Author Topic: A couple of quickie fixes  (Read 18743 times)
« on: May 16, 2011, 04:44:24 PM »
Having had a couple of free hours to myself over the last day or two, I got into my shop for a little R&R.
There were a couple of jobs that needed sorting, one for a member on here, who thought that it would make a simple little article, and another from a local mate who wanted the clutch modifying on his 1/4 scale model car. I will be doing both bits in this same post.
John Somers is part way through his Upshur engine build which has a pair of gears inside of it, one on the crankshaft, and the other on the end of the camshaft. When in mesh, the smaller crankshaft one drives the larger (double the number of teeth) at exactly half crankshaft speed.
Depending where you obtain the gears from also affects what the centre hole size is. Some will come with a mounting flange, or like these, with nothing at all, just a hole through the centre, and as usual in cases like this, neither is of the correct size.
So John suggested that I might be able to make up a picture ridden post, just to show how I would put things right, and end up with the right sized hole in the correct sized gear.
This is John's posting on his own site.
http://start-model-engineering.co.uk/2011/05/upshur-vertical-single/upshur-4-stroke/
These are the gears that John sent to me for modification. Both are made of stainless steel and cannot be any thicker than the original thickness, so I can’t put a converter hub on there to get around the problem. So it requires a slightly different method than normal.
Just to keep my mind focussed when doing a job like this, I make up a rough layout page showing what I have and what is required.
I converted my lathe over to accept Myford chucks (they are much smaller than my normal ones) and duly fitted a four jaw self centring one. I prefer these as they give a much better gripping power  over a 3 jaw when handling small parts.
Because the gears are stainless, I decided to use stainless for the modification, so I chucked up a piece of 11mm diameter.
I then turned a spigot on the end that was 0.002” (0.05mm) smaller than the hole through the gears, and about 0.010” (0.25mm) longer than the thickness of the gears.
This shows what it looked like.
The reason for being so much smaller than the hole is to allow for clearance for the silver solder (silver BRAZE for our US cousins) to penetrate the joint by capillary action.
The filler piece was then really rough parted off, just leaving a very thin flange to stop it falling through the holes in the gears.
I soon had the two required done.
This next picture shows what some people class as a black magic art, but nothing could be further from the truth.
Silver soldering just requires a few basic rules to be adhered to to get good results every time.
The parts should be clean, chemically if possible (a wipe over with cellulose thinners), good quality silver solder and flux, plus a little flame technique.
I am a real tight a**e when it comes to solder, purely because it is so expensive nowadays. I use only just enough to get the job done. Why use too much and then have to clean it off afterwards? So this picture shows just what I used.
For stainless, Tenacity flux is a must. But I use it all the time on everything, mixed up with a tiny amount of water until it becomes a ‘runny’ paste. When it dries up in the mixing tub over time, I just add a bit more water to get it runny again and carry on with it. This batch must have been on the go for well over 18 months.
So, assemble the bits. The ring of solder goes under the flange, flux painted into the hole and around the solder, the slug is then pushed down into the hole.
The reason for holding these parts like shown is that, as everyone knows, the solder will always flow towards the heat, so because I want the solder to penetrate right through the hole, the parts get heated from underneath.
Just like this.
Once the parts reach cherry red, you will easily see the silver solder starting to run. When that happened, still keeping the heat on the part, I pushed down on the flange, just to make sure the slug was right through the hole.
After letting the assembly cool down until things had solidified, it was turned over.
As you can see, the flux and solder have penetrated perfectly through the joint.
No black magic, poking about or feeding extra solder in. Just the correct amount of everything, and a bit of heat.
After both were given the same heat treatment, they were just cleaned up with a wire brush.
Tenacity flux comes off very easily.
Now comes the magic bit.
I love using soft jaws, they are about the cheapest method you can get to really lift your accuracy while using a lathe.
So here, I have swapped the jaws over in my chuck, locked the jaws down onto a thin bit of bar and have just finished gently boring them out so they are a very close fit to the small gear size. Everything has to be completed on the small gear before boring out again to take the larger gear.
