stew?
It is little things like that which remind us all that we are only human.
Offline 28ten
« Reply #193 on: August 03, 2009, 02:08:00 PM »
I'v just read right through this, really good stuff. I like the way you have made the crossheads, I think it would translate to a smaller scale, so if i get some milling capability I will try it.
I am intrigued at the way you fitted the hornblocks and them made the rods to fit. In small scale the accepted method is to make the rods first and to use them as a jig for setting the hornblocks.
Anyway good stuff, I wish i had the ability to do something similar myself
« Reply #194 on: August 03, 2009, 03:19:22 PM »
Thanks for your encouragement Chaps
Hi 28ten
By rods I take it you mean bearing blocks.
I just followed the recommended way from books for fitting the hornblocks and bearings for this scale, the critical feature is getting everything square and in line, in smaller scales this must be as equally important, but I guess the smaller size allows you to use different methods.
I was really pleased how that method for making the cross head worked out, everything fitted together without any fettling, I just thought it would be a better method to those recommended in books so I tried it: a lot of the literature on building locos dates from the 1960 - 70, so I think it was written around what kit was available in the average workshop then, we've moved on since then.
Thanks again for you input
Have fun
« Reply #195 on: August 05, 2009, 05:39:31 PM »
Well done Stew,
That is looking mighty complex!  :smart:
« Reply #196 on: August 07, 2009, 04:20:14 PM »
I thought I'd give a bit of an update on the remake of the rocker arms, as I'll be short on shop time for the next week.  :(,
I originally toyed with the idea of making the rockers out of one piece instead of fabricating them, for the remake I went for the one piece option. The most suitable material I had in my stash was from a garage door (thanks Ralph  :thumbup:)
First job cut a chunk out with an hacksaw:- cutting on the forward stroke helped along with a bit of oil.
After half an hour and a sore arm this is what I got
Roughed to size in the mill :- Bloody tough stuff Ralph blunted two cutters  :hammer:
Note crib sheet to help keep things on track.
A bit of milling and drilling and filing and job complete. Note the difference with the first attempt made to drawing the second attempt may look different but all the critical features are correct and fit for purpose.
Any one who,s worked in a design office will tell you one of the most important things is to recognise the functions and importance of each feature:- Critical to function, Safety critical, Critical to appearance, Minor to function, Minor to appearance etc etc
I seemed to have spent an age assembling and unassembling things the cylinder is held together with 60, 6 ba and
 7 ba screws and washers, I've been busy with not a lot to show for my activity, any way I've packed the pistons and glands with PTFE packing and assembled the cylinder into the frame so that I can measure up for the reversing linkage which will be the last thing to fit before I set the timing and give it a try. As for setting the timing I've no idea how to do it I'm going do a bit of reading about it first and then have a go.
This is the assembly so far
Have fun
« Reply #197 on: August 07, 2009, 07:03:46 PM »
You know something Stew...
Your arms didn't look that big to me....all this sawing and filing we should be calling you Popeye......
maybe I'm just lazy....
Very nice work, as usual...... :clap:
« Reply #198 on: August 10, 2009, 02:07:57 PM »
Nice Job Stew  :thumbup:
Them there black arms are mighty strong stuff alright, they are what I used to make my ball turners tool posts from  :)
They are a very nice shape and would appear to me to have the benefit of a wider bearing section to spread the load, thus helping to reduce wear, I think  :scratch:
(with a good helping of oil etc obviously)
Really looking forward to the running tests  :D
« Reply #199 on: August 19, 2009, 12:31:34 PM »
Setting the valve timing
 :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang:
I guess that just about says it.
I've been trying to set the timing for nearly two weeks now, along the way I've put few things right:- catching pins: Valve chest drawing error that lost me 1/8" of throw: Reversing arm slipping: Eccentrics slipping, etc etc etc, but I just can't seem to get it right, I've read and re read the build manual tried putting a different interpretation on what it mean by forward dead centre and back dead centre:- checked things: eccentric throw, length of arms, action of reverser etc etc, but I just can't to get working or get things to stay put, one minute thing turn over nice then it jams up and throws thing out.
I'm sitting writing this with a can of draft GUINESS  :beer: to drown my sorrows.  :(
Decided to put it to one side for a few days, and then go back to stage one strip it down and carefully build it up again checking everything out.
Down but not beaten
