Author Topic: Big Marine Steam Engine  (Read 115929 times)
Re: Big Marine Steam Engine
« Reply #50 on: August 18, 2011, 01:38:21 AM »
Well done John!  :clap: :clap:
You two Lads Up North, produce some beautiful pattern work......
Also, the production castings!  :thumbup:
« Reply #51 on: August 25, 2011, 04:46:54 PM »
Got a little bit more done
I need some bronze so i can cast the cylinder lower cover
The price of scrap bronze has gone through the roof :( :( :(
Made the lids for the main bearing oil boxes instead
Replaced the cap heads with studs & nuts
« Reply #52 on: August 25, 2011, 05:29:29 PM »
This project off your'e is coming along very nice. I follow this with the greatest intresst.  :thumbup: :thumbup: :clap:
« Reply #53 on: August 29, 2011, 05:23:03 PM »
Lads
Got a bit of casting done this week end
Lower cylinder cover
Its going to be a propper pain to machine
The first one back in to the pot
Looking not bad
Being an enviromentalist i always try to use the waste energy
« Reply #54 on: August 29, 2011, 06:42:21 PM »
I don't know what I like best, the bacon or the cylindercover  :lol:
« Reply #55 on: August 29, 2011, 06:49:30 PM »
needed mushrooms really  :drool: :drool: :drool: :drool: :drool:
but it was still not bad
casting will do the job  :D :D :D :D
  • Country: za
« Reply #56 on: August 30, 2011, 01:17:29 PM »
Cor smashing, just going crispy the way I like it.  :D
Nicely cast. :thumbup: :clap:
Now I'm hungry! :drool: :drool:
« Reply #57 on: August 30, 2011, 02:07:52 PM »
Nice photo's of the pour.  :thumbup: Thanks.
I like my bacon a bit more crispy. Were are the eggs?   :lol:  :lol:
« Reply #58 on: August 30, 2011, 04:26:42 PM »
The wife was less impressed
It took the teflon off her wok :bugeye: :bugeye: :bugeye:
« Reply #59 on: August 30, 2011, 08:06:01 PM »
Guess you now have a fry pan dedicated to casting and bacon.  :lol: :lol: :lol:
« Reply #60 on: August 31, 2011, 01:38:49 AM »
Very nice work, as always. Great pictures and good reading.  :thumbup:
 :mmr:
« Reply #61 on: August 31, 2011, 03:07:12 AM »
Blummin' Wimmin!  ::)
They can never see the good we've done...... Always find a little niggle, to grumble about!  :bang:
That's good work well shown, John!  :clap: :clap: :thumbup:
« Reply #62 on: September 04, 2011, 04:06:16 PM »
Got a bit more done
Bottom cylinder cover machined
Faced the gland side bored it then made a mandrell
Milled off the middle bit but left a register for the cylinder
I had a lesson in marking out as the hole centers for the colums are very critical
Starting to look like a engine now
« Reply #63 on: September 04, 2011, 05:00:29 PM »
You have done a fantastic good job, keep up whith the good work.  :D
  • Country: za
« Reply #64 on: September 06, 2011, 01:36:50 PM »
It just keeps on getting bigger! :D
Sure does look good :thumbup: :clap:
« Reply #65 on: September 16, 2011, 05:24:59 PM »
Got a big bit done it is nearly a runner
Time for a fly wheel
I had a 8 inch disc with a hole in it about the size i wanted but a bit thin
A centre boss was turned up on my boxford
The big bit was possible for me to machine but it would have taken a long time
Rob Wilson kindly offerd to rough it out for me on his referbished cub lathe
(Robs idea of roughing out is different from mine) needless to say it turned out perfect.
Time to cut a key way in the crank
The proportions are just right
Could not resist making it spin around
Click the picture
Just a ecentric strap and some linkage should have it running
« Reply #66 on: September 16, 2011, 05:56:58 PM »
Wow  :bugeye:
You have done a greate work her, and soon you have a runner  :clap: :clap: :clap:
« Reply #67 on: September 17, 2011, 01:48:17 AM »
Looking real good John.
 :thumbup:
« Reply #68 on: September 17, 2011, 04:13:13 AM »
It's a great step forward when parts can be "oscillated".......  :thumbup:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #69 on: September 17, 2011, 01:29:23 PM »
Good going John  :thumbup:
Makes the right sound as well  :D
Kind regards, Arnold
« Reply #70 on: September 24, 2011, 04:58:10 PM »
Had a good day in the shop
First a bit of casting
Patern for ecentric strap
Nice solid casting
Using body filler to mark out the centre is a great idea (not mine) Any one care to guess who
« Reply #71 on: September 24, 2011, 05:05:05 PM »
I'll do the same thing :D
Good work  :clap: :clap:
« Reply #72 on: September 25, 2011, 02:10:04 AM »
John.
What do they have in the water, "up there"?  :scratch:
You and the "Other Lad" are full of good good ideas, giving great results......  :clap: :clap: :thumbup:
« Reply #73 on: September 26, 2011, 04:41:05 PM »
I managed to bore the exentric casting with out going to big
I cobbled a valve rod together and a temp valve cover
A blast of ar and it trundled in to life
No rings packing or gaskets at all
Valve timing set very near
click the picture
A very happy
« Reply #74 on: September 26, 2011, 04:47:08 PM »
Wow  :drool:
I am very inpressed. You have done such a fine work here, I must ask you what are you going do with this engine. Put it in a boat?  :D