Notice the back recess, to allow for the sticky out bits on the soldered up gear.
The gear was bedded into its recess, and very gently faced off until I had a perfectly clean face.
This did mean I took a minute amount off the original gear.
Having turned the gear around, the same was done on the other side.
Without touching the gear, using a spotting drill, I put in a nice centre for the drills to follow.
By climbing up in size, I eventually ended up at 7.8mm.
Followed up with an 8mm machine reamer, to give the correct size for the shaft it is to be fitted onto.
The same procedure was followed, boring out jaws etc to fit the larger gear, eventually ending up with a 6mm reamed hole.
Job done and dusted.
I hope you enjoyed this little escapade about getting yourself out of a sticky situation.
Now onto the next, getting the clutch done.
Please don't ask about what engine it is, all that arrived here were these two pieces with a note saying that it was off a quarter scale model car and the clutch, rather than screwing onto the threads shown, he wanted the clutch backplate taper boring so that it could be fitted onto the other end of the crankshaft.
In this case, I'm not one for asking why, I just get the job done. It's his problem afterwards.
So after stripping the clutch, I found that the backplate fitted perfectly well into the previously bored soft jaws, so it was just a matter of getting the right taper.
I invariably always have my tool post set perfectly square to the topslide, so this method works just fine for me. With a 1/4" thick parallel resting along the tool post face with the end of the para resting along the taper, I tightened up the loose topslide at that angle.
I will be using the topslide for cutting the taper, so I mounted up a tiny carbide boring tool, and marked it up showing the depth I needed to bore it to.
I just followed the general procedure of boring to about 2/3rds size, checking with engineers blue and slightly adjusting the angle if needed. I only needed to move it a tiny amount just once to get the angle perfect.
Boring finished.
And it fitted the the crank perfectly.
I hope you enjoyed following me along in the shop for a few hours.
Hopefully, I will have two very satisfied mates.
« Last Edit: May 18, 2011, 04:44:13 AM by Bogstandard »
Offline crabsign69
Re: A couple of quickie fixes
« Reply #1 on: May 16, 2011, 04:53:45 PM »
wow im always learning something here thanks for sharing. good job too
Offline Blade
« Reply #2 on: May 16, 2011, 06:33:38 PM »
Nice job! Thanks for sharing.
Are those soft jaws available for most chucks? Looks like they are very usefull.
« Reply #3 on: May 16, 2011, 07:00:11 PM »
Very nice informative fixes here, both of them. What is learned here can be applied to many situations in the shop. Thanks for showing John.  :D
Offline John-Som
    • Start Model Engineering
« Reply #4 on: May 17, 2011, 01:06:56 AM »
Once again Bogs has come up with sound engineering solutions and presented them to us in a clear and concise way. Even if we are not faced with the identical task you can bet there are always hidden gems in every post. I particularly liked the method of setting up the spot on taper for the boring of the clutch - easy when you know how !
Anyway thanks Bogs for sorting out my gears, you have saved me from making a dogs dinner out of my costly gears.
John-Som
start-model-engineering.co.uk - a friendly place for model engineering beginners
« Reply #5 on: May 17, 2011, 02:17:21 AM »
Sweet! :clap: :clap:
Very nicely done, and shown John.......   :thumbup:
  • Country: za
« Reply #6 on: May 17, 2011, 06:49:07 AM »
Excellent Tutorial  :clap: :clap: :clap:
« Reply #7 on: May 17, 2011, 07:23:26 AM »
Just to answer Blade's question.
Whenever I buy a chuck, the first thing I always ask is if soft jaws are available for it. If they aren't, then I don't buy that particular chuck, purely for the reason you have asked that question.
If you can trace your particular chuck to a supplier, then you stand a good chance of obtaining a set.
If you can't, then it could be rather difficult, mainly due to the fact that each manufacturer will have their own ways and settings for cutting the scrolls in their own produced chucks, so just by asking for a set of soft jaws for say a 5" 3 jaw chuck might get a set sent to you, but unless you are very lucky, they won't actually fit because the scroll inside the chuck isn't the same as the scrolls on the back of the jaws.
I have been trying to educate people over the last few years to buy soft jaws for their chucks when they actually buy the chuck. They are relatively cheap at around 25 pounds per set for a normal sort of chuck, and that outlay will be more than repaid when you come to do very accurate turning, plus, at a push, when they are eventually turned down so you can't turn them down any more, you can always bolt or weld new soft iron faces to them, so they should last at least the lifetime of the chuck.
So even though this hasn't answered Blade's question exactly, maybe he will understand where I am coming from.
Offline metalmad
« Reply #8 on: May 17, 2011, 07:28:46 PM »
nice one Bogs
Pete :clap:
A little bit every day, sometimes the same little bit!
« Reply #9 on: May 18, 2011, 03:26:52 AM »
HI as per very well dun regards bob
Offline kvom
« Reply #10 on: May 18, 2011, 09:45:53 AM »
Soft jaws are great, both for lathe and milling vise usage.  CNC lathes with non-collet chucks typically use soft jaws all the time.  Those jaws are steel.
For home shop use, aluminum jaws are easiest to use.  If a chuck has 2-piece jaws, then the upper jaws can be replaced with aluminum bars.  It's just a matter of cutting to size and drilling/countersinking holes to match the inner jaws.  I bought chucks for my lathe and rotab with 2-piece jaws just for use with soft jaws.  You don't need a high quality chuck since runout is irrelevant;  the bored pocket will be concentric with the spindle perforce.  BTW, don't dismount the chuck until you're done with that pocket in order to maintain accuracy.
As this thread shows, soft jaw pockets are often the only way to securely and accurately hold a thin disc.
Offline cfellows
« Reply #11 on: May 18, 2011, 09:59:44 AM »
Nice write-up, Bogs.  Always enjoy reading your posts.  I was going to ask about using soft jaws with a chuck having 2-piece jaws and KVOM answered that question.
Chuck
« Reply #12 on: May 18, 2011, 04:59:38 PM »
Chuck,
Thanks for the encouragement.
It seems in the UK, those two part chuck jaws aren't as popular as the one piece type that I use.
Maybe it is our pessimistic way of thinking, the less there is, there is less to go wrong.
But I will keep repeating it until I am blue in the face, soft jaws are the cheapest method to get super accuracy. I even bore out the jaws when I fit them to my RT chucks on the mill if required.
Offline Blade
« Reply #13 on: May 18, 2011, 06:07:36 PM »
Thanks for the answer John. I may not be able to find soft jaws for my chuck but I know I can get emergency collets which can serve the same purpose up to a certain size. Would be nice to have the soft jaws for the larger sizes though, maybe I can make some for the four jaw.
« Reply #14 on: May 19, 2011, 03:38:50 AM »
Blade,
Soft jaws are only of any use with self centring chucks, not for 4 jaw independents.
« Reply #15 on: May 19, 2011, 05:09:03 AM »
John, just wanted to jump in and thank you for this post. I used your method of sliver soldering last night to get a super joint - I`ve never used a ring of solder like that, always fed it in - this way worked really well.
« Reply #16 on: May 19, 2011, 06:51:06 AM »
I'm glad it worked for you, it has done for me for more years than I care to remember.
The only time I really ever feed wire is when doing a very large assembly like a boiler shell, where you can't gauge the amount of wire that is needed because of the usual uneven surfaces, all other times, it gets the silver solder laid on or around the joint treatment. It is just a lot easier for my way of working, other people may find wire feeding more to their liking. So once you find a method that works for you, stick with it, but never forget, that in some situations, other methods may be required.
  • Country: za
« Reply #17 on: May 19, 2011, 08:11:58 AM »
I think it's about 60 'ish :D :D :D
Offline SPiN Racing
« Reply #18 on: May 19, 2011, 03:21:01 PM »
Great post John, very informative.
Always enjoy watching your technique to achieving the goals.
Parallel on the taper.. I like that.  :clap:
Always good to see your posts, and methodology.
Scott
SPiN Racing
